I modified this Love2D Calculator https://github.com/imtn/love2d-calculator to work on Gameshell!
First create a new directory and two files named main.lua and conf.lua with the following code:
main.lua
--io.stdout:setvbuf("no") --enables live console output in sublime
--LOGIC ITEMS
local numOnHold = 0 -- After pressing +, -, *, /, =, previous number is kept in here.
local operatorJustSelected = false -- whether or not the most recent button press by a user, was on an operator
local justCalculated = false --Whether or not the user has just pressed enter or return to calculate.
local hasDecimal = false --Whether or not the calcDispStr number has a decimal point. If it does, we can't add any more decimal points
local maxCalcDispLen = 18 --If I didn't have this, the user could just keep typing numbers forever. This is the max, pleasant-to-see, digits that the calculator will display.
local currentButtonPressedIndex = 0 -- The index in buttonTable of whatever button is currently being held down. 0 means nothing is pressed right now because lua arrays start at 1
--FONTS
local buttonTextFont -- Font of all button text here
local calcDispStrFont-- Font of calcDispStr
local operatorButtonFont -- Font of + - * / =
local operatorDispFont -- Font of display in top right
--STRINGS & TEXT, CORRESPONDING
--You can set, but not get, the string displayed by LOVE2D's TEXT object. Therefore, we need a string and text for every item to display
local calcDispStr = "" -- string, to display on the face of the calculator, also needs to keep track of positive/negative as +/-
local calcDispText -- Text object to display numbers
local opDispStr = "" -- string to display
local opDispText -- Displays + - * / on the top right
local windowX, windowY = love.graphics.getDimensions() --width and height of window
--COLORS OF SHAPES AND TEXT
local backgroundColor = {64,64,64}
local rectangleColor = {41,41,41}
local buttonColor = {56,56,56}
local blackColor = {1,125,254}
local focusColor = {255,255,255}
--Basic arithmetic operations, to put in opTable and make the conditionals less wordy
local add = function(a, b) return a + b end
local subtract = function(a, b) return a - b end
local multiply = function(a, b)
c = a * b
if c == 0 then
c = 0
end -- lua relies on the c compiler, which can produce negative 0, which is sure to confuse the user. this if statement gets rid of negative zero.
return c
end
local divide = function(a, b) return a / b end
--List of lists. Each list is associated (conceptually, not actually codewise) with a button. Each list has six elements, which are in order: {x position, y position, width, height, radius of the corners of the button's rounded rectangles, string to be printed on button}
--Draw these like love.graphics.rectangle("fill", windowX*v[1], windowY*v[2], windowX*v[3], windowY*v[4], windowX*v[5])
--Set the color as black for text, then love.graphics.print(" "..v[6], windowX*v[1], windowY*v[2])
--Where you are looping through everything in buttonTable and v is each inner table
local buttonTable = {
{0.025, 0.634, 0.18, 0.17, 0, "1", 20, 5, 1, 3},
{0.210, 0.634, 0.18, 0.17, 0, "2", 20, 5, 2, 3},
{0.395, 0.634, 0.18, 0.17, 0, "3", 20, 5, 3, 3},
{0.025, 0.457, 0.18, 0.17, 0, "4", 20, 5, 1, 2},
{0.210, 0.457, 0.18, 0.17, 0, "5", 20, 5, 2, 2},
{0.395, 0.457, 0.18, 0.17, 0, "6", 20, 5, 3, 2},
{0.025, 0.280, 0.18, 0.17, 0, "7", 20, 5, 1, 1},
