Install and Run Pygame on GameShell with Miniconda
Connect to GameShell via ssh
ssh cpi@192.168.1.112
cpi@192.168.1.112’s password: [type “cpi”]
Linux clockworkpi …
cpi@clockworkpi:~$ pwd
/home/cpi
You can find the address to “ssh" to by navigating to “tiny cloud” in the GameShell. The default username and password are both “cpi”.
Create a folder “downloads” in “/home/cpi/“, where we will place the Miniconda install script later.
mkdir downloads
ls
apps downloads games launcher launchergo music skins
Download Miniconda for Linux and Move to GameShell
I already download the miniconda install script (https://repo.anaconda.com/miniconda/Miniconda-3.16.0-Linux-armv7l.sh, which is renamed miniconda-install.sh) on the computer and thus I just “scp” it to the GameShell. Alternatively, you can of course download the Anaconda install script directly to the GameShell after “ssh” to it.
cd ~/Downloads
~/Downloads >> scp miniconda-install.sh cpi@192.168.1.112:/home/cpi/downloads
Wait until the transferring/downloading process done.
Install Miniconda on GameShell
Login to GameShell and install Miniconda.
Linux clockworkpi …
cpi@clockworkpi:~$ bash downloads/miniconda-install.sh
Read the terms and follow the promotions to install Miniconda. Then create the environment, say “first”, install “SDL” ([2]) and “pygame".
cpi@clockworkpi:~$ conda create -n first python=2.7
Install SDL ([2])
cpi@clockworkpi:~$ cd downloads
cpi@clockworkpi:~/downloads$ wget http://www.libsdl.org/release/SDL-1.2.14.tar.gz
cpi@clockworkpi:~/downloads$ tar -xzvf SDL-1.2.14.tar.gz
cpi@clockworkpi:~/downloads$ cd SDL-1.2.14
cpi@clockworkpi:~/downloads$ ./configure --prefix=$HOME
cpi@clockworkpi:~/downloads$ make
cpi@clockworkpi:~/downloads$ make install
Install Pygame ([2])
cpi@clockworkpi:~$ source activate first
(first) cpi@clockworkpi:~$ cd downloads
(first) cpi@clockworkpi:~/downloads$ wget https://www.pygame.org/ftp/pygame-1.9.1release.tar.gz
(first) cpi@clockworkpi:~/downloads$ tar -xzvf pygame-1.9.1release.tar.gz
(first) cpi@clockworkpi:~/downloads$ cd pygame-1.9.1release
Comment out the line starting with “_camera” in “Setup”, and then install the “pygame” by running:
(first) cpi@clockworkpi:~/downloads$python setup.py install
Now you can import “pygame”.
Python 2.7.10 …
import pygame
Create a Game and Start in GameShell
Connect to GameShell and navigate into the games. Create a repository “first_game” for the new game.
(first) cpi@clockworkpi:~$ cd games
(first) cpi@clockworkpi:~/games$ mkdir first_game
Create the pygame script “first.py” in “~/games/first_game".
import os, sys, random, time, datetime, math
import pygame
from pygame.locals import *
from pygame.color import *
GS_KEY_MENU = 27
GS_KEY_X = 117
GS_KEY_Y = 105
GS_KEY_A = 106
GS_KEY_B = 107
GS_KEY_UP = 273
GS_KEY_DOWN = 274
GS_KEY_RIGHT = 275
GS_KEY_LEFT = 276
GS_KEY_SELECT = 32
GS_KEY_START = 13
class First :
def __init__(self) :
    self.width = 320
    self.height = 240
    self.delta = 0.2
    self.event = None
def draw(self, screen) :
    pygame.display.flip()
    screen.fill(THECOLORS["white"])
    screen.blit(pygame.font.Font(None, 24).render("Hello world!", 1, THECOLORS["black"]), (10, 10))
    screen.blit(pygame.font.Font(None, 24).render("You pressed: %s" % self.event, 1, THECOLORS["black"]), (10, 50))
def run(self) :
    pygame.init()
    screen = pygame.display.set_mode((0, 0), pygame.FULLSCREEN)
    clock = pygame.time.Clock()
    running = True
    while running :
        for event in pygame.event.get():
            if event.type == QUIT:
                running = False
            elif event.type == KEYDOWN :
                self.event = event.key
                if event.key == GS_KEY_MENU :
                    running = False
        self.draw(screen)
        pygame.event.pump()
        clock.tick(1 / self.delta)
if name == “main” :
game = First()
game.run()
Then create an entrance shell “11_First.sh” in the launcher of GameShell.
