Have you ever been in a situation where a PC game requires a Gamepad but you don´t have one? Then you look at your Gameshell and think “I wish I could use it as a gamepad for my PC” well those days should be over.
I present you MVGE, a gamepad emulator for the gameshell.
How does it work?
It captures keypresses from the gameshell and sends them by network in an UDP message. And probably you are thinking, cool but how do you send the keystrokes to the OS? You need a client on the pc which maps the UDP messages to actual kestrokes, that client is called MVGE Mapper
You can find the source here:
How to install?
- On the CPI
- Download the latest release from releases
and run tar -zxvf MVGE-x.x.tar.gz -C /home/cpi/apps/Menu/ on your CPI.
- You should have the Qt libs but if you don´t you will need to instal them:
sudo apt-get install libqtcore5 libqtgui5 libqtnetwork5
- On the PC
Currently only supports Windows! Now Supports Windows,Linux(X and Wayland) and MacOS!
- Run the .exe (It is portable, no installer yet)
Usage:
By default it uses usb-eth and port 3000. I recommend using the usb cable but if you wish you can also use wifi, in the launcher directory you will find a file named config.ini
[General]
iface=usb0
port=3000
If you wish to change the interface to wifi, you should replace usb0 with wlan0.
Change the port number to any port you wish (Remember to use the same port in the Mapper)
Demo video:
DISCLAIMER:
Consider its current state as a beta! Expect bugs. I would love to hear suggestions and fix any bug you find.
This is some fresh amazing content. I would be the first off the bat to try, if I had a windows computer! Argh!
Looks like dual booting time!
I’m almost thinking; expanding upon this, using something similar to the Logitech G15 displays. Remember this keyboard?
Would be useful for say, synchronising it with events/timers within an MMO, or to be used as a macro management console/programmer.
Hmm never had this keyboard, but as its built right now, you can use as anything, not only a gamepad, just map the keys you wish your gameshell to send to the OS!
Good news! MVGE-Mapper 1.1 1.2 is out! appart from some improvements it brings Linux support!
There is a release for x64, if you need x32 you would need to compile it from source.
As for MacOs… I added some development but I don´t know if it will compile or even work properly, currently I don´t have a Mac and I never used one.
Edit:
Fixed crash and incorrect key bug from 1.1 in 1.2
I am back here bringing good news, from today MVGE Mapper supports Windows, Linux (Both X and Wayland) and MacOS!!!
Unfortunately providing binaries for every system is pretty difficult, in particular MacOS as I don´t own a Mac but you should be able to compile it painlessly if you have Xcode and Qt5
You only need to clone the repository and
cmake CmakeLists.txt
make
Thats all!
Source: GitHub - Mihaylov93/MVGE-Mapper: Maps MVGE keypress to Keyboard keypress and sends them to OS.
Tested on Mac OS Sierra (version 10.12)
Enjoy!
This opens up the gameshell to be able to do much more!! I will try it when I wake up.
Out of interest, can you map a modifier + a key, eg, CTRL + C or something. And of even more interest, what about macros?
Not just for gaming, but having the gameshell as an external customisable interface can make repetitive automated tasks easier, eg mass photo editing/post processing in adobe Lightroom. It could also be used in audio and video editing software to shuffle between sequencing tracks.
I’m getting excited about this! Nice work!
It is possible but not implemented.
And for macros and other things, should be fairly customizable. Mind that under the hood MVGE sends UDP messages, think of that as an API, so basically anyone could writte in any language “receivers” (thas basically what MVGE Mapper is) and customize the behaviour on a received message.
MVGE sends the keypress through UDP with the following format
Key_[name]:[n] where name is the name of the key and n is 1 for key pressed, and 0 for key released.
For example
Key_Up:1
The key names come from Qt, you can check all the valid names here MVGE/mainwindow.cpp at master · Mihaylov93/MVGE · GitHub
For example Qt::Key_Escape, would be Key_Escape in your UDP message
I forgot to add, it should work best with the modifications of the keypad https://github.com/Mihaylov93/Keypad/commit/f7688a3190c28872b7a8eb1f481e27011257a820
But I have no data to support that statement.
