Devterm CM4 printer prints nothing but "bar codes"
Hi all. I finally got some paper for my devterm printer. Unfortunately, all it prints is the exact pattern of bars no matter what I try to print. I eventually tried
sudo apt install -y devterm-thermal-printer
after reading a forum post. This actually caused the printer to completely stop working and disabled the networking as well. I reimaged last time because I could not figure out why wifi stopped working and nothing seemed to fix it. This time I immediately tried:
sudo apt remove -y devterm-thermal-printer
sudo reboot
Network support came right back up. Now the printer can’t even print the bar code errors anymore. It does nothing at all because the driver is gone. I decided I don’t know what I am doing and I don’t even know if the printer is DOA out of the box. Sucks because this is one of the most fun things about this device.
I tried this command too when the printer made noises and spat out bar code:
echo -en ā€œ\x12\x54ā€ > /tmp/DEVTERM_PRINTER_IN
it spat out more bar code…just about a two inch long bar code of the exact same pattern as the thing does of I print ā€œtestā€ in text editor or geany. Same pattern, just shorter. I am using vonylist 58mm thermal paper as advertised it would print with.
Anyone have a clue what the issue might be?
Thanks for reporting this issue just purchased the CM4 processor to use in my A06 DevTerm I use an external thermal printer now and have included my raw notes:
l_susb command displays all devices…
When I use an external USB thermal printer:
USB printers may present themselves to the system differently depending which USB- to-serial chip they use internally. Try the following first:
ls -l /dev/usb/lp0
If the response is something like:
crwxrwxr-x 1 root lp 180, 0 Mar 14 14:11 /dev/usb/lp0
Then this is a recent model. But if instead you get:
ls: cannot access ā€˜/dev/usb/lp0’: No such file or directory
Then try:
ls -l /dev/ttyUSB0
Don’t fret if your USB printer is the ā€œolderā€ model. All of these print images equally
well. Just need to know which it is: /dev/usb/lp0 , or /dev/ttyUSB0 .
Let’s verify we can print something. For a current ā€œ lp0 ā€ model, type:
chmod 777 /dev/usb/lp1
echo -e ā€œThis is a test.\n\n\nā€ > /dev/usb/lp0
echo -e ā€œThis is a test.\n\n\nā€ > /dev/usb/lp1
prints plain test file
cat ā€œtestfinenameā€.txt > /dev/usb/lp1
wher ā€œtestfilenameā€ is the name of your plain text file…
did you ever get this figured out? was your printer module damaged?
I am having the same issue (sorry for necro posting this thread…)
@forbidden64
Well, no. I did have ā€˜ similar idea to what MHam68HC11 suggested. except I found a generic source code for 58MM thermal printer driver, I compiled it and then just added it through the printer menu in the desktop. It even works over bluetooth, but I like the idea of the built in one. Because of the network issue, I assumed the build had some issue and didn’t try using it again. I’m trying out the A06 and haven’t been able to write the image successfully(ordered a new SD card). So, I’ll update this and also try the above if I have the same issue. I really still want that thing to work.
The 58mm driver works on the external, but could not see the internal.
Does anyone know what make that printer is in case it was always DOA?
Update:
I finally got the A-06 board hooked up and firmware installed. The printer worked perfectly right away. So, there is a problem with the CM4 image.
If you have not already bought a new processor, sd card reader and sd card like I had, try the steps described above. By the time I got a response it had already been a few months. Anyway, mine works now.
Of course, just in time for that, the headphone jack was poorly soldered at the anchor points (correction, SMD headphone ports apparently have no anchor points through the board at all). It snapped off with the pads and is stuck in headphone mode so speakers do not work. So it has no sound lol… sigh. Iwill have to run bypass wires all over, or buy a new main board.
Oh PS! The automatic fan service for heat management also works flawlessly on the A06/Armbian image. I do not have to start the fan manually in the terminal anymore like I did with the CM4. Totally worth the change over so far.
