Hi,
I’ve managed to assemble a DevTerm A06 and it’s working just fine. The only problem I have is that I can’t seem to enable the big cores at boot time. The following commands work after boot, from the CLI:
I’ve tried to sprinkle them liberally around a few startup scripts (including in rc.local). No matter what I do, there seems to be something that shuts down CPUs 4 and 5 a short time after boot:
cpi@clockworkpi-a06:~$ sudo apt update
cpi@clockworkpi-a06:~$ sudo apt install devterm-gearbox-a06
cpi@clockworkpi-a06:~$ sudo devterm-a06-gearbox -s 6
| Cortex-A53 | Cortex-A72 | Mali-T860 |
| CPU 0 | CPU 1 | CPU 2 | CPU 3 | CPU 4 | CPU 5 | GPU |
| 1 | 600 MHz| OFF | OFF | OFF | OFF | OFF | 200 MHz |
| 2 | 800 MHz| 800 MHz| OFF | OFF | OFF | OFF | 200 MHz |
| 3 |1008 MHz|1008 MHz|1008 MHz|1008 MHz| OFF | OFF | 400 MHz |
| 4 | OFF | OFF | OFF | OFF |1008 MHz|1008 MHz| 400 MHz |
| 5 | OFF | OFF | OFF | OFF |1200 MHz|1200 MHz| 400 MHz |
|*6*|1416 MHz|1416 MHz|1416 MHz|1416 MHz|1800 MHz|1800 MHz| 800 MHz | <===
CPU Governor: schedutil GPU Governor: simple_ondemand
Now add “/usr/bin/devterm-a06-gearbox -s 6” to /etc/rc.local so it runs at boot.
Don’t forget the “sleep 15” command above it.
cpi@clockworkpi-a06:~$ sudo vim /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sleep 15
exit 0
I ended up trying something like that (except I’m just enabling the cores through the CLI and I’m controlling the governor differently but no big deal).
However, I’m still curious about what’s stopping CPU 4 and 5 about 24 seconds into the boot process.
Well, that’s surprising. I’ll see if I can dig through the code and figure out why that happens. Thanks for looking into this for me, I spent quite a bit of time trying to disable services that might have been related and I totally overlooked fan-temp. Though I suppose it makes sense it might care about the power profile of the CPU and how many cores are active, now that I think about it.
