FYI, i just looked into this yesterday… install xbindkeys-config… will let you open the xbindkeys that the image (i am using .3) has… you will find… nothing… its empty… thats why it doesn’t work on cm4… the rpi-backlight app is there… written in C… and it works well… but they didn’t include the xbindkeys default file… go ahead and add some keybindings… shift + up… command “rpi-backlight up” and shift + down “rpi-backlight down” since the fn buttons actually trigger pg up and pg dn…
you will need an external monitor or something to see the “add” button at the bottom since the window can’t be scaled… when you added what you want… click “save apply and exit” you can test them before you exit…
EDIT: forgot to mention… if it still doesnt work… run this
