Building an MMBASIC Utility Library
(updated July 9, 2025)
I’m starting to play around with my PicoCalc, and as it’s been a pretty long time since I’ve done much of anything in MMBASIC, I thought I’d start by rebuilding my library of Subroutines and Functions. The first two are are a file selector and a fixed width input function:
(it’s formatted for readability)
'Utility library
Clear
Option base 1
Option EXPLICIT
Dim fontw As integer= MM.FONTWIDTH
Dim fonth As integer= MM.FONTHEIGHT
Dim b As integer=145
test
Sub test2
  Local a$,k$
  CLS
  k$="abcdefghijklmnopqrstuvwxyz"
  k$=k$+"1234567890.-_"
  a$=textinput$(0,20,k$,10)
  Print @(0,0)a$
End Sub
Sub test
  Local a$
  CLS
  a$= dirwin$(0,50,14,"B:/","")
  Print @(0,0)a$;
End Sub
Function dirwin$(x,y,lines,path$,Ext$)
  Const winw=39
  Local fname$(256)
  Local a$,key$,i,n,file$,search$
  Local p$,fcount,top,bottom
  Local ftop,x2,y2,y3,y4,y5
  Local boxw,boxh,o$,o1$
  Local cursor,cmode,endstate
  Local dflags As integer
  dirwin$="999"
  endstate=1
  dflags=2
  key$="abcdefghijklmnop01234567890.-"
  boxw=fontw*winw+6
  boxh=fonth*(lines)+3
  x2=x+3
  y2=y+fonth+3
  y3=y+2
  y4=y2+3
  y5=y2+boxh+2
  Box x,y,boxw,fonth+3,1,666
  Box x,y+fonth+4,boxw,boxh,1,b
  Box x,y5,boxw,fonth+3,1,b
  Print @(x2,y5+2)"[D]rive [S]ort"
  If ext$="" Then
    search$=search$+"*"
  Else
    search$="*."+ext$
  EndIf
  search$=UCase$(search$)
  If path$<>""Then p$=path$ Else p$=Cwd$
  On error skip
  Chdir p$
  If MM.Errno Then p$="A:/":Drive "a:"
  'Main Loop
  Do
    'Load dir array
    If endstate=1 Then
      fcount=0
      cmode=0
      cursor =1
      ftop=1
      If Len(p$)>3 Then
        fcount=1
        fname$(1)="1.."
      EndIf
      For i=1 To 2
        On error skip 9
        If i=1 Then
          file$=Dir$("*",DIR)
        Else
          file$=Dir$(search$,file)
        EndIf
        Do While file$<>"" And fcount<256
          Inc fcount,1
          fname$(fcount)=Str$(i)+file$
          file$=Dir$()
        Loop
        If MM.Errno Then Exit Function
      Next i
      Sort fname$(),,dflags,1,fcount
      If Len(p$)>winw Then
        Print @(x2,y3)Left$(p$,2)+"..."+Right$(p$,winw-5)
      Else
        Print @(x2,y3)Left$(p$+Space$(winw),winw)
      EndIf
    EndIf
    Do
      Select Case endstate
        Case 1,2
          top=ftop
          bottom=ftop+lines-1
        Case 3
          top=ftop+cursor-1
          bottom=ftop+lines-1
        Case 4
          top=ftop+cursor-2
          bottom=top+1
      End Select
      For i = top To bottom
        If i<=fcount Then
          n=Len(fname$(i))-1
          a$=Right$(fname$(i),n)
          file$=Left$(a$+Space$(winw-4),winw-4)
          If Left$(fname$(i),1)="1"Then
            file$=file$+"DIR "
          Else
            file$=file$+"FILE"
          EndIf
          If i=ftop-1+cursor Then
            cmode=2
          Else
            cmode=0
          EndIf
        Else
          file$=Space$(winw)
          cmode=0
        EndIf
      Print @(x2,y4+(i-ftop)*fonth,cmode)file$
      Next i
      Do :a$=UCase$(Inkey$):Loop Until a$<>""
        i=Asc(a$)
        endstate=0
        If i=128 And cursor+ftop>2 Then
          If cursor>1 And cursor<=lines Then
          cursor =cursor-1
          endstate=2
          ElseIf cursor=1 And ftop>1 Then
            endstate=3
            Inc ftop,-1
          EndIf
        ElseIf i=129 And (cursor+ftop-1)<fcount Then
          If cursor>=lines Then
            Inc ftop,1
            endstate=2
          ElseIf cursor<lines Then
            Inc cursor,1
            endstate=4
          EndIf
        Else If i=136 Then
          cursor=1
          If ftop-lines<1 Then
            ftop=1
            endstate=3
          Else
            ftop=ftop-lines
            endstate=2
          EndIf
        ElseIf i=137 Then
          endstate=2
          If ftop+lines>fcount Then
            cursor=fcount-ftop+1
            'add new endstate?
          Else
            ftop=ftop+lines
            cursor=1
          EndIf
        ElseIf i= 134 Then
          endstate=2
          ftop=1
          cursor=1
        Else If i=135 Then
          endstate=2
          ftop=fcount\lines*lines
          cursor=fcount Mod lines+1
        ElseIf i=13 Then
          a$=fname$(cursor+ftop-1)
          o$=Right$(a$,Len(a$)-1)
          If Left$(a$,1)="1" Then
            endstate=1
            If o$=".." Then
              On error skip 2
              Chdir ".."
              p$=Cwd$
            Else
              If Right$(p$,1)<>"/"Then
                p$=p$+"/"+o$
              Else
                p$=p$+o$
              EndIf
              On error skip 1
              Chdir p$
            EndIf
          Else
            endstate=5
          EndIf
        ElseIf a$="D" Then
          endstate=1
          If Left$(p$,1)="A"Then
            a$="B:"
          Else
            a$="A:"
          EndIf
          On error skip 2
          Drive a$
          p$=Cwd$
          If MM.Errno Then Drive "A:":p$=Cwd$
        ElseIf a$="S" Then
          endstate=1
          If dflags=2 Then
            dflags=3
          Else
            dflags=2
          EndIf
        ElseIf Asc(a$)=27 Then
          endstate=6
          o$=""
        EndIf
      Loop Until endstate > 0
  Loop Until endstate>4
  dirwin$=p$+"$"+o$
End Function
Function TextInput$(x,y,key$,length)
  Local blink,text1$,cx,a$,c$,px,cmode
  blink = 0
  Text1$=""
  cx=0
  'Fixed Text Input
  Print @(x,y)Space$(length);
   Do
    Do
      a$=Inkey$
      blink=(blink+1) Mod 1000
      c$=a$
      If blink <500 Then cmode = 2 Else cmode =0
      cx=Len(text1$)
      If cx=length Then
        c$=Right$(text1$,1)
      Else
        c$=" "
        Inc cx,1
      EndIf
      px=cx-1
      Print @(x+((px)*fontw),y,cmode)c$;
    Loop While a$=""
    Print @(x+(px*fontw),y,0)c$
    If Asc(a$)=8 And Len(text1$)>0 Then
      Print @(x+px*fontw,y,0)" ";
      Text1$=Left$(text1$,Len(text1$)-1)
    ElseIf Instr(1,key$,a$)>0 And Len(text1$)<length Then
      Text1$=text1$+a$
      Print @(x+px*fontw,y,0)a$;
    EndIf
  Loop Until Asc(a$)=13
  textinput$ = text1$
End Function
I wrote the original code in 2015, and was an all-in-one directory routine, but I don’t entirely remember what my logic was, so paired I it down to the basics and will build it back up. The original directory display routine was simpler, and I update it to something I think is way better, and I added a drive swap with some error protection so it doesn’t bomb if you pull out the SD card. Currently it’s just a file selector, that returns the path and filename, with a $ delimiter between the two. In the original the dialogs were non-destructive popups, but because of the between the Maximite Pico MMBASIC, they don’t work, so I have to come up with another method.
