It’s common issue, 18650 battery…
Which brand do you recommend ? I know Panasonic, Samsung are good. However, they are cell, not purchase directly. Hopefully, let me know Amazon URL is the best.
Thanks.
Osamu
Thanks.
Osamu
There was a topic about batteries already here Batteries compatible with Uconsole - #2 by Daeraxa
Thanks a lot !! ![]()
I’ll try it.
Osamu
2500mah 35a 3.7v Are high discharge batteries harmful to machines?
In general, no. Amps are “pulled” by the system (at least for digital/regulated systems like the uConsole), so the amperage rating (e.g. “35a”) is more like a “max speed” rating. Your uConsole will likely never draw more than a few amps, split between both batteries.
That being said, as an electronic cigarette user (who uses a lot of 18650 batteries) I’ve not heard good things about the EFEST brand. I’d recommend checking Mooch315’s recommended list (he’s an electrical engineer who is a trusted reviewer of batteries in the e-cig world).
You probably want to choose:
Thanks for the great answer. I also use e-cigarettes, so I was wondering if it would be possible to use it because there are many 18650 batteries.
I have had very good luck with battery junction. They have a wide variety of cells. I would recommend using protected cells. I personally use the 3600 MAH with protection.
no protection circuit size : 65mm(H)
protection circuit size : 69.5mm(H)
Are there any problems with the mounting size?
We carefully designed the battery holder to make it more compatible with various 18650 battery sizes: Φ18±0.5mm diameter, 65-69mm length.
(that’s from https://www.clockworkpi.com/uconsole)
I ordered these as they are protected and within the 69mm limit.
If you can manage to get a branded old style laptop battery (black casing, more or less cylindrical outline) and safely disassemble it with care, that would give you best quality battery. Be extra cautious to not short any connections/terminals during the disassembly.
I also have LiitoKala! but mines are the good old green ones. What I have experienced with Liitokala is that they have an aditional transparent wrapping that makes them a bit thicker, they fit on the devterm but makes it bulge a bit.
Bought Liitokala too, but until Uconsole arrives, is stored in my cabinet. Never used this type of batteries before, is it recommended buy a recharger and charge it meanwhile?
Most of the reputed brands ship them with the ideal amount of charge for long term storage of the batteries. Hopefully you should be fine without any recharging/discharging for a while.
In Chinese we say we already have the vinegar, where ia the dumplings?
Long-time “vaper” and flashlight nerd here and even though I probably won’t get my uConsole for a very long time I want to hand some warnings.
do the batteries need to be “button top”?
