I think is noticeable because the screen is rotated 90degrees maybe I need to screen the refresh rate?
Hi Trinity,
it was on youtube 720p fullscreen or Mednaffe fullscreen
was some vertical tearing on the thirds of the screen
but now I did something and mess up the screen settings.
I think now only have external screen. Not sure what I did
what is a ps output I know a little of bash
anyone can show me a normal config.txt i think this one is mess up
Here you go
I had good results getting rid of tearing by enabling Wayland. I believe itās still listed as mildly experimental in raspbian though, and comes with all the usual wayland caveats.
Use āraspi-configā in the terminal, then go to Advanced->Wayland and enable.
Nice, which caveat ?
I donāt have my uConsole yet, but I tried activating Wayland on my DevTerm and one thing I noticed was that it broke the VNC server I had setup on it. Disabling Wayland caused the VNC server to start working again. So maybe thatās one of the caveats. ![]()
Yeah, absolutely - if itās something that interacts with the screen (especially if itās X11 specific) it may simply not work, or be buggy.
For myself so far I noticed that tic-80 fullscreen freezes the display under wayland, and I had to press F11 to go windowed to use it.
If thereās as solution to tearing that doesnāt involve using a slightly more experimental feature like wayland on the pi Iād love to hear it.
Thank you, this solved the issue with the screen not rendering. ![]()
now ill try to check about the tearing again ill place photos
correct config.txt
disable_overscan=1
dtparam=audio=on
[pi4]
max_framebuffers=2
[all]
ignore_lcd=1
dtoverlay=dwc2,dr_mode=host
dtoverlay=vc4-kms-v3d-pi4,cma-384
dtoverlay=devterm-pmu
dtoverlay=devterm-panel-uc
dtoverlay=devterm-misc
dtoverlay=audremap,pins_12_13
dtparam=spi=on
gpio=10=ip,np
dtparam=ant2
enabling wayland get rid of the tearing in youtube, but emulators stop rendering images
solved
the render need to be done by softfb no opengl
no tearing in emulators now
Hello, my friend. I encountered a similar issue where the screen tearing was particularly noticeable when the screen pixels changed vertically. I followed the steps mentioned above to enable Wayland and modified the config.txt file. However, now Iām experiencing video playback freezing when in full screen mode. Have you encountered this issue as well?
