This firmware update fixes a bug related to the fn key and changes the volume key logic. Here’s how you can flash the firmware on uConsole(A06 or CM4 only) or a PC running Ubuntu 22.04:
Download the uconsole_keyboard_flash.tar.gz file.
Extract the contents of the archive: tar zxvf uconsole_keyboard_flash.tar.gz.
Install the required package using the following command: sudo apt install -y dfu-util.
Navigate to the extracted directory: cd uconsole_keyboard_flash.
Execute the flash script with root privileges: sudo ./flash.sh.
If everything goes well, you will see a progress bar indicating the flashing process.
If any issues occur or the keyboard loses control (which is unlikely), simply reboot uConsole to resolve it.
Rest assured that this flash program will not brick your keyboard.
Nice to know, thanks. I want to bake my own image based on the latest Ubuntu (23.04 today) but I think there will be some adjustments to be made that will be documented later. DevTerm already has a lot of information on its wiki, but uConsole, since is a newer project, will have more details soon, I think.
I’m in the batch that received their uConsole, but without the CM4 adapter. I do have a CM3 to put in, though, in the meantime. Which OS image should I use? I see a Clockwork OS 0.5 that presumably is from older devices, so I’ll try that, but anything else I should look at?
I was able to boot into the image, go through the armbian setup and log into XFCE.
Keyboard and trackpad seem to work fine, as do the arrow keys. I was also able to get online, so I think I would call this a success!
I think the old dl.clockworkpi site isn’t used any more, at least it seems that it has been removed from the homepage links. Either way that would be the DevTerm image, not the uConsole.
The second link you posted leads directly to the uConsole image you need? I’m not sure what you mean by “nothing in the images page”.
Sorry, I mentioned the images page, but that was a link someone shared back in july, looks like it was removed.
But, on the page I linked to, that download link was not working earlier. Maybe there was just a hiccup, i could click the link and nothing would happen. I copied and pasted into a new browser tab, nothing. But, trying it a half hour later now, it seems to be working. apologies for the confusion here, I guess I was thinking it was a broken / bad link.