{0.210, 0.280, 0.18, 0.17, 0, "8", 20, 5, 2, 1},
{0.395, 0.280, 0.18, 0.17, 0, "9", 20, 5, 3, 1},
{0.025, 0.813, 0.18, 0.17, 0, "(-)", 12, 2.5, 1, 4},
{0.210, 0.813, 0.18, 0.17, 0, "0", 20, 5, 2, 4},
{0.395, 0.813, 0.18, 0.17, 0, ".", 24, 2, 3, 4},
{0.620, 0.280, 0.177, 0.232, 0, "/", 23, 7, 4, 1},
{0.803, 0.280, 0.177, 0.232, 0, "*", 20, 15, 5, 1},
{0.620, 0.520, 0.177, 0.232, 0, "+", 15, 7, 4, 2},
{0.803, 0.520, 0.177, 0.232, 0, "-", 23, 7, 5, 2},
{0.620, 0.760, 0.177, 0.225, 0, "c", 17, 7, 4, 3}, --clear, delete, whatever you want to call it
{0.803, 0.760, 0.177, 0.225, 0, "=", 17, 7, 5, 3}
local currFocus = {x=2,y=1}
--CALLBACK
function love.load()
love.graphics.setBackgroundColor(backgroundColor)
buttonTextFont = love.graphics.newFont(30)
calcDispStrFont = love.graphics.newFont(21)
operatorButtonFont = love.graphics.newFont(36)
operatorDispFont = love.graphics.newFont(17)
calcDispText = love.graphics.newText(calcDispStrFont, calcDispStr)
opDispText = love.graphics.newText(operatorDispFont, opDispStr)
end
--CALLBACK
function love.resize(w, h)
windowX = w
windowY = h
end
--CALLBACK
function love.draw()
--Border edge offset of 0.01
-- Draws the number buttons area
love.graphics.setColor(rectangleColor)
love.graphics.rectangle("fill", windowX * 0.02, windowY * 0.27, windowX * 0.56, windowY * 0.72, windowX * 0)
-- Draws the operator buttons area
love.graphics.rectangle("fill", windowX * 0.61, windowY * 0.27, windowX * 0.38, windowY * 0.72, windowX * 0)
--draws the actual buttons
for _, v in ipairs(buttonTable) do
love.graphics.setColor(buttonColor)
love.graphics.setFont(buttonTextFont)
love.graphics.setColor(blackColor)
love.graphics.print(tostring(v[6]), windowX*v[1]+v[7], windowY*v[2]+v[8])
if currFocus.x == v[9] and currFocus.y == v[10] then -- Button is focused
love.graphics.setColor(focusColor)
love.graphics.rectangle("line", windowX*v[1], windowY*v[2], windowX*v[3], windowY*v[4], windowX*v[5])
end
end
-- Draws the number display area
love.graphics.rectangle("fill", windowX * 0.01, windowY * 0.01, windowX * 0.98, windowY * 0.25, windowX * 0.01)
-- create love.graphics.newText and displays calcDispStr, and another for the + - * /
love.graphics.draw(calcDispText, windowX * 0.98 - calcDispText:getWidth(), windowY * 0.24 - calcDispText:getHeight())
love.graphics.draw(opDispText, windowX * 0.98 - opDispText:getWidth(), windowY * 0.12 - opDispText:getHeight())
end
--All key pressing AND button pressing gets relegated to this function
function love.keypressed( key )
if key == "escape" then
love.event.quit()
end
if key == "j" then -- A Button
for _,btn in pairs(buttonTable) do
if btn[9] == currFocus.x and btn[10] == currFocus.y then
buttonPressed(btn[6])
end
end
end
if key == "left" then
moveFocus(-1, 0)
end
if key == "right" then
moveFocus(1, 0)
end
if key == "up" then
moveFocus(0, -1)
end
if key == "down" then
moveFocus(0, 1)
end
end
function buttonPressed(key)
if key ~= "(-)" then
handleNumberAndOperatorInputs(key)
elseif calcDispStr ~= "" then
if calcDispStr:sub(1, 1) == "-" then
calcDispStr = calcDispStr:sub(2)
else
calcDispStr = "-"..calcDispStr
end
calcDispText:set(calcDispStr)
end
end
function moveFocus(xDir, yDir)
if currFocus.y == 3 and currFocus.x == 3 and xDir == 1 then -- movement from btn "3" to "+" when going right
currFocus.y = 2
end
if currFocus.y == 3 and currFocus.x == 4 and xDir == -1 then -- movement from btn "c" to "." when going left
currFocus.y = 4