The second function is a fixed width input routine that that only allows characters from a defined set. I originally created this because the standard INPUT function didn’t allow enough control over what was entered or what the max size was.
They work, but they’re a bit of rough work in progress, so I’ve got a lot of cleanup and optimizing to do, and I’m looking for feedback and suggestions.
Your file selector works well and looks nice!
Suggestions:
  • sorting; either sort alphabetically by default, or allow for sorting by alpha/timestamp
  • add a way to scroll up/down by a full “page”; shift+up/down arrow on PicoCalc sends pageup and pagedown, so that might be a good way to map it
  • consider expanding the size to full screen; given the limited display size of the PicoCalc, I’m not sure it would be useful to have anything showing behind the dialog anyway
  • for filenames that are too long (I only had one when I tested – “geometricabstractionism.bas”), consider animating/scrolling the line when highlighted so it can show the full filename; this is less likely to be an issue if the dialog was expanded to full screen
  • since there’s plenty of space on the drive indicator line at the top, consider moving the “[D] Drive” note there and combining it on the single line with the actual drive letter, as this would free up another row
  • consider passing in some colors (foreground, background, frameline) for “theming”, if used with an application that has a very different default color set;.these default colors are fine though, and allowing for theming might just add unnecessary bloat
I’m guessing the input function is still a work in progress? I noticed a few errors inlcuding a typo in the LOCAL line (“.” insead of “,”), an error with KEYDOWN, and some other stuff and decided to not go further looking into it for now. :slight_smile:
I played around with it a bit and added:
  • scroll up/down by a full page using shift+up/down
  • expanded size to full screen
  • moved “[D] Drive” to top line, at far right, added divider line, and adjusted “…” path drawing to match
  • also changed some var=var+1 to INC var,1 (faster)
Still to do:
  • sorting
  • handle long filenames (though maybe not necessary now the area is wider)
  • color theming
(Also, I removed the second function and test2 while I edited this.)
'Utility library
CLEAR
OPTION base 1
OPTION EXPLICIT
DIM fontw AS integer= MM.FONTWIDTH
DIM fonth AS integer= MM.FONTHEIGHT
DIM b AS integer=145
test
SUB test
  LOCAL a$
  CLS
  a$= dirwin$(0,0,24,"b:/","")
  PRINT @(0,0)a$;
END SUB
FUNCTION dirwin$(x,y,lines,path$,Ext$)
  CONST winw=39
  LOCAL fname$(256) 'length 13
  LOCAL a$,key$,i,n,file$,search$
  LOCAL p$,fcount,top,bottom
  LOCAL ftop,x2,y2,y3,y4,y5
  LOCAL boxw,boxh,o$,o1$
  LOCAL cursor,cmode,endstate
  dirwin$="999"
  endstate=1
  boxw=fontw*winw+6
  x2=x+3
  y2=y+fonth+3
  y3=y+2
  y4=y2+3
  y5=y2+boxh+2
  BOX x,y,boxw,fonth+3,1,666
  BOX x,y+fonth+4,boxw,boxh,1,b
  PRINT @(fontw*(winw-9),y3)"[D] Drive"
  LINE fontw*(winw-9)-4,y,fontw*(winw-9)-4,fonth+3,1,666
  IF ext$="" THEN
    search$=search$+"*"
  ELSE
    search$="*."+ext$
  ENDIF
  search$=UCASE$(search$)
  IF path$<>""THEN p$=path$ ELSE p$=CWD$
  ON error skip
  CHDIR p$
  IF MM.Errno THEN p$="A:/":DRIVE "a:"
  'Main Loop
  DO
    'Load dir array
    IF endstate=1 THEN
      fcount=0
      cmode=0
      cursor=1
      ftop=1
      IF LEN(p$)>3 THEN
        fcount=1
        fname$(1)="1.."
      ENDIF
      FOR i=1 TO 2
        ON error skip 9
        IF I=1 THEN
          file$=DIR$("*",DIR)
        ELSE
          file$=DIR$(search$,file)
        ENDIF
        DO WHILE file$<>"" AND fcount<256
          inc fcount,1
          fname$(fcount)=STR$(i)+file$
          file$=DIR$()
        LOOP
        IF MM.Errno THEN EXIT FUNCTION
      NEXT i
      IF LEN(p$)>winw-10 THEN
        PRINT @(x2,y3)LEFT$(p$,2)+"..."+RIGHT$(p$,winw-15)
      ELSE
        PRINT @(x2,y3)LEFT$(p$+SPACE$(winw-10),winw-10)
      ENDIF
    ENDIF
    '---------- Display directory contents ----------
    DO
      SELECT CASE endstate
        CASE 1,2
          top=ftop
          bottom=ftop+lines-1
        CASE 3
          top=ftop+cursor-1
          bottom=ftop+lines-1
        CASE 4
          top=ftop+cursor-2
          bottom=top+1
      END SELECT
      FOR i = top TO bottom
        IF i<=fcount THEN
          n=LEN(fname$(i))-1
          a$=RIGHT$(fname$(i),n)
          file$=LEFT$(a$+SPACE$(winw-4),winw-4)
          IF LEFT$(fname$(i),1)="1" THEN
            file$=file$+"DIR "
          ELSE
            file$=file$+"FILE"
          ENDIF
          IF i=ftop-1+cursor THEN
            cmode=2
          ELSE
            cmode=0
          ENDIF
        ELSE
          file$=SPACE$(winw)
          cmode=0
        ENDIF
      PRINT @(x2,y4+(i-ftop)*fonth,cmode)file$
      NEXT i
      '---------- Input/Selection loop ----------
      DO :a$=INKEY$:LOOP UNTIL a$<>""
        i=ASC(a$)
        endstate=0
        IF i=128 THEN
          IF cursor>1 AND cursor<=lines THEN
            inc cursor,-1
            endstate=2
          ELSEIF cursor=1 AND ftop>1 THEN
            endstate=3
            inc ftop,-1
          ENDIF
        ELSEIF i=129 AND (cursor+ftop-1)<fcount THEN
          IF cursor>=lines THEN
            inc ftop,1
            endstate=2
          ELSEIF cursor<lines THEN
            inc cursor,1
            endstate=4
          ENDIF
        elseIF i=136 THEN
          ftop=ftop-lines
          if ftop<1 then
            cursor=1
            ftop=1
            endstate=3
          else
            endstate=2
          endif
        ELSEIF i=137 THEN
          ftop=ftop+lines
          IF (cursor+ftop-1)>fcount THEN
            DO
              inc cursor,-1
            LOOP UNTIL ((cursor+ftop-1)<=fcount or (cursor<1))
            IF cursor<1 then
              ftop=ftop-lines
            endif
          ENDIF
          endstate=2
        ELSEIF i=13 THEN
          o$=RIGHT$(a$,LEN(a$)-1)
          IF LEFT$(a$,1)="1" THEN
            endstate=1
            IF o$=".." THEN
              ON error skip 2
              CHDIR ".."
              p$=CWD$
            ELSE
              IF RIGHT$(p$,1)<>"/"THEN
                p$=p$+"/"+o$
              ELSE
                p$=p$+o$
              ENDIF
              ON error skip 1
              CHDIR p$
            ENDIF
          ELSE
            endstate=5
          ENDIF
        ELSEIF UCASE$(a$)="D" THEN
          endstate=1
          IF LEFT$(p$,1)="A"THEN
            a$="B:"
          ELSE
            a$="A:"
          ENDIF
          ON error skip 2
          DRIVE a$
          p$=CWD$
          IF MM.Errno THEN DRIVE "A:":p$=CWD$
        ELSEIF ASC(a$)=27 THEN
          endstate=6
          o$=""
        ENDIF
      LOOP UNTIL endstate > 0
  LOOP UNTIL endstate>4
  dirwin$=p$+"$"+o$
END FUNCTION
Thanks! The text input worked, but I didn’t tested it after I added the EXPLICIT option. Fixed it in the post and I’ll fire it up to confirm it.
