How does UConsole boot and install an image? Is it through U-Boot?
assuming you have a cm4 lite; you flash the os to your tf card using another computer. in which case you’ll just follow the guide on the raspberry pi website; using either the stock clockwork os (it is severely out of date now) or you use one of the community os images that can be found in this forum.
if you have a cm4 with emmc. you will need to use a carrier board that supports flashing the emmc.
