Thanks for the ssh info for connect trought fillezilla! it works for me!
Hello, clearly I have the same issue and I have some network and computer science background.
I just canāt ping my gameshell and I tried most evrything :
- Ping the IP
- Tried SSH using Filezilla
- Tried SSH using WinSCP
- Tried SFTP
- Tried to fix the IP
Nothing worked. But I know my gameshell is connected because I managed to get and install the update on my gameshell.
Any idea ?
Thanks
Toji
Have you tried to connect with an another device on the network? It might be something with your PC or security settings.
If you canāt ping it, that should most definitely be your first priority.
Yeah I tried that.
Iāll try at work tomorrow to check if itāa a domestic wifi issue or not.
Thanks
Iāll let you guys know if I ever find something.
Gotta cover all the bases, man
Saying āitās probably your routerā isnāt really helpful, but itās probably your router.
If you can, you might be able to get by with a laptop hotspot if you have one available.
Tried at work, works llike a charm.
So my domestic WiFi is the issue.
Going to check what Iāve been missing
Thanks
Open a new Windows Explorer window, then click on the āNetworkā tab on the side, and then you will see āCLOCKWORKPIā listed under PCs. Click on it, then enter cpi for user name and cpi for password, then you will see the games and music folders. You can drag and drop the roms into the correct folder in games. There is no point in putting music on it, the speaker is too weak to be enjoyable for music.