  • I plan on adding a sort, and it’s really easy in this version of MMBASIC, so it the next thing on my to-do.
  • Yes, given the display size, full screen would be better. I normal set the window sizes either through a global variable or though a parameter in the function call. In this case it was set internally to 30 just to see how it looked, and if it self-adjusted correctly.
  • The drive indicator line is actually full, as it’s set up to display long paths… which reminds me I probably should truncate the line at a leading “/” rather then the middle of a directory line… I intend the bottom to have more options, and different ones depending on the mode (Open, Save, Select Dir. etc), as well as being where file names are entered
  • Scrolling long file names is a good idea, and there’s a couple was to handle it, either auto scrolling or using the right & left cursor. I was planning to add a “[I]nfo” option to display more information like file size and date.
  • I pulled the colors temporarily because the Pico version of MMBASIC handles color a bit differently then the Color Maximite, which can be a embeded into stings, sort of like the C64 could. I havent seen any similar, so it means a lot of separate color commands.
Thank for the addition! It was another thing I planned on adding.
Good catch the INC, didn’t realized it was an option. I’ve got to print out the user docs because I’m and old-school hardcopy manual guy, and I always miss stuff scrolling through it on my phone.
Ah, it makes sense that you were planning to use the bottom for more options. Sorry I moved the drive selector hint up to the top! Hopefully some of the other code I put in there is useful though. :slight_smile:
Speaking of manuals, I just looked in the PicoMite manual and realized how easy sorting actually is, like you said… It’s just a parameter to the FILES command! (I’m still finding my way through MMBasic.) EDIT: Actually, I guess that won’t work since it if just the command to print the results. I was confusing it with DIR$, which doesn’t appear to have sorting built in. I guess this requires sorting the array. So I guess it’s SORT, then!
Took me a bit to figure out SORT as the doc’s kind of makes it look there’s simple default, no parameters, mode, but there isn’t.
I integrated the changes you suggested slightly differently, and added HOME and END… as well as trying to clean out the vestigial junk that was in the old version… which I’ll dropped into the original post.
Drats! Lol, muffed the math on the END move… can’t seem to edit the first post anymore…stated adding color options so. ill put that up later.
Suggestions, comments, and general roasting:
Ok, Color is stated, more of a pain in Pico MMBASIC, but it’s coming along. Current I’m setting is as a an overall theme, so like with other MMBASIC I’ve made in the past, it’s possible to customize and save personal preferences. There in constants them moment, but once I get the colors where i like them, ill change them to universal constants.
I figured a fairly simple way to display long filename which uses the left & right cursor keys to move through the name. I know how i would step it up to auto scroll the long filenames when highlighted, but as fast as MMBASIC is, is still BASIC, so it may add a good amount of lag to scrolling through the directory listings.
The next module I’m going to start working on is a variation of a drop-down/popup option menu subroutine i created. Previously, it was more hardcoded, so you had to create a function/sub for each one, but i think I see a way just to pass the option strings and option redirects as parameters, so you’d only need one, which saves a ton of space… which I actually ran out of in my Maximite programs.
Along with that addition, I’m trying to figure out the best way to implement non destructive popups ad drop downs. On the Maximite I came up with a way of writing out the screen memory of the area the dialog covered to disk, and then reading it back when it closed. I think I can do the same with SAVE IMAGE & LOAD IMAGE.
Hi!
I’m new to the group and just happen to stumble into this conversation. If you don’t mind I further refined the utility code. This updated code significantly enhances the file browser by replacing “magic numbers” with descriptive constants for improved readability and maintainability. Key navigation has been upgraded with explicit sorting, dedicated Home and End key support, and refined Page Up/Down logic for more predictable scrolling. The TextInput$ function is now much more user-friendly, featuring **arrow key navigation, character insertion, and **case-sensitive input. Additionally, the ‘dirwin$’ function introduces an interactive “F” key filter, displays the file/directory count, ensures clearer redrawing of the file list, and implements more robust error handling with centralized error messages for path and drive operations. Finally, the user interface now includes better labels in the command bar, making all new features easily discoverable.
'Utility library - Enhanced
CLEAR
OPTION base 1
OPTION EXPLICIT
’ — Global Constants —
CONST COLOR_BACKGROUND_LIST = 145 ’ A typical light blue/gray
CONST COLOR_BOX_BORDER = 666 ’ A darker border color
CONST DIR_LIST_WIDTH = 39 ’ Width of the directory listing area in characters
CONST KEY_UP = 128
CONST KEY_DOWN = 129
CONST KEY_PAGE_UP = 136
CONST KEY_PAGE_DOWN = 137
CONST KEY_HOME = 134
CONST KEY_END = 135
CONST KEY_ENTER = 13
CONST KEY_ESCAPE = 27
CONST KEY_BACKSPACE = 8 ’ Assuming this is 8 for backspace
CONST DIR_ENTRY_PREFIX = “1” ’ Prefix for directory entries in fname$()
CONST FILE_ENTRY_PREFIX = “2” ’ Prefix for file entries in fname$()
CONST SORT_MODE_DIRS_FIRST = 2 ’ Sort directories before files
CONST SORT_MODE_ALL_ALPHA = 3 ’ Sort all alphabetically
’ — Global Variables —
DIM fontw AS INTEGER= MM.FONTWIDTH
DIM fonth AS INTEGER= MM.FONTHEIGHT
’ — Main Program Entry Point —
CALL MainProgram
SUB MainProgram
LOCAL selectedItemPath$
CLS
PRINT “Welcome to the Enhanced File Browser!”
PRINT “”
PRINT “Press any key to open the file browser…”
DO : LOOP WHILE INKEY$ = “” ’ Wait for a key press
' Example usage of the enhanced dirwin$
' It returns the full path and selected item name, separated by '$'
selectedItemPath$ = DirWindow$(0, 0, 24, "B:/", "") ' Start in B:\, showing 24 lines
IF LEFT$(selectedItemPath$, 3) = "999" THEN ' Check for cancellation string
    PRINT @(0, fonth * 26) "Operation cancelled."
ELSE
    LOCAL currentPath$, selectedItemName$
    currentPath$ = LEFT$(selectedItemPath$, INSTR(1, selectedItemPath$, "$") - 1)
    selectedItemName$ = RIGHT$(selectedItemPath$, LEN(selectedItemPath$) - INSTR(1, selectedItemPath$, "$"))
    PRINT @(0, fonth * 26) "Selected Path: " + currentPath$
    PRINT @(0, fonth * 27) "Selected Item: " + selectedItemName$
END IF
PRINT ""
PRINT "Press any key to exit."
DO : LOOP WHILE INKEY$ = ""
END
END SUB
SUB test ’ Original test kept for reference (now calls DirWindow$)
LOCAL result$
CLS
result$ = DirWindow$(0, 0, 24, “B:/”, “”)
PRINT @(0, 0) result$;
END SUB
’ FUNCTION DirWindow$ (x, y, lines, initialPath$, fileExtensionFilter$)
’ Displays a file/directory browser window.
’ Parameters:
’ x, y: Top-left coordinates of the window.
’ lines: Number of lines to display in the file list area.
’ initialPath$: Starting directory path.
’ fileExtensionFilter$: Optional file extension filter (e.g., “TXT”, “JPG”).
’ Returns:
’ A string containing “Path$SelectedItemName$” or “999” if cancelled.
