PicoCalc NES Emulator Issue
Hello! I’ve just recently received my PicoCalc. I’m trying to use the built in NES emulator, but having trouble opening it. The github repo doesn’t have a guide for the emulator, or at least I can’t find it. I have the Pico 1 H that comes with it, if that would contribute to anything. Thanks
Where did you find that there is a built in nes emulator?
In Stock SD card
there is a PicoCalc_NES_v1.0.uf2
also you can get it from here
put Your Pico 1H into BOOTSEL mode by pressing the BOOTSEL while Power on
then put this uf2 file into Pico 1H usb disk
here is also a reference video
Thank you. Does this also work on the pico 2?
pico2 version NES uf2 is here
Thanks! I thought that I could open all the different software from picomite.
