New Hacker Gadgets Dual 21700 Battery Holder
A battery may deliver 20 A for a few seconds. Sustaining 20 A means maintaining that current under load while keeping the voltage high enough for the device to operate. As the battery discharges, its voltage drops, and a sudden spike in power draw can cause a momentary dip called voltage sag.
In a uConsole, a cell with a higher continuous discharge rating, such as 30 A or 40 A or more, today a using 70 A, tends to have lower internal resistance. For the same current spike, that usually means less voltage sag and more headroom to keep the uConsole running. mAh tells you how much charge the battery stores. A tells you how much current it can deliver. Check the continuous discharge rating in the datasheet. A “70 A” label may refer to peak current only.
With 20 A cells, my uConsole shuts down under heavy load at around 23% charge, when the voltage drops to roughly 3.20 V. Several people here have reported the same thing, and yes, I measured it myself. It happens. The exact point depends on how you use your uConsole, how you built it, and what you’ve installed inside.
Temperature matters too - If the CM5 hits its soft temperature limit, vcgencmd get_throttled records it with the 0x80000 flag. When a cell gets too hot, the amount of current it can safely deliver goes down. Low-quality cells come with added risks. Just look at the discharge and temperature limits in the datasheets for reputable cells.
As for me, I’m done using cells rated at 20 A or less in my setup. That’s based on what I actually measured. It’s why I built the tool in the first place. You can’t control what you don’t measure.
The point is, I fixed the same problem the same way with both 18650 and 21700 cells. Regardless of how much charge the cells could store, what made the difference in my tests was how much current they could sustain under load. That’s what I saw firsthand. I had the same problem twice, and the same fix worked both times.
That said, everyone builds and uses their uConsole differently, so what worked for me may not apply to every setup. Mine runs at around 38°C on the CPU and 41°C on the RP1 because I built it to run at those temperatures. Playing around with demanding workloads on it is part of the fun for me.
Note: If you’re using a cell rated below 20 A that can sustain 7 A or less of continuous discharge (check the datasheet), and get_throttled has logged 0x80000, watch what happens when the voltage dips below 3.20 V during a load spike. Poof. That’s when my uConsole shut down. I am happy, I solved this.
your uconsole-thermal-mon-v3.7.sh sript is no longer on LimeWire. Is it available somewhere else? Thanks
Try again..same link above.
Error 410
This Link No Longer Works
The files behind this link are gone. A share stops working once the person who created it deletes the files or the link expires.
I would recommend to use gists at github
I’m old, and old guys have their quirks. :grin: Feel free to fork it. I built this project to solve a specific problem I had. It did what I needed, and I don’t have the time or inclination to maintain it.
that’s the beauty of gists: it’s not a proper repository, just a single file with syntax highlight
may be i can push in github if you like
Thank you, I will try it out.
