Let me take you through a journey where I did what I do best, break things.
I was tinkering with the keyboard code and as you might know, you can use the DevTerm keyboard on your PC, I uploaded a code where I introduced a bug where I had few keys pressed and they didn’t release, which resulted connecting the keyboard to my PC = disabling all kind of inputs on my PC.
I couldn’t even click upload to reflash the keyboard with the fixed code, so I figured out I could leave how I dealt with that, in case it happens to someone else.
Create a config under X11 xorg:
sudo nano /usr/share/X11/xorg.conf.d/99-disable-cpi-kbd.conf
add the following:
Section "InputClass"
Identifier "Disable DevTerm Keyboard"
MatchProduct "ClockworkPI DevTerm"
Option "Ignore" "on"
EndSection
Restart X11 and you should be good to go.
Now your Linux OS won`t accept input from the device and you can still flash it by DFU.
