Thanks for the help so far, it’s greatly appreciated.
I’ve run it in debug mode now and it seems to be coming up with a few errors, do you have any suggestions?
from this screen, if you hit enter a couple of times, the binary is running right?
if it is, you can try accessing the meshtastic web interface. see if that loads something.
IIRC, that would be https://127.0.0.1. you then try to add your local device.
I got it working, after running it in dev mode and then re-installing it it’s worked. I’m guessing it’s because it didn’t load all of the packages correctly? I could be wrong though.
Thanks for everyone’s help.
Anyone able to help I am setting up the hackerGadgets v1 board have everything working but LoRa just get connection failed all the time when starting up the ui
do the same. do not start the meshtasticd as a service immediately. i.e. disable the daemon and start it by daemon manually. enabled debug in the configuration file (config.yaml) and watch the output to try understand what is wrong.
if it cannot detect the chip, then you either have a chip problem or a configuration problem for the chip. If something else is breaking, you should be able to spot it, for example, conflict on the GPS port or something. if so, either disable GPS in your configuration or make sure no other app is using the GPS when you start meshtasticd.
Thank you again for all your work,
I am having an apt update issue, When I run it. I get an Error 403 for the re4son-kernel reprository. I can comment it out in the /etc/apt/sources.list.d but Do I need to? or do I even need re4son-kernel repro?
I think they changed their repos. I will be putting out a new kali image in a day or so.
I just updated trixie, bookworm and dragonos to work with the new screen today. The rest will be within the week.
They don’t use re4son’s kernel patches anymore.
It is possible to update the meshtastic firmware? I have AIO V1 board and the current firmware is 2.7
Thank you!
Yes it will update when ever available when you apt upgrade
Bonjour Rex est-il possible de faire de reset du module lora sur l’aio v2 ? Je ne peux plus rien modifier sur le module car j’ai accidentellement activé l’administration à distance en utilisant la clef publique d’un nœud dont j’ai modifié la clef :frowning: je ne peux plus rien modifier je suis perdu
the config is stored in /etc/meshtasticd/config.yaml afaik
i made the mistake of selecting managed mode on my and it’s bricked now. can’t flash, reboot, hard reset or anything.
The whole device is bricked? Or you can’t access meshtastic?
That yaml file @snipeytje posted might have what you need. If that don’t work uninstall and reinstall meshtastic-mui and start fresh.
Hello, i can access to meshtastic mui but lora device is brick, I uninstall and reinstall meshtastic mui but nothing change
Have you tried by passing the MUI and just check meshtasticd? Disable it using systemctl, and start meshtasticd in debug mode, and see if the hardware is really toast.
Hello , no hardware is ok the problem is i cant access setting, i cant modify or juste make a factory reset
have you tried deleting the config file?
Yes, i delete config.yaml in /etc/meshtasticd and i uninstall meshtasticd and reinstall but nothing change