FUNCTION DirWindow$(x, y, lines, initialPath$, fileExtensionFilter$)
CONST MAX_FILES_DISPLAY = 256 ’ Max number of files/dirs to display
CONST PATH_DISPLAY_TRUNCATE_LENGTH = DIR_LIST_WIDTH - 15 ’ Space for path + “[D] Drive”
LOCAL fileNames$(MAX_FILES_DISPLAY)
LOCAL inputChar$, i, n, currentFile$, searchPattern$
LOCAL currentPath$, fileCount, topVisibleLine, bottomVisibleLine
LOCAL firstLineToDisplay, x2, y2, y3, y4, y5
LOCAL boxWidth, boxHeight, selectedItemName$, cancelledSignal$
LOCAL cursorIndex, displayMode, exitState
LOCAL sortOrder AS INTEGER ' Renamed dflags to sortOrder
LOCAL filterText$ ' For the interactive filter
DirWindow$ = "999" ' Default return value for cancellation
exitState = 1       ' Initial state: load directory
sortOrder = SORT_MODE_DIRS_FIRST ' Default sort order (directories first)
filterText$ = fileExtensionFilter$ ' Initialize filter with passed value
' --- Calculate UI dimensions ---
boxWidth = fontw * DIR_LIST_WIDTH + 6
boxHeight = fonth * lines + 3
x2 = x + 3
y2 = y + fonth + 3
y3 = y + 2
y4 = y2 + 3
y5 = y2 + boxHeight + 2
' --- Draw UI Boxes ---
BOX x, y, boxWidth, fonth + 3, 1, COLOR_BOX_BORDER           ' Path display box
BOX x, y + fonth + 4, boxWidth, boxHeight, 1, COLOR_BACKGROUND_LIST ' File list box
BOX x, y5, boxWidth, fonth + 3, 1, COLOR_BACKGROUND_LIST      ' Command bar box
' --- Draw command labels and separators ---
PRINT @(fontw * (DIR_LIST_WIDTH - 9), y3) "[D] Drive"
LINE fontw * (DIR_LIST_WIDTH - 9) - 4, y, fontw * (DIR_LIST_WIDTH - 9) - 4, fonth + 3, 1, COLOR_BOX_BORDER
PRINT @(x + 3, y5 + 2) "[S]ort [F]ilter [H]ome [E]nd [PgUp] [PgDn] [Esc] Exit"
' --- Set search pattern ---
IF filterText$ = "" THEN
    searchPattern$ = "*"
ELSE
    ' Ensure filter is uppercase for comparison
    searchPattern$ = UCASE$(filterText$)
    IF INSTR(1, searchPattern$, "*") = 0 AND INSTR(1, searchPattern$, ".") = 0 THEN
        searchPattern$ = "*." + searchPattern$ ' Assume it's an extension if no wildcard/dot
    END IF
END IF
' --- Set initial path ---
IF initialPath$ <> "" THEN
    currentPath$ = initialPath$
ELSE
    currentPath$ = CWD$ ' Current working directory
END IF
' Try to change to initial path, handle error
ON ERROR GOTO HandlePathError
CHDIR currentPath$
ON ERROR GOTO 0 ' Reset error handling
' Main Loop
DO
    ' --- Load dir array if state requires it ---
    IF exitState = 1 THEN ' Full redraw and directory re-scan
        fileCount = 0
        displayMode = 0
        cursorIndex = 1
        firstLineToDisplay = 1
        ' Clear previous list display before loading new one
        FOR i = 0 TO lines - 1
            PRINT @(x2, y4 + i * fonth, 0) SPACE$(DIR_LIST_WIDTH);
        NEXT i
        ' Add ".." entry if not at root (assuming X:\ is 3 chars)
        IF LEN(currentPath$) > 3 THEN
            fileCount = 1
            fileNames$(1) = DIR_ENTRY_PREFIX + ".."
        END IF
        ' Get directories
        ON ERROR RESUME NEXT ' Temporarily ignore errors during Dir$
        currentFile$ = DIR$("*", DIR)
        DO WHILE currentFile$ <> "" AND fileCount < MAX_FILES_DISPLAY
            INC fileCount, 1
            fileNames$(fileCount) = DIR_ENTRY_PREFIX + currentFile$
            currentFile$ = DIR$()
        LOOP
        ' Get files
        currentFile$ = DIR$(searchPattern$, FILE)
            INC fileCount, 1
            fileNames$(fileCount) = FILE_ENTRY_PREFIX + currentFile$
        LOOP
        ' Sort the file list
        SORT fileNames$(),, sortOrder, 1, fileCount
        ' Display current path and file count
        LOCAL displayPath$
        IF LEN(currentPath$) > PATH_DISPLAY_TRUNCATE_LENGTH THEN
            displayPath$ = LEFT$(currentPath$, 2) + "..." + RIGHT$(currentPath$, PATH_DISPLAY_TRUNCATE_LENGTH - 5)
        ELSE
            displayPath$ = LEFT$(currentPath$ + SPACE$(PATH_DISPLAY_TRUNCATE_LENGTH), PATH_DISPLAY_TRUNCATE_LENGTH)
        END IF
        PRINT @(x2, y3) displayPath$;
        PRINT @(x + boxWidth - fontw * 10, y3) "Files:" + LTRIM$(STR$(fileCount)); ' Display file count
    END IF
    DO
        SELECT CASE exitState
            CASE 1, 2 ' Full redraw or simple cursor move/scroll
                topVisibleLine = firstLineToDisplay
                bottomVisibleLine = firstLineToDisplay + lines - 1
            CASE 3    ' Cursor moved up and list scrolled up (handled by cursor moving to top of screen)
            CASE 4    ' Cursor moved down and list scrolled down (handled by cursor moving to bottom of screen)
        END SELECT
        FOR i = topVisibleLine TO bottomVisibleLine
            LOCAL displayFileName$, itemType$
            IF i <= fileCount THEN
                LOCAL rawFileName$, fileNameLength
                rawFileName$ = RIGHT$(fileNames$(i), LEN(fileNames$(i)) - 1)
                fileNameLength = LEN(rawFileName$)
                displayFileName$ = LEFT$(rawFileName$ + SPACE$(DIR_LIST_WIDTH - 4), DIR_LIST_WIDTH - 4)
                IF LEFT$(fileNames$(i), 1) = DIR_ENTRY_PREFIX THEN
                    itemType$ = "DIR "
                ELSE
                    itemType$ = "FILE"
                END IF
                displayFileName$ = displayFileName$ + itemType$
                IF i = firstLineToDisplay - 1 + cursorIndex THEN
                    displayMode = 2 ' Highlight selected item
                ELSE
                    displayMode = 0 ' Normal text
                END IF
            ELSE
                displayFileName$ = SPACE$(DIR_LIST_WIDTH) ' Blank line
                displayMode = 0
            END IF
            PRINT @(x2, y4 + (i - firstLineToDisplay) * fonth, displayMode) displayFileName$
        NEXT i
        ' --- Wait for user input ---
        DO : inputChar$ = INKEY$: LOOP UNTIL inputChar$ <> ""
        LOCAL asciiValue AS INTEGER = ASC(UCASE$(inputChar$)) ' UCASE for commands
        exitState = 0 ' Reset state, assume no major change
        ' --- Handle user input ---
        SELECT CASE asciiValue
            CASE KEY_UP ' Up Arrow
                IF cursorIndex > 1 THEN
                    INC cursorIndex, -1
                    exitState = 2 ' Cursor moved, partial redraw
                ELSEIF firstLineToDisplay > 1 THEN
                    INC firstLineToDisplay, -1
                    exitState = 2 ' Scrolled up, full list redraw
                END IF
            CASE KEY_DOWN ' Down Arrow
                IF (cursorIndex + firstLineToDisplay - 1) < fileCount THEN
                    IF cursorIndex < lines THEN
                        INC cursorIndex, 1
                    ELSEIF (firstLineToDisplay + lines - 1) < fileCount THEN
                        INC firstLineToDisplay, 1
                        exitState = 2 ' Scrolled down, full list redraw
                    END IF
                END IF
            CASE KEY_PAGE_UP ' Page Up
                    firstLineToDisplay = MAX(1, firstLineToDisplay - lines)
                    cursorIndex = 1 ' Reset cursor to top of page
                    exitState = 2
                END IF
            CASE KEY_PAGE_DOWN ' Page Down
                    firstLineToDisplay = MIN(fileCount - lines + 1, firstLineToDisplay + lines)
                    IF firstLineToDisplay < 1 THEN firstLineToDisplay = 1 ' Ensure it doesn't go negative
                    exitState = 2
                END IF
            CASE KEY_HOME ' Home
                cursorIndex = 1
                exitState = 2
            CASE KEY_END ' End
                firstLineToDisplay = MAX(1, fileCount - lines + 1)
                cursorIndex = fileCount - firstLineToDisplay + 1
                exitState = 2
            CASE KEY_ENTER ' Enter
                selectedItemName$ = RIGHT$(fileNames$(cursorIndex + firstLineToDisplay - 1), LEN(fileNames$(cursorIndex + firstLineToDisplay - 1)) - 1)
                IF LEFT$(fileNames$(cursorIndex + firstLineToDisplay - 1), 1) = DIR_ENTRY_PREFIX THEN ' It's a directory
                    exitState = 1 ' Re-scan directory
                    IF selectedItemName$ = ".." THEN
                        CHDIR ".."
