This just happened to me puff of smoke so people take this serious and use clapton tape and tape up as shown here replacment on the way thanks to @vileer
The Samsung 58E 21700 is rated for up to 10.7 A of continuous discharge per cell. Think of that as how much current it can supply when needed—the uConsole only draws what it needs. With two cells in parallel, they share the load, so this rating alone shouldn’t limit performance.
If you run demanding workloads, I suggest looking for batteries with a higher continuous discharge rating, such as 20 A. This may help prevent shutdowns caused by voltage drops under heavy load, especially as the batteries run low.
Config.txt:
#Samsung INR21700-58E — 2 cells
dtoverlay=clockworkpi-custom-battery
dtparam=charge_full_design_uah=10660000
dtparam=energy_full_design_uwh=38802400
I hope this helps.
Excellent. Glad I didn’t completely waste the money. I don’t imagine I’ll be doing anything overly demanding. I’m mostly going for longevity than heavy workload. I am new to this “hobby” so I’ve been reading the forums and I was interested in the 21700 upgrade. This board is a wealth of knowledge and I really appreciate the help. Thank you.
john@clockworkpi:~ $ upower -d
Device: /org/freedesktop/UPower/devices/line_power_axp22x_ac
native-path: axp22x-ac
power supply: yes
updated: Sat 17 Oct 2026 08:06:51 AM EDT (4 seconds ago)
has history: no
has statistics: no
line-power
warning-level: none
online: no
icon-name: ‘ac-adapter-symbolic’
Device: /org/freedesktop/UPower/devices/battery_axp20x_battery
native-path: axp20x-battery
power supply: yes
updated: Sat 17 Oct 2026 08:06:54 AM EDT (1 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: discharging
warning-level: none
energy: 11.16 Wh
energy-empty: 0 Wh
energy-full: 11.16 Wh
energy-full-design: 11.16 Wh
energy-rate: 0 W
voltage: 4.057 V
charge-cycles: N/A
percentage: 100%
capacity: 100%
technology: lithium-ion
icon-name: ‘battery-full-symbolic’
History (charge):
1792238754 100.000 charging
1792238754 0.000 unknown
History (rate):
1792238811 0.000 discharging
1792238784 1.597 charging
1792238754 1.472 charging
Device: /org/freedesktop/UPower/devices/DisplayDevice
power supply: yes
has history: no
has statistics: no
battery
present: yes
state: discharging
warning-level: none
energy: 11.16 Wh
energy-rate: 0 W
charge-cycles: N/A
percentage: 100%
Daemon:
daemon-version: 1.90.9
on-battery: yes
lid-is-closed: no
lid-is-present: no
critical-action: PowerOff
need help in figuring what’s wrong
The counters don’t seem to be working. Try the procedure I described above. If you’ve already set the battery parameters correctly, try forcing the counters to reset.
energy-rate: 0 W
charge-cycles: N/A
Note: NEVER leave two sets of battery parameters enabled at the same time. Delete or comment out the parameters for any other battery.
Wellcome to the forum, @Uncle_Revv!
These batteries are a very good choice.
A CM5 draws a maximum of 5 watts. An NVMe drive draws a maximum of 12 watts. That adds up to 17 watts. 10 amps at 3.6 volts equals 36 watts. That leaves another 19 watts for the display and peripherals - and that’s with just one battery.
If you use two batteries in parallel, you’ll have a maximum of 72 watts. You’ll never need batteries with a higher continuous power rating in a uConsole. Even the pcb’s traces couldn’t handle that current.
In my experience, switching to batteries with a higher discharge current rating stopped my uConsole from shutting down under load. The point is voltage stability during sudden power demands from the CM5, NVMe, and radios. Even when the average consumption is comfortably below the battery’s rating, voltage sag can still trigger a shutdown -
HG themselves mentioned this issue, and it was one of the reasons they developed this new 21700 battery pack.
Higher-rated cells can help when they have lower internal resistance, keeping the voltage more stable during those peaks. They don’t force extra current through the PCB—the uConsole only draws what it needs. So while the theoretical wattage is useful, the battery’s behavior under load matters too.
Note: I’ve been using batteries with a higher discharge current rating since I was using 18650 cells, and that had already solved the shutdown issue back then. What I gained from this new pack was simply longer runtime.
Yes, this is especially true for low quality cells.
But high end brands like Samsung, LG etc. stick to their specifications. The 58E cells are specified for 10 A continuous (!) and 15 A peak.
At 10 A (and especially 20 A for two) the AXP228 becomes the bottleneck before the voltage of the Samsung 58E drops.
Do I insert this text between the existing lines?
Has anyone tried a dual m.2 2230 adapter/riser card on the new 21700 battery holder? Something like this: https://www.aliexpress.com/item/1005012457730735.html. Just wondering if it’ll fit under the batteries and allow the case to close. Thanks!