end
currFocus.x = currFocus.x + xDir
currFocus.y = currFocus.y + yDir
if currFocus.x <= 0 then
currFocus.x = 1
end
if currFocus.x >= 6 then
currFocus.x = 5
end
if currFocus.y <= 0 then
currFocus.y = 1
end
if currFocus.y >= 5 and currFocus.x < 4 then
currFocus.y = 4
end
if currFocus.y >= 4 and currFocus.x > 3 then
currFocus.y = 3
end
end
function handleNumberAndOperatorInputs(key)
--handles numpad and home keyboard inputs
local numTable = {["0"]=0,["1"]=1,["2"]=2,["3"]=3,["4"]=4,["5"]=5,["6"]=6,["7"]=7,["8"]=8,["9"]=9, ["."]=".", kp0=0,kp1=1,kp2=2,kp3=3,kp4=4,kp5=5,kp6=6,kp7=7,kp8=8,kp9=9,["kp."]="."}
local opTable = {["+"]=add,["-"]=subtract,["*"]=multiply,["/"]=divide,["kp+"]=add,["kp-"]=subtract,["kp*"]=multiply,["kp/"]=divide}
--timesIAppreciatedSwitchStatements++;
--KEY IS DELETE
if key == "backspace" or key == "delete" or key == "c" then
--clear everything
calcDispStr = ""
opDispStr = ""
opDispText:set(opDispStr)
numOnHold = 0
hasDecimal = false
-- KEY IS CALCULATE
elseif key == "return" or key == "kpenter" or key == "=" then
--calculate anything if operator is selected
--if no selection, display what is currently displaying
if opDispStr == "" then
--nothing
else
--some operation happened, loop through possible operations
--but if operator has just been selected, don't do anything
if not operatorJustSelected then
local tempNum = opTable[opDispStr](numOnHold, tonumber(calcDispStr))
numOnHold, calcDispStr = tempNum, tostring(tempNum)
opDispStr = ""
hasDecimal = false
justCalculated = true
end
end
--KEY IS OPERATE
elseif opTable[key] ~= nil then
if key:len() > 1 then
key = key:sub(3)
end
--If just selected operator, replace that operator
--If we haven't just selected the operator and the operator display string ain't empty,
--perform opDispStr with numOnHold and calcDispStr, put in numOnHold and calcDispStr
--and set opDispStr as key, set operatorJustSelected to true
--If we haven't just selected the operator and opDispStr is empty, opDispText
-- set operatorJustSelected to true
-- set opDispStr as key
if operatorJustSelected then
opDispStr = key
elseif opDispStr ~= "" then
operatorJustSelected = true
opDispStr = key
hasDecimal = false
else --opDispStr == ""
numOnHold = tonumber(calcDispStr)
hasDecimal = false
opDispStr = key
end
--KEY IS NUMBER
elseif numTable[key] ~= nil and not ((numTable[key] == ".") and hasDecimal) then
if numTable[key] == "." then
hasDecimal = true
end
--if just selected operator, add replace calcDispStr with new number, but the old calcDispStr should still be in numOnHold
if operatorJustSelected or justCalculated then
calcDispStr = tostring(numTable[key])
elseif calcDispStr:len() < maxCalcDispLen then
calcDispStr = calcDispStr .. numTable[key]
end
--Below if statement prevents arithmetic involving only a decimal point
if calcDispStr == "." then
calcDispStr = "0."
end
end
end
conf.lua
--Configuration File
function love.conf(t)
t.title = "Calculator"
t.window.width = 320
t.window.height = 240
t.modules.physics = false
t.modules.sound = false
t.modules.mouse = false
t.modules.audio = false
t.modules.filesystem = false
t.modules.image = false
t.modules.touch = false
end
Then, create a new file named Calculator.sh in /home/cpi/apps/launcher/Menu/GameShell/ with the following content:
love path/to/the/folder
where path/to/the/folder leads to the directory with the two files you just created.
Now reboot and you’re done!
Have fun!
