Just a quick note. If you want Meshtastic and pyGPSclient to be working together, best to use GPSD, and feed NMEA scentences to Meshtastic and offer the same to PyGPSclient via a TCP socket. I just updated my write up on setting that up here.
It should give you pointers to be able to share the GPS device succesfully.
You can then get GPSD, Meshtastic, SDR working all at the same time.
Thanks for documenting it out, I will try this tonight. I took a trip to LA and wanted to take it with me and ended up plugging in a second USB GPS and got around the conflicts but it was pretty cumbersome to use in public with everything attached.
Does anyone know the battery connector size for the Hackergadgets battery board without the 18650s? I order a battery for it any it came sans connector. thank you
Got a slight problem, it’s been baffling me for a day or so now and I feel like I’m going in circles.
I’ve got the rtl sdr to so I’ve moved onto the gps but I can’t get it working at all. I’ve gone through the config.txt and changed this as well as tried using minicom and re-installing the expansion board packages multiple times but it doesn’t seem to work, my dad says it’s possibly due to bad weather, had clouds for 2 days now but I’m doubtful.
when I try and use PyGPSClient it shows no data but launches ok. Can someone recommend what to do?
I’m a bit of a newbie to this so any help would be greatly appreciated.
I’ve got a new problem with lora this time. Feels like it’s just me lol.
So I’ve gone through the whole setup for the Lora part but I keep getting a meshtasticd.service fail… I’m also not getting a kind of Meshtastic Web or MUI. I was wondering if someone could give me a hand?
the log is saying that the binary cannot be found. Do you have the binary at /usr/sbin/meshtasticd ? is it executable?
try stopping the meshtasticd service and starting it by hand amd putting it into debug mode and see whats going on.
