My device is A06
How to set the default root user login in armbian system
My device is A06
Define the term “set”? Login automatically as root in X windows? Switching to the root user on the terminal once you are inside as the CPI user? Set the root users password?
The default OS is hard coded to the CPI user. You should always login as cpi, and sudo to root. The Manjaro OS images allow you to setup a user and, I think, login as root.
What I mean is that like the kali system, you can log in to the system directly with the root user. Open the terminal and the folder is the root privilege
Yeah, not [easily] possible. Just the nature of the pre-built image.
Plus, it’s really bad practice. ![]()
