im struggling to get cm5 to work i need somone to help me with simple download drop and drag im still lerning how to use o.s etc so i would be gratefull and would even consider donation
You might want to look into this thread: https://forum.clockworkpi.com/t/bookworm-6-6-y-for-the-uconsole-and-devterm
not working for me:( our im doing somthing wrong
What version of the CM5 do you have? You just need to write the image to the emmc or SD card on the lite model. Then boot, the panel doesn’t load right about 20% of the time causing no image to display.
gutted io have emmc how do i connect to computer :{ usb to usb u consle ?
With the emmc you will require a Pi carrier board that has a switch to put the cm into flash mode.
Nice to have the carrier board to be able to load stock Pi OS and make sure the cm is functioning before trying it in the uConsole or Devterm.
