Posted instructions in the other thread
Well I compiled it and its now working quite well!
Rise of the Triad = Very playable
Star Wars Dark Forces = Playable (need to adjust key binding for Jump)
Looking good!
in RetroArch?
cool glad it works.
Make sure you do the WITH_DYNAREC=arm stuff, otherwise it will be slow.
Funny because i did not.
I downloaded your source, unzipped it, ran sudo sh ./autogen.sh, then ./configure and finally make.
Its smooth as is.
That is just vanilla dosbox, not libretro/RetroArch
Ok… Should I redo everything the way you said or can I run it the way I did?
That’s up to you! whatever you prefer.
Is there a big advantage to use your method? Will it be more stable?
Sorry my english is not perfect…
I am a retroarch/libretro dev, so I’m biased, I prefer to use RA for anything I can.