                        currentPath$ = CWD$
                        ON ERROR GOTO 0
                    ELSE
                        IF RIGHT$(currentPath$, 1) <> "/" AND RIGHT$(currentPath$, 1) <> "\" THEN
                            currentPath$ = currentPath$ + "/" + selectedItemName$
                        ELSE
                            currentPath$ = currentPath$ + selectedItemName$
                        END IF
                        CHDIR currentPath$
                        ON ERROR GOTO 0
                    END IF
                ELSE ' It's a file
                    exitState = 5 ' Exit with file selected
                END IF
            CASE ASC("D") ' Change Drive
                exitState = 1
                LOCAL newDrive$
                IF LEFT$(currentPath$, 1) = "A" THEN
                    newDrive$ = "B:"
                ELSE
                    newDrive$ = "A:"
                END IF
                DRIVE newDrive$
                currentPath$ = CWD$
                ON ERROR GOTO 0
            CASE ASC("S") ' Sort Toggle
                exitState = 1
                IF sortOrder = SORT_MODE_DIRS_FIRST THEN
                    sortOrder = SORT_MODE_ALL_ALPHA
                ELSE
                END IF
            CASE ASC("F") ' Filter
                LOCAL newFilterInput$
                newFilterInput$ = TextInput$(x + 3, y5 + 2, "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_*", 10)
                IF newFilterInput$ <> "" THEN
                    filterText$ = newFilterInput$ ' Update the filter
                ELSE
                    filterText$ = "" ' Clear filter if empty input
                END IF
                ' Re-draw command bar to clear input box
                PRINT @(x + 3, y5 + 2) LEFT$("[S]ort [F]ilter [H]ome [E]nd [PgUp] [PgDn] [Esc] Exit" + SPACE$(DIR_LIST_WIDTH), DIR_LIST_WIDTH);
                exitState = 1 ' Re-scan after filter change
            CASE KEY_ESCAPE ' Escape
                exitState = 6
                selectedItemName$ = "" ' Clear selection for cancellation
        END SELECT
    LOOP UNTIL exitState > 0 ' Loop until a significant state change (e.g., directory change, file selection, exit)
LOOP UNTIL exitState > 4 ' Loop until selected file (5) or cancelled (6)
DirWindow$ = currentPath$ + "$" + selectedItemName$ ' Return path and selected item
EXIT FUNCTION ' Exit function normally
HandlePathError:
PRINT @(x2, y3) “Error: Access Denied or Invalid Path!” + SPACE$(LEN(currentPath$)) ’ Overwrite path with error msg
currentPath$ = “A:/” ’ Attempt to fallback to A:
DRIVE “A:”
currentPath$ = CWD$
RESUME NEXT ’ Continue execution after error
END FUNCTION
’ FUNCTION TextInput$ (x, y, allowedKeys$, maxLength)
’ Displays a single-line text input field.
’ Parameters:
’ x, y: Top-left coordinates of the input field.
’ allowedKeys$: String of characters allowed for input.
’ maxLength: Maximum length of the input string.
’ Returns:
’ The string entered by the user.
FUNCTION TextInput$(x, y, allowedKeys$, maxLength)
LOCAL blinkTimer, currentText$, cursorCol, inputChar$, charAtCursor$, displayMode
blinkTimer = 0
currentText$ = ""
cursorCol = 0 ' Represents the column position of the cursor (0-based)
' Clear the display area for the input field
PRINT @(x, y) SPACE$(maxLength);
DO
    DO
        inputChar$ = INKEY$
        blinkTimer = (blinkTimer + 1) MOD 1000
        IF blinkTimer < 500 THEN displayMode = 2 ELSE displayMode = 0 ' Blinking cursor mode
        ' Display blinking cursor at current position
        IF cursorCol < LEN(currentText$) THEN
            charAtCursor$ = MID$(currentText$, cursorCol + 1, 1)
        ELSE
            charAtCursor$ = " " ' Blank space if cursor at end
        END IF
        PRINT @(x + (cursorCol * fontw), y, displayMode) charAtCursor$;
    LOOP WHILE inputChar$ = "" ' Wait for a key press
    ' Reset character at cursor to normal display before processing new input
        PRINT @(x + (cursorCol * fontw), y, 0) MID$(currentText$, cursorCol + 1, 1);
    ELSE
        PRINT @(x + (cursorCol * fontw), y, 0) " ";
    END IF
    LOCAL asciiVal AS INTEGER = ASC(inputChar$) ' Do not UCASE here, allow case-sensitive input
        CASE KEY_BACKSPACE
            IF cursorCol > 0 THEN
                currentText$ = LEFT$(currentText$, cursorCol - 1) + RIGHT$(currentText$, LEN(currentText$) - cursorCol)
                cursorCol = cursorCol - 1
                PRINT @(x, y) LEFT$(currentText$ + SPACE$(maxLength), maxLength); ' Redraw the full string
            END IF
        CASE KEY_ENTER
            EXIT DO ' User pressed Enter, finish input
        ' Assuming 130 and 131 are Left and Right arrow keys - VERIFY THESE!
        CASE 130 ' KEY_LEFT (example, verify ASCII for your environment)
            END IF
        CASE 131 ' KEY_RIGHT (example, verify ASCII for your environment)
                cursorCol = cursorCol + 1
            END IF
        CASE ELSE
            IF INSTR(1, allowedKeys$, inputChar$) > 0 AND LEN(currentText$) < maxLength THEN
                ' Insert character at cursor position
                currentText$ = LEFT$(currentText$, cursorCol) + inputChar$ + RIGHT$(currentText$, LEN(currentText$) - cursorCol)
            END IF
    END SELECT
LOOP
TextInput$ = currentText$
END FUNCTION
Thanks for the additions, I’ll try integrating them!
The variable name are truncated for a couple reasons. When I program in compiled languages, I use a verbose naming convention because they’re lables that are only relevant in the source. In interpreted languages, like MMBASIC, where every byte counts, I’ve written programs large enough were I’ve had to remove every remark, space between operators, and shorten variable names just to get the last lines of coded to fit in. The segments I listed came from a Maximite MMBASIC I wrote that used 100% of the code space. It was such a problem that I had to write a sepetate program just to compact the program I was working on.
Another reason for terse names is that I’m programming all this on the PicoCalc itself, and the line length is limited… I’m hesitant to invoke the underscore line continuation because it’s a system level option and I wanted to keep it generically compatable… so long var/function names make it hard to read. Even with the abbreviations I’m not entirely happy with a lot of the lines being cut off, but its a necessary compromise for the time being.
