Is Diablo possible? I think there is a Linux native binary available?
Only thing I tried so far with box86/box64 installed was Zachtronics superb TS-100, which runs, but is scaled weirdly (I think down to 800x480?) making text unreadable and thus the game is unplayable sadly.
Someone made a Gameshell port of Diablo a few years ago, and I’m guessing it will run fine on Devterm too. Looks like the build process is pretty easy, but I haven’t tried it yet.
Forget about PiKISS for the A04 and A06 cores. It refuses to run on anything else other than a Pi. However, you can still take a look at the PiKISS git in the scripts folder, there are a lot of interesting things to install (x86/x64 and otherwise)
PiKISS is a nice collection of scripts accessible through a menu to install various things. It includes the install script for Diablo, I believe.
I am not sure if PiKISS works out of the box on the A04 and A06 cores, but worth a try.
Installing box64 works fine, the only change from the script being defining ARM_DYNAREC instead of RK3399, when calling cmake, that is:
sudo apt install cmake
git clone https://github.com/ptitSeb/box64
cd box64
mkdir build
cd build
cmake .. -DARM_DYNAREC=ON -DCMAKE_BUILD_TYPE=RelWithDebInfo
make -j4 # assuming all 4 cores are enabled
sudo make install
However, I’ve been unable to get box86 to build. The compiler complains about the -marm option, the -mfpu=neon option, and the -march=armv7-a+simd option. The last one worries me the most, since isn’t the point to compile armv7 code (for 32-bit)? And the error suggests that the compiler can only deal with arm64 architectures:
They seem to work, but I haven’t been able to test this thoroughly, since my screen keeps dying a few minutes after boot. I guess, I will have to contact @AlexDuan by mail to get a replacement after all.
Zachtronics TIS-100 started, which I think is x86
Zoom conference client x64 started aswell and seems to work well, even with UVC webcam plugged in, except for a few graphical glitches and the screen being to small to actually be useful (might have to experiment with screen scaling for this)
Ok, based on your comment, I also used the armbian-gaming.sh script to build box86 only, and it seems to work! I also tried TIS-100, which is indeed x86. It seems fully functional, although, just as you say, it’s going to be challenging play on the tiny screen. Great tip, thanks.
So I have an issue that this gets stuck on Logging in user '*****' to Steam Public.... It seems to be stuck in that condition permanently. Have you encountered that before?
Hmm, I don’t remember getting that. It’s been a while since I tried running something this way. Many of the Steam (and other Windows games) I tried to run ended up throwing that GLXBadFBConfig error. And since the display and controls on the DevTerm aren’t exactly gaming-friendly, I haven’t been using it for that lately.
The only thing I might suggest is making sure steamcmd is up to date. Maybe delete, download, and set it up again? I vaguely remember having trouble with an out of date version of it at one point, but I don’t remember it getting stuck like that (I seem to remember it just exiting and failing with an error).
These days I’ve been using my DevTerm as a small private Valheim game server. I was kind of surprised that even worked. I’ve also recently set it up with qFlipper to connect to my Flipper device. While I can update the Flipper firmware that way, I think it’s most interesting as a way to make a serial connection to the Flipper and then send messages wirelessly over the sub 1GHz range, etc.
Also, you may want to make sure you’re not running (or are signed out of) Steam on other machines. Maybe it’s not letting you log in multiple times? Before it would log me out on another machine when I tried to log in again, but maybe something changed.
This is a weird problem that I can’t nail down. I also have installed full Steam app in both Manjaro and standard Ubuntu install, and both of them just hang on the monent when I click “login” button. The issue is that I’ve been trying to solve that for months.
I’m not sure if it’s related to other Steam instances on other machines, I’ve been able to download a linux version of one game using steamcmd on Mac, then transferring it to DevTerm.
The only comment that I can give now is that Half-Life 2 Linux x86 runs pretty slow even with forced DirectX 6.1 and all low-power optimizations. Only A72 are enabled on 1.8 GHz, and Mali is set to 800 MHz. Maybe I can overclock them…
