the lights on my lightkey light the buttons no longer respond. what do I do?
First, check the cables and the board if anything looks weird or is loose. Then check if the pins are all still straight and that you didn’t bend any when connecting them.
Login with SSH and run sudo showkey. Press keys and check if there’s any output from the lightkey (see my screenshot, it should look similar)
