How to upgrade mmbasic 5 to 6?
hi
I have received my picocalc, but with mmbasic 5, so i like to upgrade to 6.
I have read a lot of topic, but i’m still lost
How can i do ?
Go here:
and download
PicoMite_PICO_V6.00.03_PicoCalc.uf2
This is (as of writing) the latest version that works with the Pico 1H board that ships with the PicoCalc.
Next you will need a micro USB cable. And you’ll need to locate the button on the Pico 1H board in your PicoCalc. You can program the Pico board alone or while it is installed in the PicoCalc (as long as the PicoCalc is turned off).
Be sure your PicoCalc is OFF.
Press the button on the Pico 1H (it is below the word “reset” on the back of the PicoCalc below the micro USB port) and then plug in the micro USB cable to your computer while holding the button down. After a few moments a drive will mount on your computer. You can release the button.
Now just copy the file PicoMite_PICO_V6.00.03_PicoCalc.uf2 to the drive that appeared. The Pico will unmount after copying is complete.
That’s all!
