Hi @rex - first of all, thank you for your fantastic work on the Bookworm 6.12 release.
I’m running into persistent boot and stability issues only with CM5. With the original CM4 that shipped with the uConsole, everything works fine (same configuration, same SD card).
Device & Setup
Device: uConsole with CM5 lite 8GB (CM5108000)
4G Module: Present (official module)
SD Card: Silicon Power 64 GB V30 A1 U3 (3D NAND)
OS: Fresh install of Bookworm 6.12 (first booted with CM5 installed, tried CM4 after the problems occured)
Symptoms (Only with CM5)
Boot Issues
Very slow boot (30+ seconds), including any of the following:
Black screen with backlight on, nothing else
Black screen with blinking cursor
Stuck on penguin logo with
dphys-swapfile.serviceor any other message
Occasionally needs battery removal to recover
With patience, it eventually boots
Sometimes it boots fast with no problems
Post-Boot Freeze
After cold boot, launching a heavier app (e.g. Chromium or VS Code):
GUI input like opening apps or opening menu freezes
Cursor moves, windows move, but no clicks register
After 10–20 seconds, everything “catches up” and all tasks complete rapidly
This happens only once after cold boot, rest of session is stable
EEPROM Config Tried
[all]
BOOT_UART=1
POWER_OFF_ON_HALT=1
BOOT_ORDER=0xf1
SD_BOOT_MAX_RETRIES=2
SD_QUIRKS=1
Happy to run logs, dmesg, bootchart, or anything else you need.
