I’m considering buying a uConsole and am wondering if it can be used as a personal computer.
Depending on the core, yes? for example if you can run use a Raspberry Pi 4 for your workload then the uConsole can as well (definitely not the R01 though) with the benefit that you can take the computer with you.
Would I recommend it as your main computer? No, probably not.
I have several used laptops (Windows 7 vintage) that I upgraded to Linux with an SSD hard drive - my only issue with the DevTerm and the uConsole use beyond utility is the microSD card… other than that - as a computer for coding , and development (I use an external monitor ) but my preference is to repurpose a laptop and maintain a backup of my efforts on an external hard drive.
I have an original pi 4 (the one that was finicky about power before Pi did a hardware revision) hooked up as a “desktop” in my office.
I have and do use it when I want a large monitor and full keyboard, it also runs rtl_433 scans and is a media server for the house, it is also hooked up to a tv with the second hdmi if I want to watch something. Would I want to run VSCode and compile on it? Nah but it does just fine as a “normal” computer.
But then I have done this with every pi version starting with the 1B.
The uconsole presents an interesting convergence use case as well. Plug in to a dock of sorts and you can have a full keyboard/monitor and charge while using it, disconnect and you have an almost umpc for travel.
I don’t have a uConsole yet (still waiting) but I can say that I had to go out of town for a week and I took a DevTerm and only needed that the entire time. I’m a programmer, so I think with the uConsole, the smaller keyboard would make it trickier to use full-time without a keyboard/mouse, but I think I’d be fine using it as my main desktop with that (probably also a monitor).
Photographers have a saying, “What’s the best camera? The one you have with you.” The idea is that if the alternative is not taking the photo, any camera works, so it’s good to have one you can always carry. That’s the thing I expect I’ll like about the uConsole: it’s small enough that you can always have it with you.
I ended up bringing a small mechanical keyboard (Vortex POK3R) and wireless mouse when I travel overnight with a DevTerm. Maybe less convenient than a laptop once I start bringing so many accessories. But I can also curl up in a chair and use the DevTerm more easily than I can a laptop. I’m using a CM3 so I don’t benefit from the improved performance of RPi4.
I found the trackball and left/right buttons on the uConsole to be much better than on the DevTerm. And I have a CM4 in mine, so it’s quite zippy. I have some WiFi troubles on mine, so I’m using a USB WiFi dongle until I get around to fixing it. (my home wifi is a bit complicated with some repeaters plus an unreliable access point from the cable company)
Ah, yeah. My normal keyboard is the HHKB and the Fn key mappings match most of the HHKB’s. The trackball didn’t bother me too much, worked fine more or less, but I use ratpoison instead of a DE (not a very mousey UI) and most of the coding I do is either acme (somewhat mousey editor) or vi. I did stutter some when writing SQL or chatting with people, but for the most part, I’m close enough to regular typing speed on it that I can stop noticing the keyboard.
Assuming it’s not all due to the complicated setup, there was a thread somewhere around here about the CM4 defaulting to using the onboard antenna and ignoring the one that is actually plugged into the board, which makes a bigger difference on the metal-bodied uConsole. Apparently, that can be toggled with a kernel parameter: sudo sh -c 'echo "dtparam=ant2" >> /boot/config.txt'. (There was some elaboration in the thread but I don’t remember which thread.)
I travel with the DevTerm or a linux laptop (depending on the footprint) At home I use a full size Logitech keyboard/mouse . The K3 keyboard and M585 mouse use a multiple dongle solution so that I can switch between the DevTerm and my W10 laptop using the same mouse and keyboard - with an external gamer flat screen I have a large enough edit space for visual studio or Spyder3… although most of the visual studio work is on the w10 laptop - recently I’ve reloaded two used laptops with the i86 variant of rasbian so all machines have the similar OS (except W10 the necessary evil)
Just came across this. Has been 2 years since last reply.