Unless there’s an OPTION setting I don’t see, and I’m new to the PicoCalc as well, there is no GOTO option in this version of MMBASIC. When I started trying to add some errors handling, I was looking to do basicly the same thing you did, but found it wasn’t an feature. The only option is to use ON ERROR SKIP to temporary ignore errors in potentially problematic upcoming code, like file system access, and then check for an error state right afterwards.
Thanks for the clarifications and prompt reply.
This MMBasic code has been meticulously optimized to address the severe memory constraints inherent to the PicoCalc/Maximite environment. The strategy prioritizes minimizing raw byte count, which necessitates deviations from standard readability conventions.
My approach involved:
  • Aggressively stripping all comments and non-essential whitespace.
  • Truncating variable and parameter names to their shortest possible forms.
  • Consolidating multiple statements onto single lines using colons (:), a critical technique given the absence of underscore line continuation.
  • Implementing error handling via ON ERROR SKIP, adhering to the specific behavior outlined for this MMBasic interpreter.
While this highly optimized code is presented based on a deep understanding of embedded BASIC programming, direct testing on the PicoCalc hardware is pending. Based on my extensive experience with various BASIC dialects in constrained embedded systems, however, provides a strong foundation for the effectiveness of these optimizations.
Stripping all comments and unnecessary whitespace.
Truncating variable and parameter names.
Combining multiple statements per line using colons (:), given the absence of underscore line continuation and GOTO for error handling.
Leveraging the ON ERROR SKIP behavior as described for the specific MMBasic implementation.
The goal was to maximize code within tight memory limits, reflecting the unique challenges of embedded programming on this platform.
Clear:Option Base 1:Option Explicit
Dim fw As integer=MM.FONTWIDTH
Dim fh As integer=MM.FONTHEIGHT
test
Sub test2
Local a$,k$:CLS:k$=“abcdefghijklmnopqrstuvwxyz”:k$=k$+“1234567890.-_”:a$=TextInput$(0,20,k$,10):Print @(0,0)a$
End Sub
Sub test
Local a$:CLS:a$=dirwin$(0,50,14,“B:/”,“”):Print @(0,0)a$;
End Sub
Function dirwin$(x,y,ln,p$,e$)
Const ww=39
Local f$(256),a$,k$,i,n,fl$,s$,pl$,fc,t,bt,ft,x2,y2,y3,y4,y5,bw,bh,o$,cu,cm,es,df As integer
dw$=“999”:es=1:df=2:k$=“abcdefghijklmnop01234567890.-”
bw=fwww+6:bh=fhln+3
x2=x+3:y2=y+fh+3:y3=y+2:y4=y2+3:y5=y2+bh+2
Box x,y,bw,fh+3,1,666:Box x,y+fh+4,bw,bh,1,b:Box x,y5,bw,fh+3,1,b
Print @(x2,y5+2)“[D]rive [S]ort”
If e$=““Then s$=s$+”" Else s$=".”+e$
s$=UCase$(s$)
If p$<>““Then pl$=p$ Else pl$=Cwd$
On Error Skip:Chdir pl$
If MM.Errno Then pl$=“A:/”:Drive “a:”
Do 'Main Loop
If es=1 Then 'Load dir array
fc=0:cm=0:cu=1:ft=1
If Len(pl$)>3 Then fc=1:f$(1)=“1..”
For i=1 To 2
On Error Skip
If i=1 Then fl$=Dir$(”*”,DIR) Else fl$=Dir$(s$,file)
Do While fl$<>“” And fc<256
Inc fc,1:f$(fc)=Str$(i)+fl$:fl$=Dir$()
Loop
Next i
Sort f$(),df,1,fc
If Len(pl$)>ww Then Print @(x2,y3)Left$(pl$,2)+“…”+Right$(pl$,ww-5) Else Print @(x2,y3)Left$(pl$+Space$(ww),ww)
EndIf
Do
  Select Case es
    Case 1,2:t=ft:bt=ft+ln-1
    Case 3:t=ft+cu-1:bt=ft+ln-1
    Case 4:t=ft+cu-2:bt=t+1
  End Select
  For i=t To bt
    If i<=fc Then
      n=Len(f$(i))-1:a$=Right$(f$(i),n)
      fl$=Left$(a$+Space$(ww-4),ww-4)
      If Left$(f$(i),1)="1"Then fl$=fl$+"DIR " Else fl$=fl$+"FILE"
      If i=ft-1+cu Then cm=2 Else cm=0
    Else
      fl$=Space$(ww):cm=0
    EndIf
  Print @(x2,y4+(i-ft)*fh,cm)fl$
  Next i
  Do:a$=UCase$(Inkey$):Loop Until a$<>""
    i=Asc(a$)
    es=0
    If i=128 And cu+ft>2 Then If cu>1 And cu<=ln Then cu=cu-1:es=2 ElseIf cu=1 And ft>1 Then es=3:Inc ft,-1
    ElseIf i=129 And (cu+ft-1)<fc Then If cu>=ln Then Inc ft,1:es=2 ElseIf cu<ln Then Inc cu,1:es=4
    ElseIf i=136 Then cu=1:If ft-ln<1 Then ft=1:es=3 Else ft=ft-ln:es=2
    ElseIf i=137 Then es=2:If ft+ln>fc Then cu=fc-ft+1 Else ft=ft+ln:cu=1
    ElseIf i=134 Then es=2:ft=1:cu=1
    ElseIf i=135 Then es=2:ft=fc\ln*ln:cu=fc Mod ln+1
    ElseIf i=13 Then
      a$=f$(cu+ft-1):o$=Right$(a$,Len(a$)-1)
        es=1
        If o$=".." Then On Error Skip:Chdir "..":pl$=Cwd$:If MM.Errno Then Exit Function
        Else If Right$(pl$,1)<>"/"Then pl$=pl$+"/"+o$ Else pl$=pl$+o$
        On Error Skip:Chdir pl$:If MM.Errno Then Exit Function
        End If 'Matches If o$=".." Then
      Else
        es=5
      EndIf
    ElseIf a$="D" Then
      es=1
      If Left$(pl$,1)="A"Then a$="B:" Else a$="A:"
      On Error Skip:Drive a$:pl$=Cwd$
      If MM.Errno Then On Error Skip:Drive "A:":pl$=Cwd$
    ElseIf a$="S" Then es=1:If df=2 Then df=3 Else df=2
    ElseIf Asc(a$)=27 Then es=6:o$=""
    EndIf
Loop Until es > 0
Loop Until es>4
dw$=pl$+“$”+o$
End Function
Function TextInput$(x,y,k$,lg)
Local bl,t1$,cx,a$,c$,px,cm
bl=0:t1$=“”:cx=0
Print @(x,y)Space$(lg);
Do
Do:a$=Inkey$:bl=(bl+1)Mod 1000:c$=a$
If bl<500 Then cm=2 Else cm=0
cx=Len(t1$)
If cx=lg Then c$=Right$(t1$,1) Else c$=" ":Inc cx,1
px=cx-1
Print @(x+(pxfw),y,cm)c$;
Loop While a$=“”
Print @(x+(px
fw),y,0)c$
If Asc(a$)=8 And Len(t1$)>0 Then Print @(x+pxfw,y,0)" ":t1$=Left$(t1$,Len(t1$)-1)
ElseIf Instr(1,k$,a$)>0 And Len(t1$)<lg Then t1$=t1$+a$:Print @(x+px
fw,y,0)a$;
ti$=t1$
End Function
I waited to wait to post the full update to until I had the chance to install and RTC into my PicoCalc this weekend, and as your not hearing me crying that I accidently killed it, it works!
The current version is just an input file selector, and I will be reintegrating the option to select output filenames and paths in the next version.
