Hello All,
I have rand the pip command to install idle and Jupyter notebook on the Devterm A0604. However, when I run the commands IDLE and jupyter notebook in the shell, they don’t launch the programs and return unknown command error. I checked the GUI and jupyter notebook is shown under applications in the menu but it does not launch it when clicked.
have you checked ~/.local/bin ?
Of course. The Jupyter files are there and permissions are also correct. However when I run the command it does not recognize it as a command. I browse to that directory and issue command. I even tried to launch it from applications, it shows error.
I am not sure why IDLE is also not recognised.
Can you paste in what exactly you are typing in the terminal and what’s the result? Or take a screenshot?
cpi@clockworkpi-a06:~$ which pip3
/usr/bin/pip3
cpi@clockworkpi-a06:~$ pip3 install idle
Requirement already satisfied: idle in ./.local/lib/python3.9/site-packages (1.0.4)
cpi@clockworkpi-a06:~$ idle
-bash: idle: command not found
cpi@clockworkpi-a06:~$ idle3
-bash: idle3: command not found
Jupyter notebook is working now. But the IDLE issue is still there. Can you please help? I will use all this knowledge to create free tutorials on Youtube and a free course on Udemy.
um, that’s not how the pip-installed idle works. you should use the system package manager to install idle.
or you could just “import idle” in python and it’ll hopefully pop up.
On mine, I made an icon that runs the command “/usr/bin/idle %F” and that worked.
Well, it does warn you (in the logs you omitted) that ~/.local/bin is not in your PATH.
Hello folks,
Thanks a ton for offering all the assistance. I have tried a few things and following sequence of commands works for me,
sudo apt install python3-pip
sudo apt-get install idle3 -y
pip3 install jupyter notebook jupyterlab
cd ~
sudo nano .bashrc
Add the following line to the .bashrc file,
PATH=$PATH:~/.local/bin
Exit and restart the shell.
Thanks a lot again for all of your assistance. I will ask more questions when I get any issues.
- If you apt install idle3, you don’t need to update PATH to include ~/.local/bin
- Don’t
sudoedit your.bashrc
I had to add the bin directory to the PATH for Jupyter.
Hey - thinks for this post - just found it -big fan of Juper Notebook!
