Can I use a USB RTL-SDR dongle with uConsole? (while awaiting HackerGadgets board delivery)
Hi,
As per the title. I’m itching to get going with SDR and am currently awaiting delivery of the HackerGadgets expansion board for this purpose.
In the meantime, is a cheap SDR dongle with USB likely to work with uConsole?
Cheers muchly.
yes, there are even a few guides of people who modified their existing extension boards to have an internal rtl sdr inside the case.
Brilliant, thanks snipeytje. I keep looking at them and for the price, thought it might be worth trying one.
I plugged my RTL-SDR dongle into a USB port, but nothing happens. It isn’t being recognized by SDRpp or CubicSDR. I checked dmesg, but I’m not entirely sure what to look for, and I didn’t notice any obvious errors. Any ideas on how to troubleshoot this?
Run
$ lsusb
and google <usb stick name> linux
Unmodified RTL-SDR dongles typically consume between 200-500mA of current at 5V, with most averaging around 300mA under typical conditions.
should be good by power limits on usb
Good info, Thanks for the quick reply.
Here’s the output from dmesg -w when I plugged the RTL-SDR dongle into the USB port.
[ 464.290984] usb 1-1.1: USB disconnect, device number 21
[ 464.802971] usb 1-1.1: new full-speed USB device number 22 using dwc2
[ 464.891962] usb 1-1.1: New USB device found, idVendor=1eaf, idProduct=0003, bcdDevice= 2.01
[ 464.891972] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 464.891975] usb 1-1.1: Product: Maple 003
[ 464.891978] usb 1-1.1: Manufacturer: LeafLabs
[ 464.891981] usb 1-1.1: SerialNumber: LLM 003
[ 465.090974] usb 1-1.2: new full-speed USB device number 23 using dwc2
[ 465.162980] usb 1-1.2: device descriptor read/64, error -32
[ 465.338980] usb 1-1.2: device descriptor read/64, error -32
[ 465.514975] usb 1-1.2: new full-speed USB device number 24 using dwc2
[ 465.586982] usb 1-1.2: device descriptor read/64, error -32
[ 465.762980] usb 1-1.2: device descriptor read/64, error -32
[ 465.867195] usb 1-1-port2: attempt power cycle
[ 466.450982] usb 1-1.2: new full-speed USB device number 25 using dwc2
[ 466.858986] usb 1-1.2: device not accepting address 25, error -32
[ 466.930985] usb 1-1.2: new full-speed USB device number 26 using dwc2
[ 467.338988] usb 1-1.2: device not accepting address 26, error -32
[ 467.339319] usb 1-1-port2: unable to enumerate USB device
[ 467.340347] usb 1-1.1: USB disconnect, device number 22
[ 467.538984] usb 1-1.1: new full-speed USB device number 27 using dwc2
[ 467.628592] usb 1-1.1: New USB device found, idVendor=1eaf, idProduct=0024, bcdDevice= 2.00
[ 467.628600] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 467.628603] usb 1-1.1: Product: uConsole
[ 467.628606] usb 1-1.1: Manufacturer: ClockworkPI
[ 467.628608] usb 1-1.1: SerialNumber: XXXXXXXX
[ 467.630275] input: ClockworkPI uConsole Consumer Control as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0005/input/input22
[ 467.683136] input: ClockworkPI uConsole Keyboard as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0005/input/input23
[ 467.751115] input: ClockworkPI uConsole as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0005/input/input24
[ 467.751232] input: ClockworkPI uConsole Mouse as /devices/platform/axi/1000480000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1EAF:0024.0005/input/input25
[ 467.751363] hid-generic 0003:1EAF:0024.0005: input,hidraw0: USB HID v1.10 Keyboard [ClockworkPI uConsole] on usb-1000480000.usb-1.1/input0
[ 467.751738] cdc_acm 1-1.1:1.1: ttyACM0: USB ACM device
try this?
$ sudo bash -c "echo -1 >/sys/module/usbcore/parameters/autosuspend"
thanks, no joy on
sudo bash -c “echo -1 >/sys/module/usbcore/parameters/autosuspend”
