Photos of the main board show a dual pcb switch SW701 with no apparent lable or reference in the assembly manual… What is this for ?
Seems to be some kind of boot selection/debug option.
Just a guess: one puts mcu into programming mode, and the other one (100% guess) selects which microprocessor’s serial goes to the USB-C port
I lied. The first switch toggles boot mode of the stm32 as well as connect its serial to the serial<->USB chip. The second switch is to switch the actual USB-C port connection between the serial<->USB chip and the stm32 (has its own USB interface).
So depending on which way you need to program the stm32, one or both switches must be flipped.
This would make a great addition to the wiki: PicoCalc/wiki at master · clockworkpi/PicoCalc · GitHub
If you have the time to setup a PR that’d be great, otherwise I’ll try and remember once I get ramped up. (not affiliated, just enjoying)
