Don’t post in this thread, refer to this thread !
UPDATE: 6.6.78 Image
Updated image, firmware, kernel, and tweaks to help the CM5 work better in the hardware. This image does not need any of the tweaks below. This image the FS will not auto expand, with people having problem with the sd card on the CM5 I thought best to leave it out for now. If you have problems with your sd card try adding sdhci.debug_quirks2=4 to you cmdline.txt file.
UPDATE: CM5 Audio Now Available!
CM5 audio is here! Kernel 6.6.77 now has a experimental PWM audio driver. It’s currently out of tree so it won’t be added to my GitHub kernel yet. You’ll need to update your config.txt file to enable it. Here’s a current copy of how it should look HERE or add dtoverlay=test-rp1-audio-out to the [pi5] section of the config.txt
I have also included a newer panel driver for the CM5. It is a little more reliable but not 100% yet. I do have a hack way of making it even more reliable but it requires a systemd service to manually kick on the backlight when it fails to start. Download backlight.service and name it blacklight.service then place it in /etc/systemd/system/ then activate it by sudo systemctl enable backlight if a image fails to display then a restart is required.
Features: ClockworkPi-CM4-Bookworm-6.6.y
  • Desktop, Lite, and RetroPie images available.
  • Image built using Pi-Gen.
  • APT repo added for LTS kernel updates.
    • Bleeding edge repo available for the latest kernel 6.10.y. You need to add the bleeding repo.
  • Dark mode for all screens (first boot, login, desktop)
  • Sane charging defaults applied.
  • External WiFi antenna already set in config.txt.
  • A few clockworkpi images for wallpapers.
  • Activate 4g card by uconsole-4g enable and uconsole-4g disable
  • linux-headers included with kernel
  • Works with both DevTerm and uConsole.
  • Updated driver overlays - easier config.txt management.
    • Just follow the instructions at the bottom of the config.txt
Raspberry Pi Imager will cause image not to boot if you apply custom settings.
I have added a few working/testing images and kernels with the *.deb files to install in the mega folder if you want for different OSs.
Google Drive link for the main image if Mega doesn’t work for you.
Here’s my Github with the rpi-6.6.y branch if you’d like to compile yourself. All the ClockworkPi drivers are pre-marked to compile in bcm2711_defconfig or bcm2712_defconfig. Also the APT repo with kernels and hardware scripts for ClockworkPi devices
Support my work and buy me a coffee here.
New Distro Poll
Android apps running on the uConsole CM4 via Waydroid
Sunvox on Uconsole CM4
Retropie on uconsole
What’s is the current state of the hardware and software?
New uConsole won't boot up
Initial Impressions (with CM4-108000)
Favorite OS and applications to use on the uConsole?
Raspbian OS, sudo apt update failed
How to make an OS image from vanilla Raspbian OS?
CM5 for DevTerm
Update to uConsole
Guide to configure your own OS for uConsole-CM4
The screen remains unlit after assembling the UConsole
New uConsole and already has screen burn-in
SunVox on uConsole
Meshtastic / Radio Helper Scripts for Uconsole + Hackergadgets AIO v2
Cm5 help o.s image
Uconsole turns off after few minutes of use
Updated guide for Bookworm : encrypted root partition on uConsole
Should I get a CM4 or CM5?
So how do I do... anything?
Confused on updates
I have some questions. please
A couple weeks with the uConsole
uConsole-Sleep v1.3
Id like to upgrade my OS
Newer kernel than 5.4.61+?
Disable Autologin for CM4?
How do I prevent kernel updates from bricking my CM4 DevTerm?
Brand new uconsole no picture on lcd
Raspberry pi os build with some pre-installed apps
uConsole OS directory
RPi OS Bookworm CM4 ........i think i have cracked getting new custom OS recipe
Setting DevTerm as a writer deck
uConsole os Images
EXT Cartridge Module
uConsole-Sleep v1.3
uPico Expansion Card
Unable to launch Chromium after apt upgrade
Cellular Modem Service
Uconsole infinite reboot
Speakers stopped working
CM4 Adapter does not work
About R-01, software and difference
Is this image already has pre-disabled kernel update(as it was on 6.1)?
Yes it does and I’m going to work on a repository to apt update the kernel. I’ll set a build script up to do it once a month. I’ll post here when I get that completed. You’ll just have to add the repository when I’m done.
Solid work, thank you! installing the image)
have succeed to apply rotation for plasma login screen? as i can set rotation within desktop, but not when do first power on(
The login screen is the only screen I have no F’n clue whats going on. I can rotate the console, lightDM first boot, desktop. but I’ve been looking and looking but cant figure out how to do it. If you figure that out let me know.
fixed it.
  1. add next line
xrandr --output DSI-1 --rotate right
to the file
/usr/share/sddm/scripts/Xsetup
  1. Add next lines
[X11]
DisplayCommand=/usr/share/sddm/scripts/Xsetup
to the file
/var/lib/sddm/state.conf
reboot.
after i got correct rotation right after boot. maybe it will help
The last small issue is with the sound while play VCMI. Small glitches appears when on stock clockwork image everything is fine and audio is clear
disappeared when selected pulse-audio and rebooted in raspi-config
For Arch, usually this is enough:
does retropie works with wayland anyone?
I know retroarch and emulationstation does.
Thank you for this! The 6.6.30 kernel fixed the problems I had with hardware accelerated video decode.
It would be great to integrate your work in Armbian - only I have no clue how to get it in there.
It would also take care of the distribution - Mega is, well, not so Mega :wink:
I downloaded the 6.6 kernel file from Mega. I thought the zips were going to be .deb files but they are just folders with a lot of subfiles. how is that supposed to be installed? I already have the previous image with the 6.1 kernel running own my console. and I would lie to update the kernel rather than redeploying a new OS on the system. is that possible to do with the files in that download?
Yes, the contents of the “out” folder needs to be dumped in the boot partition and the other folder gets dumped in the root partition.
cp -r out/* $bootfs/
cp -r lib/* $roofs/lib/
Something like that
Thanks I’ll make a backup of this SD card and then give that a shot.
Appears gpio isn’t working thus breaking the 4G extension script.
The brightness keys are easily fixed with brightnessctl as mentioned in one of the previous image threads.
The original patches used now deprecated commands. I had to rework the audio patch to work. I can take a look and see what’s going on but I don’t have a the 4g card or a uConsole. So I can’t test it.
What commands are you using for the gpio?
Here’s the script.
