New Batteries for Higher Current
I’ve been using Panasonic batteries in my uConsole but have had a few crashes when plugging my F0 into the USB-A. I figure it must be because the Flipper is drawing current to charge as it is also connecting for data transfer, so I am thinking of replacing the batteries with either Samsung 30Q 18650 3000mAh 15A or Molicel P28A 18650 2800mAh 35A. I know that 35A is a little overkill and the Samsung can reach 20A under regular operating temps, so it is almost a toss-up which to order. Does anyone have suggestions?
I recommend these, I get 5-6.5 hours of use.
Bought! Thank you for the suggestion.
Button tops or flat?
I use flat tops, button tops fit but its a little tight for my taste.