(first) cpi@clockworkpi:~$ cd launcher/Menu/GameShell
(first) cpi@clockworkpi:~$ vi 11_First.sh
The content of “11_First.sh” should be like this.
#! /bin/bash
python ~/games/first_game/first.py
You can also make an icon for the new game, say a png picture “First.png”, and put it into “~/launcher/skin/default/Menu/GameShell”.
Reload the UI, and now you should see a new app named “First” in the launcher. Enter it, you will see “Hello world!” followed by a promotion to tell you the code of the last pressed key. If you followed exactly what are given in “first.py”, then you can exit the first game and back to the launcher by pressing the button “MENU” on the GameShell.
That’s all. Happy coding!
References
[1] Installing on Linux — Anaconda documentation
[2] https://community.webfaction.com/questions/315/how-do-i-install-pygame
[3] GitHub - pvcraven/gameshell_template: Python Arcade Gameshell Template
Hello! Thank you for this guide! it’s the only guide that i’ve found on the internet about PyGame on GameShell. But i guess i’m missing some steps in order to run Pygame sample successfully - i get only a black screen for couple of seconds and then i return to main menu.
The first time i’ve tried to follow this guide i’ve missed the line where you need to create first conda environment: conda create -n first python=2.7, but next time i’ve ran it.
Maybe there is some other steps not mentioned in this guide? How should i debug my problem? i’m not expirienced with linux and just wanted to tinker with and with pygame, but stuck right at the beginning :frowning:
UPD: After one more try i get this message while installing PyGame:
Hunting dependencies...
sh: 1: smpeg-config: not found
WARNING: "smpeg-config" failed!
SDL     : found 1.2.14
FONT    : not found
IMAGE   : not found
MIXER   : not found
SMPEG   : not found
PNG     : not found
JPEG    : not found
SCRAP   : not found
PORTMIDI: not found
PORTTIME: not found
Should i install those libs as well?
Hi~It has been a while since I wrote this post, but I think all the steps are recorded, and as I remembered, SDL is the only package you need to handle before installing pygame. Did you install pygame from the source?
yes, i believe i’ve installed PyGame as described in your guide.
i’ve tried to follow your guide one more time and now i get error when trying to call import pygame:
(first)cpi@clockworkpi:~/downloads$ python
Python 2.7.10 |Continuum Analytics, Inc.| (default, Oct 28 2015, 19:48:38)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
Anaconda is brought to you by Continuum Analytics.
Please check out: http://continuum.io/thanks and https://anaconda.org
>>> import pygame
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/home/cpi/miniconda/envs/first/lib/python2.7/site-packages/pygame/__init__.py", line 95, in <module>
    from pygame.base import *
ImportError: /home/cpi/lib/libSDL-1.2.so.0: undefined symbol: _XGetRequest
After a quick search, it seems an old problem due to the incompatible version of other libraries, like libX11. As I can’t repeat this issue on my gameshell, I am not sure in your case which library should be updated. By the way, I repost this guide in a better format [Repost with Snapshot] Install and Run Pygame on GameShell with Miniconda. Hope to hear your problem being solved in the end.
UPDATE: I see someone said this problem appears after update SDL to 1.2.15, which version you used?
The same as in the guide (i’ve copied commands into Putty console)
i’ll try to follow your guide, hope that i’ll able to finish it successfully :slight_smile:
