Good afternoon, I tried these steps but it gets on the loading screen infinitely ⦠after deleting the file action.config it returns to normal ⦠can it help? thank you.
paste your action.config?
ROM = / home / cpi / games / SNES
ROM_SO = / home / cpi / apps / emuladores / snes9x_libretro.so
EXT = zip, sfc, smc
LAUNCHER = retroarch -L
TITLE = SNES
SO_URL = http: //buildbot.libretro.com/nightly/linux/armhf/latest/ snesx2005_libreto.so.zip
ROM = / home / cpi / games / SNES <- space between / and home ,and cpi ?
Sorry for speaking Portuguese BR did not understand your question ⦠I have a space between the bar and the folders (name) I have to take out the spaces? would it be this ? thank you.
Good afternoon, I managed to solve the problem of not starting ⦠but when selecting the game the screen turns black and returns to the list of games ⦠anyone have a suggestion? I can only play by entering the retroach, choosing the core ⦠and then the game ā¦
I managed ⦠I put the emulator in the emulators folder the correct version of snes9x 2005 and everything ok, now Iām going to change the icon to the correct snes icon. thank you.
hey tnalvo,
great that you found a solution to your problem. In *nix filesystems (CPI is based on Debian) there are no spaces when referring to files or directories.
If you have to access a file that does have a space in the name, enclose it with quotes.
Like:
ROM=/home/cpi/games/SNES/āSuper Mario Etc Etcā
Good morning friend, yes as I am newbie had not understood, thanks for the tip, now I will try to install PS1 emulator.
Hi there -
I appreciate the email, but in the future, please ask me questions in
the forum - so that other members of the Clockwork community can learn
as well. Just like you, I am a customer and do not have all the answers.
For the āCoinā button in MAME you can use the inbuilt settings in CPI
MAME
thread here:
In short: they say that you cannot really pick your own combination of
buttons, but have to select what is there in the menus of MAME. In my
own Clockwork I use the button āSELECTā to insert a coin in MAME
hope this helps -
CM
yo you the best got my megaman battlenetwork icon up and running cuz of you
Sorry, not sure if this has been posted. But is there a way to link a game icon on the home screen to the emulator folder with the game files in it (like the Retro Games icon)? For example, if I wanted a Pokemon folder to directly link to a folder with those games in it. I figured out how to get the icon on the home screen, but Iām not sure how to get the emulator in the folder.
I think I get what you mean. Instead of having all of your gba Roms in a folder, you just want PokƩmon, and want the folder to be on the main menu with a custom icon?
The post above gave a great tutorial. Just make a note of what you name your folder, where it is, and whatās inside.
Can I get these same command steps for sega
Hey, welcome to the forums @Christian_Robinson!
I notice you deleted your comment. Possibly because you worked it out? Or perhaps were trying to articulate it easier. Either way. Hereās a small step by step way to show you how to do what you want. You can substitute PokĆ©mon with whatever you want.
- Make a directory called Pokemon
- Make a file file called Pokemon.sh within the above mentioned directory
- Edit the contents to look like this:
retroarch -L /home/cpi/apps/emulators/mgba_libretro.so /home/cpi/games/MGBA/pokemon.gba
- Add your desired icon to the same directory you saved the Pokemon.sh file, and name it Pokemon.png
Step 3 might need to be adjusted according to where you have things located.
Frustratingly, the Retroarch cores are stored in ~/apps/emulators by default. The location that you have put is a far more logical location. Itās where I personally have it set to in my own custom image.
That said, it doesnāt matter where Retroarch specifies the core directory is in the config. You define where it is with the script you make. Just make sure there is a file where your script says there should be one, and that the name is correct.
Say youāre not wanting to use the mgba core, and instead want to use the gpsp standalone emulator.
Also, say youāre trying with a different rom, with the name āMother 3 Eng.gbaā
And also, say you have altered the directory structure. Hereās what your Mother 3.sh file would look like.
/home/cpi/apps/emulators/gpsp /home/cpi/games/GBA/Mother\ 3\ Eng.gba
Notice how you donāt need to have another program, followed by an -L parameter like you originally tried.
Spaces in file names need to be differentiated from spaces between commands, as seen above, using a back slash \
Another thing I just realised. If you are using the mgba that gets downloaded via the action.config file, you may want to delete the mgba_libretro.so core, and edit the MGBA action.config to have SO_URL=https://buildbot.libretro.com/nightly/linux/armv7-neon-hf/latest/mgba_libretro.so.zip
It needs to be updated, as the stock location isnāt the correct one. That could potentially be another reason mgba isnāt loading. That said, Iām guessing you can use mgba normally.
Hopefully this works for you!
on fantasti launcher all of this is natively supported, roms of a system are not associated with a folder, but opened independently depending of their file type,
thatās mean you just organize them as you want,
by example you could create a mario folder with all roms of all platform inside
Thank you so much for reaching out! I got it to work at like 6 am or something and deleted the comments. Iām not sure what did it Iāll have to check again. I added something like #!/bash or something and it worked! Im going to make more icons to go with my dark mode theme im working on. Iām a noob to coding but I can make artwork so im trying to learn. Thank you for reaching out. Clockworkpi gameshell has been a good project for me.
Thatās so strange, given the # means the line was commented out! Also, donāt feel bad for leaving things up that you have worked out. Chances are someone else probably wanted to ask the same question. Even just putting an edit fo say youāve worked it out is just as useful. ![]()
Im excited to hear about the dark mode skin youāre making!! Iām a huge fan of not having my eyeballs burned by bright UIs.
Thereās some great info on how to tinker with colour parameters here:
And if you google ācolour pickerā, google has a tool available to easily convert RGB colours you use in photoshop etc to the hex values required by the gameshell.
And haha I know what you mean, working on things till 6am. Iāve been doing it way too much lately. That awkward feeling, getting into bed, while your significant other is just waking up to go to work. The curse of the gameshell.
I made the [Rom Name].sh file in this directory:
Home/cpi/launcher/menu/gameshell/Pokemon.sh
Then for Pokemon.sh:
#!/bin/bash
/home/cpi/games/MGBA/Pokemon.gba
I put the .png icon here in my modified OP1 skin for pure dark theme:
Home/cpi/skins/OP1Dark/menu/gameshell/Pokemon.png
I think this might have been my issue because it was named Pokemon - Emerald Version.gba and it sounds like it needed to be:
/home/cpi/games/MGBA/Pokemon\ -\ Emerald\ Version.gba
Is that how it shouldāve looked before renaming the .gba rom?
In that case can I remove this and be fine? What is this for exactly?
#!/bin/bash