I looked at everyone suggestions, comments and example and added the following to my code:
  • Scrolling for long line handling.
  • Dialog Colors.
  • Shift cursor UP and DOWN paging.
  • Fast move to the top and bottom of the directory listing.
  • Error handing (basic file system).
  • Directory Sorting.
  • Directory Filtering.
Usage Notes:
The [S]ORT and [F]ILTER are toggles.
  • [S]ORT swaps between ascending and descending order.
  • [F]ILTER you enter you filter text, and the second time removes it.
  • [I]NFO Shows the modification date and file size of the highlighted file/directory, and return to the option list if selected again, or if you move to another file/directory.
[CURSOR LEFT] & [CUSOR RIGHT] will scroll the with text window to show the contents of long lines
[SHIFT][CURSOR UP] moves to the top of the directory
[SHIFT][CURSOR DOWN] moves to the bottom of the directory
[ENTER] if on a file, exits the DirWin function returning the file path and filename, with a “$” delimiter between them
[ENTER] if on a directory, will move the the selected directory.
[ESC] will exit the program with the current path and a $ delineator with nothing behind it.
If there is a filesystem error DirWin will exit and return the sting “999”
'Utility library
Clear
Option base 1
Option EXPLICIT
Const CBorder1    =RGB(blue)
Const CBodyTxt1   =RGB(white)
Const CBodyTxt1B  =RGB(064,064,064)
Const CHead1      =RGB(yellow)
Const Chead1B     =RGB(blue)
Const CFoot1      =RGB(cyan)
Const CFoot1B     =RGB(000,000,128)
Const CInput      =RGB(orange)
Const CinputB     =RGB(000,000,128)
test
Sub test
  Local a$
  CLS
  Print @(0,0)a$;
End Sub
  Const winw=39
  Const wint=winw-5
  Local wspace$ = Space$(winw)
  Local fname$(256)
  Local a$,key$,file$,search$,p$,o$,o1$
  Local opt$="[D]rive [S]ort [F]ilter [I]nfo"
  Local fcount As integer
  Local ftop As integer
  Local top As integer,bottom As integer
  Local x2 As integer,y2 As integer
  Local y3 As integer,ybody As integer
  Local y5 As integer
  Local boxw As integer,boxh As integer
  Local cursor As integer
  Local lcursor As integer=0
  Local cmode a integer
  Local endstate As integer=1
  Local lflag As integer=0
  Local fflag As integer=0
  Local dflags As integer=2
  Local iflag a integer
  Local idate$, isize As integer
  Local n As integer
  Local i As integer, c As integer
  Local yfoot1 As integer
  dirwin$="999"
  key$="ABCDEFGHIJKLMNOPQRSTUVWXYZ"
  key$=LCase$(key$)+key$
  key$=key$+"0123456789!@!#%&*()<>:.'"
  opt$=Left$(opt$+wspace$,winw)
  boxw=fontw*winw+6
  x2=x+3
  y2=y+fonth+3
  y3=y+2
  ybody=y2+3
  y5=y2+boxh+2
  yfoot1=y5+2
  Box x,y,boxw,fonth+3,1,CBorder1
  Box x,y+fonth+4,boxw,boxh,1,CBorder1
  Box x,y5,boxw,fonth+3,1,CBorder1
  Color CFoot1,CFoot1B
  Print @(x2,yfoot1)opt$;
  If ext$="" Then
    search$=search$+"*"
  Else
    search$="*."+ext$
  EndIf
  On error skip
  Chdir p$
  'Main Loop
  Do
    'Load dir array
    If endstate=1 Then
      fcount=0
      cmode=0
      cursor=1
      ftop=1
      If Len(p$)>3 Then
        fcount=1
        fname$(1)="1.."
      EndIf
      For i=1 To 2
        On error skip 9
        If i=1 Then
          file$=Dir$("*",DIR)
        Else
        EndIf
          Inc fcount,1
          file$=Dir$()
        Loop
      Next i
      Color CHead1,Chead1B
      Else
      EndIf
    EndIf
    'Display loop
    wspace$=Space$(winw)
      Case 1,2
        top=ftop
        bottom=ftop+lines-1
      Case 3
        top=ftop+cursor-1
        bottom=ftop+lines-1
      Case 4
        top=ftop+cursor-2
        bottom=top+1
      Case 5
        top=ftop
        bottom=ftop+lines-1
        wspace$=Space$(lflag)
    End Select
    For i= top To bottom
      If i<=fcount Then
        n=Len(fname$(i))-1
        file$=Mid$(a$+WSpace$,1+lcursor,wint)
          file$=file$+" DIR "
        Else
          file$=file$+" FILE"
        EndIf
          cmode=2
          lflag=(n>(wint))*n
        Else
          cmode=0
        EndIf
      Else
        file$=WSpace$
        cmode=0
      EndIf
      Color CBodyTxt1,CBodyTxt1B
      Print @(x2,ybody+(i-ftop)*fonth,cmode)file$
    Next i
    'Selection loop
    Do
      Do
        a$=UCase$(Inkey$)
      Loop Until a$<>""
      i=Asc(a$)
          Inc cursor,-1
          endstate=2
          endstate=3
          Inc ftop,-1
        EndIf
      ElseIf i=129 And ftop+cursor-1<fcount Then
          Inc ftop,1
          endstate=2
        ElseIf cursor-1<lines Then
          Inc cursor,1
          endstate=4
          If lflag>0 Then endstate=2
        EndIf
      ElseIf i=130 And lflag>0 Then
        If lcursor>0 Then
          Inc lcursor,-1
          endstate=5
        EndIf
      ElseIf i=131 And lflag>0 Then
        If lflag-lcursor>wint Then
          Inc lcursor,1
          endstate=5
         EndIf
      ElseIf i=134 Then
        endstate=2
        ftop=1
        cursor=1
      ElseIf i=135 Then
        endstate=2
        ftop=fcount\lines*lines+1
      Else If i=136 Then
        cursor=1
          ftop=1
          endstate=3
        Else
          ftop=ftop-lines
          endstate=2
        EndIf
      ElseIf i=137 Then
        endstate=2
        Else
          ftop=ftop+lines
          cursor=1
        EndIf
      ElseIf i=13 Then
          endstate=1
          If o$=".." Then
             On error skip 2
             Chdir ".."
            p$=Cwd$
          Else
              p$=p$+"/"+o$
            Else
              p$=p$+o$
            EndIf
            On error skip 1
            Chdir p$
          EndIf
        Else
          endstate=999
        EndIf
      ElseIf i=68 Then 'D
        endstate=1
          a$="B:"
        Else
          a$="A:"
        EndIf
        On error skip 2
        Drive a$
        p$=Cwd$
       ElseIf i=70 Then 'F filter
        endstate=1
        If fflag Then
          fflag=0
          search$="*"
        Else
          fflag=1
          a$=Left$("Filter:"+wspace$,winw)
          i=x2+2+fontw*7
          Color CInput,CinputB
          Print @(x2,yfoot1)a$;
          a$=tinput$(i,yfoot1,key$,winw-11)
          If a$="" Then
            fflag=0
            endstate=0
          Else
            search$=a$+"*"
          EndIf
        EndIf
      ElseIf i=73 And iflag=0 Then'I nfo
        endstate=6
        iflag=1
        endstate=0
        a$=fname$(ftop+cursor-1)
        a$=Right$(a$,Len(a$)-1)
        idate$=MM.Info(modified a$)
        isize=MM.Info(filesize a$)
        a$=idate$+ " : "+Str$(isize)
        a$=Left$(a$+wspace$,winw)
      ElseIf i=83 Then 'S Sort
       endstate=1
        If dflags=2 Then
          dflags=3
        Else
          dflags=2
        EndIf
      ElseIf i=27 Then
        endstate=998
        o$=""
      Else
        endstate=0
      EndIf
      'Clean up
      Select Case iflag
        Case 1
          Inc iflag
        Case 2
          iflag=0
      End Select
      If endstate<>5Then lcursor=0
    Loop Until endstate>0
  Loop Until endstate>900
  dirwin$=p$+"$"+o$
End Function
' fixed length text input
Function TInput$(x,y,key$,length)
  blink = 0
  Text1$=""
  cx=0
   Do
    Do
      a$=Inkey$
      c$=a$
      cx=Len(text1$)
      If cx=length Then
        c$=Right$(text1$,1)
      Else
        c$=" "
        Inc cx,1
      EndIf
      px=cx-1
    Loop While a$=""
      Text1$=text1$+a$
    EndIf
  tinput$ = text1$
End Function
Design Notes:
I did a somethings differently then some of the examples people offered, large as I’d already coded it, as well as trying to do it myself to get a better feel for the problem.
