Hi all, new Uconsole user here, I have just upgraded to cm5, and image was fantastic, thank you Rex, but now it seems I have to boot and shutdown a couple of times for it to startup , is this normal?
thank you, any help appreciated
…Depends. Are you starting the image for the first time? Can you share the status messages generated when you boot?
Hi , thank you for the reply, no, multiple boots, just now to get it to boot, I had to startup (blank screen) and then hold the power button until it goes off, and then on again 3 times for it to start to boot
yes, you need to upgrade an eeprom, they released CM5 a bit buggy
This worked, working as normal now, thank you so so much, really appreciate that !
