You can change the brightness of your DevTerm in the terminal. To do so, just echo a new value into the brightness file which lives @ /sys/class/backlight/backlight@0. In this folder, you’ll find some useful files, such as: actual_brightness, brightness & max_brightness.
This was tested and accomplished on the DevTerm running raspbian.
How
To change brightness, you can change brightness to anything between 0 and 9. 0 being backlight off, and 9 being brightest. The device defaults to 5.
To change brightness, type in (changing N for brightness 0 thru 9):
echo N > /sys/class/backlight/backlight@0/brightness
incredible, thank you; it’s a shame the keycaps don’t include notations for this.
Does this publish to a global variable? one of my wishlist mods for my devterm is to backlight the keyboard, syncing to the screen brightness would be ideal
could you please upload the source of package 'devterm-backlight-rpi ’ on github?
I prefer to use console mode (multiuser.target), but the function does not work in the mode.
Thanks
I figured I’d ask this here, instead of starting a new thread; can anyone point me in the right direction for the screen timeout/turn off value? I didn’t think there was one until i walked away from mine and came back, thought it had powered off but a flick of the trackball brought it back to life. Is this the “sleep” mode referenced in the manual (eg don’t pull the batteries in sleep mode)? I initially thought the power button was sending it to a light sleep, until i noticed that the same command line scrolled past as when i used sudo shutdown
i cant seem to find the newer thread that this was referenced… but this has never worked on cm4, i installed xbindkeys-config to find that the default binding file is empty… and also… the gamepad buttons are not recognized by xbindkeys to use for brightness… and on the standard keyboard firmware fn activates the shift labels on the regular direction pads… am i behind and this has a fix somewhere? but i can say that the rpi-backlight.c works great when it is bound to shift + directions on my cm4