Within the last 2 years, has any updated in the community happened, which makes the uConsole even better, and easier to use as a personal computer?
if you can use cm5 as main computer – you can use an uconsole too.
up to your tasks, I can’t (don’t want to) run arm as the main one.
I’m currently getting cm4 lite with 4 gigs of ram, but is it possible to in the future put the cm5 in the same adapter?
Yes the same adapter for the CM4 will work with the CM5.
how long does battery last on cm4 in uconsole, I have two 2600mah 18650 cells I have from my PicoCalc, I just want to know how long it will last. And also, does the uconsole work off straight usb C power?
Yes it’ll work off only mains and those batteries should last 4-5 hours if in good condition.
I find this remark very elitist. A CM4 won’t work just as well?
There’s no shame in not having the latest and greatest, especially when they come with outstanding issues.
What matters more for the question is: What do you do on your desktop that you would like to do on the handheld?
- Do you do mostly office work? Do you have a sane number of browser tabs open?
- What generation of games do you play? Are your games graphically demanding?
- Do you compile programs on your Raspberry Pi? How fast do you need those programs to build?
- Do you plan to connect your uConsole to a larger screen? How large are the videos you watch?
- Do you plan to edit pictures and video with it? (Is that even possible?)
- Are you into amateur radio?
- If you choose to get a CM5, can you live with its issues? (Force shutdown doesn’t work, speaker noise on lower battery levels, spotty initial SD card support, a few others I may have missed out on)
Hmm, did not really come across as elitist tbh. In fact, the question answered by WRS was if there were any updates in the last 2 years, which would make it more usable as a (main) personal computer. And the CM5 released in that time.
And beside that, i think its still reasonable. While you certainly can use a Pi4 for a lot of desktop stuff, as a daily driver it will probably get annoying in the long run. And not even talking about the fact that you could get a mini PC with more capabilities for the same price as a CM4 and the Uconsole itself.
Edit: And dont get me wrong, i absolutely love the concept of the Uconsole, but would never advise it to someone as their main device.
Well for me I do the following:
- Moderate web browsing (google searching, bit of youtube, 3 tabs open max usually)
- Programming (in C and python)
- Retro gaming
(I didn’t upgrade to CM5)
even CM3 will work if you have to, but I find browser experience on CM4 very annoying. It works, but it doesn’t work well.
I wouldn’t like to run browser + IDE and switching between them all the time. what if you need to have multiple browsers? virtual machine? multiple dockers?
and max 8gm RAM for daily driver? Depends on tasks.
> free -m
total used free shared buff/cache available
Mem: 31Gi 16Gi 611Mi 3.8Gi 17Gi 14Gi
unfortunately, even old refurbished thinkpad has more juice in it for the price of uconsole.
gpd mini laptop has much more juice if you have some extra dosh and need small footprint.
and even idea of typing on uconsole’s keyboard full time makes my thumbs sick.
To be fair, I’m wrong to impose my level of patience on everyone. But honestly, I do experience moments where the CM4 isn’t enough.
- You can display a second screen in 4K, but good luck doing any work beyond that.
- If you want to play smooth 1080p videos, you better be comfortable with commanding
mpvon TTY. And you need--profile=fastto pull it off. - I sometimes run a reimplementation of Adobe Flash called
ruffle, and the performance can slow to a crawl. But that can also be chalked down to the fact that the program is pre-alpha (way too early days). - It would not be wise to video chat over Discord with the CM4. I tried it for 15 minutes, then fell back to the phone after. This probably also rules out Zoom. (Though I want to try that too.)
I feel watching YouTube on a CM3 can be painful. So yes, definitely the CM4, at the minimum.
I’ve composed office documents in a pinch with it. Some browsing (up to 6 tabs), installing apps the hard way (because I use Arch BTW), running Android,… For most of the tasks I do, I feel I’m not missing out in running a CM4 with 8GB RAM. (I totally recommend this model, especially for considerably light desktop use.)
That’s what you do with your desktop? No wonder the CM5 is a shoo-in for you.
