raspberry pi is a mainstream arm ![]()
ghehe yeah much has changed since then
Most things should just be available in some form.
I knew Debian was the source and assumed Bookworm was a version of it, but that’s about all.
Installing and configuring from a different distro or architecture is where I come unstuck and I’d love to have enough knowledge to do what you’re doing. One day, maybe.
Haha, that made me laugh
I think a little insanity helps whenever you deal with Linux.
basically, debian package is an archive so
- download some modern version of
mypackage.deb - install
deb2targz deb2targz mypackage.deb- unpack somewhere
mypackage.tar.gz - go to some kind of
bin/directory inside - run binary
and now you have working portable copy of you package which you don’t need to install into system and can remove any time, works like 4 of 5 times
sometimes you may need to download and drop some my_lib.so inside of package’s lib/ directory, depends on how wierd package is.
Even if only some of the apps work, this is a great idea. Based on my using SUSE at work with an Oracle database many years ago, I was used to dependency hell when you tried to do anything different.
Things have definitely become easier with Linux over the years, but it’s hard to get out of the current ‘Windows’ mode in my head and to think differently.
I’m running Gargoyle to play the Hitchhiker’s Guide to the Galaxy (z3). It also runs most other interactive fiction formats.
Thank you, I’ll look it up ![]()
Is there a way to adjust the background and size of the letters?
it’s a CLI application so font size should be set in your terminal program.
try to press ctrl + + and if it won’t work – change your terminal program (or read docs how to change font size). I can recommend alacritty, but it’s up to you to find suitable one.
I meant the Gargoyle program that d0ktamo mentioned
The preferred method is to start a game and then use the shortcut
Ctrl+,(Command+,on Mac). This will open Gargoyle’s configuration file in a text editor.
Thanks for the link. I’m still exploring; I haven’t even had the uConsole for a week…