One note on my “Style” (lol) in BASIC is that, with the exceptions of “x” and “y”, I typically use, then reuse, single letter variables as temporary work variables. As the scope of their usage is withing a handful of lines, and they have no value beyond them, it’s something I do to cut down a bit the number in memory.
I changed some variables names for a bit of clarity in spots, and I added a number to get rid of repetitious operations. They are neither consistently as terse of verbose as I’d like, but it’s a compromise for the moment… I’m beginning to see a naming convention evolve that I like, so I’ll do a big cleanup in the future.
I also expanded the endstate flag because it was silly to have to change the exit condition coding everything I got a new idea.
When I use these function in actual programs, The Constants at the beginning will be largely be changed to DIM declarations so so that I can save and load user preferences.
To do’s:
  • I’d like to add a Filter and Sort indicator at some point.
  • possible a second header line for drive information and status flags
  • This is a rewrite of some much older code, so it’s sort of a 1.2 version, and I’m looking at ways to clean, optimize, and speed it up.
  • Polish the interface.
  • Expand DirWin to handle Directory name selection, and saving name and paths selection.
While I’ll continue tweaking and updating it, I’m going to take a bit of a break and start working on the dropdown and dialog functions.
This is looking and working really well! Congrats. :slight_smile:
Couple of minor suggestions:
  • filter currently only searches substrings at the front of a file, with a slight tweak it can search for any substring, allowing for a filter input of “bmp” to show all bitmap files, for instance. So this line search$=a$+"*" could be changed to this: search$="*"+a$+"*" to allow for that.
  • There’s an extra background pixel on the right now, compared to the left
    • so changing boxw=fontw*winw+6 to boxw=fontw*winw+5 will fix that
    • also, changing a$= dirwin$(0,50,14,"B:/","") to a$= dirwin$(1,50,14,"B:/","") in the test function will center the display horizontally a bit more, though really 1 or 2 is equivalent since there will be either an extra background pixel on the right or left of the display, but it’s not noticable. :slight_smile:
  • re: “Filter and Sort indicator” – one way to do it and save space on the display is to just highlight the [S]ort or [F]ilter info text in a different color when it’s active. If used, it might make sense to group them separately from the [D]rive and [I]nfo info text since those can’t be “toggled” like that and would never change color. So maybe put two on the left and two on the right of the line with a gap in the middle or something.
By the way, I realize your goal for this code is to use it as file selector, but with all the work you’ve done it’s quickly becoming a nice base for a file explorer application. I haven’t messed much with it yet, but I was wondering if you’d be ok with someone building such an app starting from your code? Attribution and links to your code, and source for any new code based on it would be provided, of course. And it would give me an excuse to make a repo for my PicoCalc programs. I’m not even sure if I’ll be able to get to it soon anyway, but a file explorer application is a core application that has been missing from the PicoCalc, and I think would be a useful thing. There is a file explorer application on TheBackShed for PicoMite, but it makes a lot of assumptions about larger screen size (VGA/HDMI) and also uses drawing routines that aren’t available on the PicoCalc so the effort to adapt it would be greater than just building one from scratch. And since you’ve already put together a very nice codebase, I think it would be quicker and easier to start from yours.
The things that would need to be added would be:
  • dialog size could be expanded to use the full display (I’ve already done this in my version of your previously posted code)
  • basic features for a file explorer could be added, like…
    • delete file or folder (with option to delete recursively), with confirmation
    • new folder (or file? I guess this would be just be like “touch” to create a zero byte file)
    • rename file or folder
    • copy, cut (move), paste file or folder (with option to copy/cut recursively)
    • mark (select/deselect) files and folders, to be used with the other operations
    • invert/clear selection
    • “view” a file, depending on file type, to potentially view images, view text (and basic?) files, etc. Ideally, this would be done inside the file explorer and not need to run another application.
    • “edit” a file, depending on file type, which would likely call another application that could be assigned via config/settings. Built in system EDIT command could be used for basic files, but another application (if it exists) could be used for editing text files, or editing BMP files, etc. (Would be nice to return to the file explorer when editor exits, if possible.)
    • “execute” a file, depending on file type, which would probably only be used for launching other basic applications. (Would be nice to return to the file explorer when program exits, if possible.)
    • maybe add (or toggle) an additional column for date/time, though considering the display resolution limits, I kind of prefer your current solution of showing file/dir and using the info toggle to show details; might be worth experimenting with it as a toggle between current view and date/time instead of the file/dir column
  • rather than a function that returns a path, it would just be an application itself
  • probably other things I’ve forgotten
That’s a long list, but some of those things are pretty simple to do, while others would require some creativity and a bit of playing around to get them right. Nothing seems insurmoutable though, and I kind of think it would be a fun project. A long time ago, I considered adapting one of the earlier “menu” programs that was posted, but your file selector has come so far that it’s much closer to a file explorer already, and it’s hard to resist the temptation to start working on this! :wink:
Yes but no corresponding DEC, the author of PicoMite wasnt interested in adding it at all.
Nice work!
Here’s the link to my adaptation of your code — it now supports creating folders and deleting folders and files:
https://github.com/onimahoni/Picocalc-Commander
Neither I nor ChatGPT are great at programming — but we try our best! :grinning_face_with_smiling_eyes:
Thanks!
I debated how to handle the default search, and I settled with the asterisk suffix because it allowed for 2 of the three simple searchs, begin and contains (just add an * to the beginning of your search text), and not ends. The “Best” option is not to putting any wildcards in and let the user pick them. This version of MMBASIC allow both “*” and “?” in the directory searching which is really nice. What’s an option is to set up global variables, DirPre$ and DirSuf$ for example, and have them ultimately be a user selectable option… Thank! This also got me thinking that I should add an [F1] help subroutine to popup help screens anywhere there’s choices.
Yes, I noticed the extra space in the right margin between the text area and border after I added color, so I’ll fix that.
The indicators are another debate. Pico MMBASIC basic doesn’t allow embeded color attributes in strings, so you either need a separate function for every line variation, or you create a custom PRINT function that parses embeded color, which is going to be slow. I got excited for a moment when I discovered OPTION ESCAPE and the slash commands, but unfortunate I tried playing around with them and they don’t appear to support any of VT color commands. That leaves putting them in fixed positions. A second status line is looking like its going to be the best option, and I may move the option bar to the top so it look more like an application window then a dialog box.
DEC would be nice, but unnecessary as INC allows to set the step value, and it can be negative, such as INC x,-1
I put this stuff out there for the feedback and to share with everyone, so you’re very welcome to use any part of it however you like!
For me, its about creating a library of functions and subroutines so I’m not reinventing the wheel every time I start a new project, so I can focus on the new challenges… which itself creates more routines for the library.
The next really big thingd for me is recreating the font and editing routines I created on the Maximite… the big pain being Pico MMBASIC doesn’t currently have a LOAD option for fonts, so I’m going to have to see if I can find a workaround… and then completing the game engine I for an RPG started.
