Kali 7.1.y for the uConsole and DevTerm
It seems on the blog that frame injection is indeed a bit unstable. Maybe running airmon-ng check kill will help? Also there’s a tip and trouble shoot section there but you might have already tried them.
PS: I ordered a CM5 board too but it is taking way too long to arrive.
Hey Dave, I got the cm5 today, and after some tinkering frame injection is working! Although I haven’t have success with angryoxide yet due to unknown reason, I was able to creating fake access point and with mdk4. The only downside is that I have to keep reloading the kernel module to properly enable monitor mode. I wrote some aliases to make reloading the kernel module and enabling, disabling monitor much quicker. I would say this is quite acceptable level of success!
PS: I am on 6.12.67.
I just created an account here to say “Thank you!” this was the exact fix I was looking for!
Weird that the update sent all the files to /boot/firmware instead /boot..
I had to:
  1. Remove the drive from uConsole
  2. Plug the drive into another machine
  3. Mount it
  4. Copy the files from /boot/firmware to /boot
  5. Copy the files from /boot/firmware/overlays/ to /boot/overlays/
  6. Umount the drive
  7. Put it back into the uConsole.
After that it booted right up!
Now I just need to figure out how to get meshtasticd installed into kali-linux… :woozy_face:
Hi, bro, you’re doing great things! Maybe you can help me figure out my problem? I installed Kali on a uconsole + hackergadgets upgrade kit vs. AIO V2, CM5 on an SSD. Everything was fine, but when I’m working in the terminal, the computer freezes for a few minutes, then runs a couple of commands and freezes again.
Not sure I don’t use Kali I just made the image compatible. Kali isn’t really made to be a daily driver, it’s supposed to be a distro you boot use the tools you need and then go back to your normal OS. Kali has tons of stuff installed and is really bloated. I would say you’re better off installing the tools you need on something like Debian Trixie.
I’m using your bookworm image, and everything works! I just thought Kali had a ton of pre-installed software, and I wanted to play with it.
rex you are such a beautiful person, and your work is amazing!
Not sure why everyone keeps saying “kali is bloated”. Sure it has a bunch of stuff installed, but it has less running processes than a stock debian install. Until recently they had a dedicated developer just for arm devices.
After all that is said though, kali is based on debian-testing, so stuff may break.
Thank you! Appreciate you brother, you’re one beautiful soul!
When I update your kali image, it fails to properly update and doesn’t boot properly. How should I fix it?
If you have a micro hdmi cable you can plug that in, it’s likely the kernel got overwritten so the screen driver is gone
You can fix that by reinstalling rex’s kernel package clockworkpi-kernel
Then I should check that when I use kali next time…
Hi
CM5 uConsole - Kernel Panic on NetworkManager restart & APT Upgrade Breaks Bootloader/Kernel
Hardware Configuration:
  • Device: ClockworkPi uConsole
  • Compute Module: Raspberry Pi CM5 (Wireless version) [pi5] + NVMe
  • OS / Distro: Kali Linux (Rex’s community port for CM5) [pi5]
  • Storage: MicroSD Card
CRUCIAL UPGRADE BUG (APT Upgrade Breaks Boot):
  • Major Issue: Running a standard system update completely destroys the installation. Every time I execute sudo apt update && sudo apt upgrade -y, the system becomes completely unbootable (stuck on a green power LED with a black screen, no HDMI output, no display backlight).
  • Cause: The official Kali ARM repositories overwrite the custom kalipi-kernel, kalipi-bootloader, and custom overlays provided in Rex’s image with generic Raspberry Pi 5 packages. The new kernel fails to initialize the uConsole hardware. The only way to recover the device after an upgrade is to completely re-flash the MicroSD card with a fresh image. Even pinning the packages via apt-mark hold is problematic because the system throws candidate/installation errors for kalipi-kernel due to its state.
Description of the Wireless & Kernel Issue:
Even on a completely fresh, un-upgraded installation, the wireless stack is heavily broken and triggers a hard kernel deadlock:
  1. Initial Boot & Peripherals: On a fresh image, the internal DSI display and keyboard were uninitialized. I patched this in Windows via config.txt using dtoverlay=clockworkpi-uconsole-cm5 and dwc2,dr_mode=host [pi5].
  2. Wi-Fi Authentication Loop: The desktop environment detects the wireless interface (wlan0), but attempting to connect to a 2.4GHz WPA2 network via the GUI nm-applet results in an endless prompt loop asking for the password.
  3. NetworkManager Properties Missing Error: Bypassing the GUI and using nmcli to connect (sudo nmcli device wifi connect "SSID" password "KEY") throws this specific error:
    text
    Error: 802-11-wireless-security.key-mgmt: property is missing
    Kód používajte opatrne.
    Using nmtui causes the available network list to go completely blank.
  4. Kernel Panic / Hung Task Deadlock: Attempting to force a restart of the wireless service using sudo systemctl restart NetworkManager completely freezes the operating system. The CPU cores enter a permanent deadlock (blocked for more than 121 seconds), turning the uConsole into a brick until a hard power-down is forced.
Console Logs & Call Traces:
1. Wireless Status (iwconfig):
text
wlan0     IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=-31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
2. Kernel Stack Trace (Hung Task Dump during NetworkManager restart):
text
INFO: task sudo:28223 blocked for more than 121 seconds.
      Not tainted 6.12.67-v8-16k+ #4 (or similar 6.x re4son kernel)
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
task:sudo           state:D stack:0     pid:28223 tgid:28223 ppid:1    flags:0x00000005
Call Trace:
 __switch_to+0xf0/0x150
 __schedule+0x394/0x860
 schedule+0x5c/0x140
 __schedule_preempt_disabled+0x2c/0x50
 __mutex_lock_constprop.0+0x2ac/0x988
 __mutex_lock_slowpath+0x1c/0x30
 mutex_lock+0x50/0x58
 rtnl_dumpit+0x94/0xd0
 netlink_dump+0x134/0x378
 netlink_dump_start+0x25c/0x350
 rtnetlink_rcv_msg+0x280/0x3b8
 netlink_rcv_skb+0x68/0x140
 rtnetlink_rcv+0x20/0x30
 netlink_unicast+0x330/0x3b8
  Job session-2.scope/stop running (1min 21s / 1min 30s)
Conclusion:
This image is currently unusable for daily tasks because 1) standard apt upgrade destroys the kernel/bootloader configuration entirely, and 2) the Broadcom brcmfmac wireless stack triggers a hard kernel panic when interacting with NetworkManager security properties.
Is there a newer repository layout, a working apt-preference blacklist configuration to block the upgrade overwrite, or an updated kernel tree (6.6.y / 6.12.y) that actually works reliably on the CM5? Any advice would be highly appreciated.