I haven’t actually opened up my uConsole with the 21700 battery board, but as far as I remember, the NVMe just fits next to / underneath the battery. I’m afraid a taller structure won’t fit.
The short answer: I have absolutely no idea. The description sounds promising, but I don’t know whether this adapter would work in the uConsole with the CM5 and the HG 21700 board. We’d still need to confirm whether the SSD and Wi-Fi would work together, how to connect USB for Bluetooth, and whether the power supply could handle everything, plus consider space, heat, power consumption, and kernel compatibility. The only way to know would be to buy it and test it, but I wouldn’t buy it assuming it will work.
Send HG an email and ask. They guarantee compatibility with SSDs, not adapters.
Uncle_Revv You can put it after the last line in the [all] section.
3D Print file:
AC1200 Holder for HackerGadgets Dual 21700 Battery Board
I updated Neil G7UFO’s holder to work with the newer board. This version has you running the wires up the right side up a ramp. If you prefer to route them up the left side, you can chop off the left side of the board (and screw mount) and hold it down with double sided tape instead of screwing it down, or create a channel.
Warning: when running the AC1200 and Dual 21700 Board, you must cover the components on the battery board with Kapton Polyimide electrical tape to prevent the antenna connector from touching or breaking components off. I recommend placing double sided tape on the back of the holder to keep it from sliding down when you pull out the AC1200. Be very careful when installing not to damage the battery board.
https://makerworld.com/en/models/3474676-uconsole-ac1200-holder-for-hg-21700-battery-board
PSA sometimes the the tape isnt enough. Good thing the battery board is still alive even after the smell of magic pixie dust from im guessing the capacitor and not the wireless card. Wireless card still also works.
这是磨穿了么?看来最好用厚一些的绝缘材料。
I was working on the NVMe, changing it multiple times so I may have worn through the tape with all the movement of plugging and removing the wireless card. But yes, add more layers of the insulating tape, dont just use one. Added insulating foam in between also.
I have tried your method for the EVE 58E two cells in parallel. After reset the counters by remove the battery for 30 min, the counters seem to work, but I found that when the battery voltage dorps to below 3.3v, the counters still say that there is about 20 percents of energy left, however, the back light of the screen and the I2C from the PMIC stop working, you can only ssh or vnc into the uconsole to reboot it, and the calibration of the battery gauge is also lost since we lost the I2C of the PMIC.
I’ve used some AI tools to diagnose this issue, and they both suggested that the power of the I2C of the PMIC and the black light of the sceen are directly from the 3.3v LDO on the PMIC, and when the battery voltage is down below 3.3v, the voltage from from the PMIC LDO rail can not support the i2c bus and the blacklight, so we lost the communication of the PMIC, also lost the reading of the battery gauge. And since before the PMIC dead, it says that there is still about 20 percents of energy left, the operating system is not powered off automatically from low battery, since there is no signs of low battery.
Have you ever been into this situation ?
I’m trying to lower the capacity settings of this battery pack, like 36wh instead of 41wh, to see if when the battery voltage drops below 3.3v, whether the battery gauage will also indicate low battery to the operating system to issue a safe shutdown.
and by the way, despite the inaccurate battery indicator, two 21700 cells in parallel indeed can extend the battery life, I can get about 3hours on 9watts of load with 4k video streaming and sdr receiving together.
I switched from the EVE 40PL cells to the M50Ts just for tests, I started seeing the same issue again: the uConsole shutting down abruptly at around 20%, despite having more nominal battery capacity. My suspicion is that, at that charge level, a power spike causes the voltage to sag enough to trigger the power cutoff. From what I’m observing, in my setup, the ability to deliver current and maintain voltage seems to matter more than simply having more mAh when trying to use the battery down to around 1%. I still need to take measurements to confirm this, and the displayed percentage also depends on calibration.
The EVE INR21700-40PL cells are designed for high discharge, with 4,000 mAh per cell, giving a parallel pair 8,000 mAh and approximately 28.8 Wh. Their specified maximum discharge is 70 A per cell, subject to temperature cutoff. The LG INR21700-M50T cells focus on capacity, offering approximately 5,000 mAh each, or 10,000 mAh and 36.4 Wh per parallel pair, but with a maximum discharge of 7.275 A per cell between 25 and 55°C, or 14.55 A between 10 and 25°C. This suggests that, although the M50Ts store around 26% more energy, the EVEs have more current-delivery headroom and may maintain voltage better during power spikes. That could help explain the shutdowns at low charge levels, although measurements would be needed to confirm it.
Well, I’ve decided to switch back to the EVE INR21700-40PL cells because these shutdowns are driving me nuts. I’d rather have stability than extra capacity. With the EVEs, I can get down to 1% without it shutting down.
Well, I’m going back to the cells with the higher discharge rating. I suspect temperature COULD be a major factor, but I’d rather be happy than right, so I’m switching back to the EVEs. Keep in mind, this is my setup, with my workload. These observations apply to my case, not necessarily to everyone else’s.
