konomi
September 8, 2025, 2:32am
1
FLAGRANT SYSTEM ERROR! EXCEPTION 3
r0=400140C8 r1=20041FE0 r2=00000000 r3=20041F98
r4=0000000A r5=20001395 r6=2001025E r7=20003691
r8=18000000 r9=2000212B r10=00000001 r11=20003691
r12=20003691 sp=20001327 lr=200014CF pc=2001027C
PROGBASE=20016C04 PROGLOAD=20017204 PROGTOP=20026C04
UDATA=20016C04 KSTACK=20016D14-20017204
user mode relative: lr=FFFEA301 pc=FFFF90D4 isp=00000000 brk=00000000
panic: fatal exception
No matter what I try I always get this error. I’ve redone the SD card and followed the directions exactly.
guu
September 8, 2025, 9:19am
2
How you redone the SD card ?
here is the wiki about how to create factory sd card
konomi
September 8, 2025, 2:56pm
3
Yeah I’ve redone it a bunch of times and followed the directions carefully it’s very confusing… I got it to work once and everything seemed fine and I haven’t been able to since. I’ve got a lot of experience with Linux so redoing the SD card isn’t something I think I’d make mistakes on. I wish there was a way to validate the contents of the partition but I couldn’t find anything to do so for the file system FUZIX uses.
guu
September 8, 2025, 3:40pm
4
OK, This is new
So let’s confirm that, you did the sd card like the wiki says,and you ran the FUZIX like PicoCalc/Bin/PicoCalc SD/firmware/PicoCalc_Fuzix_v1.0.uf2 at master · clockworkpi/PicoCalc · GitHub
and it just shows the
konomi
September 8, 2025, 6:46pm
5
So because I’m testing the Pimoroni Pico Plus 2 W for uf2loader I decided to try flashing it instead. I flashed:
1745c60e17fe60444e7e7f8ac3091729 PicoCalc_Fuzix_v1.1_pico2.uf2
And FUZIX booted fine, so it’s not the SD card. When I get a chance I’ll test the Pico1 board that came with my PicoCalc with the following file:
2fcb133f5c7f8b8bd85b3f6037ce239d PicoCalc_Fuzix_v1.0.uf2
Unless there’s a 1.1 for the Pico1 somewhere?
guu
September 9, 2025, 6:32am
6
No there is 1.1 Fuzix for Pico1
but you can always compile your own version of FUZIX based on the patches from PicoCalc
