Change order to non core
I ordered a UConsole with a CM4 (order #23XXX)
If I were to get a CM4 from somewhere else, would I be able to change my order to a non-core version?
Doing the same since I already use CM4’s for other stuff.
I got mine from Digikey and I went for the 8GB version.
Be sure to get the lite version with no ECC and include wifi
You can also order from Newark.
https://www.newark.com/raspberry-pi/cm4108000/rpi-compute-module-4-lite-8gb/dp/40AJ6750
Stupid new user here, why no EEC?
The wires that would go to the micro SD card instead go to the eMMC module on those models, which means there is no way to boot or load of an SD card, so you’re kind of stuck with using the USB port if you ever need to expand storage
