PicoCalc2.... just dreaming
  1. 64-pin 2350 with ceramic heatsink running at 358Mhz minimum. 16Mb flash.
  2. full internal and external access to ALL unused pins and keyboard controller functions.
  3. Rear latching ‘tough’ connector with gold plated pins (such as Canon d-type yet obviously smaller).
  4. Onboard internal i2C Stemma QT/Qwiic connectors (say 6).
  5. Internal i2C mounting (say 6 small modules). Either on platform above main board or on rear case. i2c running at highest "stable’ clock, maybe 20/40Khz (vs PicoCalc’s 10Khz).
  6. Onboard DS3231 rtc with easy access lithium battery.
  7. Onboard 8/16/32Mb permanent and fast FRAM via i2C.
  8. Fastest possible LCD with touch panel (same resolution yet easy access display modes for speed or quality choices).
  9. Gameboy style additional buttons.
  10. Higher quality audio circuit with full 320Kbps mp3 and flac file playing. On board quality amp and 3.5mm headphone socket.
  11. Larger, higher quality internal speakers. Front/side facing with better stereo separation.
  12. Better STM32 keyboard controller with ‘easy access’ ability to run user code alongside its main functions. Higher ‘stable’ i2C clock (say 20/40Khz vs 10Khz of PicoCalc).
  13. …..
All quite possible with what is available today…. Your turn !
I would add:
  • Durable replacement for screen taping
  • Non clicky keyboard
  • Smaller form factor
  • Higher screen resolution and option for DPI interface
  • I2S audio
  • FPGA (for example for implementing your own GPU)
It would be difficult fitting anything in with a smaller form factor !. Higher screen resolution = lower performance.
Have you seen Peter’s (creator of PicoMite BASIC) design for a handheld PicoMite? It incorporates some of your wishes:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=18161
Sure have but its a little big and unfinished right now….
I don’t know what that board is you pictured, but I imagine I can’t get one from Amazon for $15 shipped and have it tomorrow. The main advantage of using a Pico/Pico 2 is they are common, cheap and you can get them anywhere. Plus, when the Pico 3 arrives, it will likely be pin compatible and a drop in replacement for a Pico/Pico 2. I’d stick with the Pico/Pico 2.
But I would like to see PSRAM that can actually be used with PicoMite Basic and an 8x10 matrix keyboard scanned directly by the Pico instead of this STM32 i2c hack they have going on here.
Hmmm Pico3, more flash, higher clocks hopefully. Why psram when you can have permanent and fast FRAM ?. That board is by the MMBasic guy !
I’ve got the same (crazy) idea! :stuck_out_tongue:
The design should be similar to the one Analogue used for their Pocket console.
The major bottleneck issue I’m facing now with the implementation is the interface with the pico… What should I use? QSPI? Hybride(SPI for instructions and parallel for datas)?
In fact, I wanted the GPU-HDL to be modular on the computer interface and the display (to handle multiple platform configuration, in this case QSPI (or else like I mentionned above) pico interface + parallel screen IO).
But for a first prototype, maybe I sould reduce the expectation to a simple SPI interface, as a PoC. And upgrade it later to something modular.
I would recommend using the conventionnal 100 kHz, this should ensure the compatibility over all the bus for every equipments you can find on the market!
And for the STM32, the STM32F4 series should do best than the F1 one. Can be used as an RTC too with cell battery on it and redesign of the power management.
Just being pragmatic about it, I guess.
I’m guessing from past conversations that 100Khz gave problems on the PicoCalc hence set at 10Khz, bad signal path maybe. My RTC will run at 200Khz…
Technically, the 100 kHz is from the I2C standard as the standard speed. 400 kHz for fast speed, 1 MHz fast plus speed, etc.
But at the same time, I had changed the frequency on both sides (Pico and STM32), and there were no issues. The path seems fine to me (even visually, there is nothing unusual about it).
I suppose the arduino-like lib in the official stm32 firmware mess up with the I2C timing. And I suppose CW team patch everything by reducing the I2C bus frequency.
So for me, 100 kHz or 400 kHz shouldn’t be an issue… Especially if we redesign the motherboard/picocalc like you suggest.
I forgot to mention that the big problem with FRAM is its architecture, which requires writing after reading. This can pose a significant risk of data corruption during operation if used as processing memory.
EDIT: From what I see on FRAM from infineon, the auto-write seem done inside the chip after a read from the user, and a ECC correct can correct 1 bit over 8 bytes in case of corruption. 2 bits errored aren’t corrected and only flagged in the status register.
I’m still curious to see the error counts per million reads.
Might be worth testing. But the largest capacity I can find is ~2 MB (16 Mbit).
At work, we replaced the EEPROM with FRAM to reduce power consumption. This was very useful!
Ok, ill play.
Id like something like the Teensy 4.1 capabilities at Pico prices, Id also like at least 2 onboard DACs, and the ADCs able to keep up with higher clock speeds, a few times Iv overclocked just fine, until I tried the ADCs and had to back off the clock speed to get it working again. I`d also like 8 ports again like in the PIC chip and Atmega days.
I had a nice read of Game Bub: open-source FPGA retro emulation handheld | Eli Lipsitz which uses a FPGA along with an ARM chip.
Anyone seen a pico form-factor board with an FPGA next to a SOC?
Havent had a chance to look at this too closely, but the board-to-board pinout would need to be dealt with. There’s a schematic available so it might be easy for someone to redo the PCB layout/pinout and make it specific to the PicoCalc. If there’s interest I could get started in a few weeks, I’ve been too busy for something like this lately.
Interesting, shame it has only 4mb flash when some tout 16mb. Might be limiting in the future. Imagine MMBasic or other languages with much more wifi/bluetooth, Internet support ?. And where is the drop-in Pico3 ?.
The Pico 2 was released last year after the Pico had been available since the beginning of 2021. I think the Pico 3 is a couple of years away.
Fingers crossed it will be worth the wait and fully compatible. Last time Raspberry were questioned they showed no interest in a Pico3.…
Aha! With nano banana,it show’s something I really dream of
As my understanding,PicoCalc is trying to make something like comandore 64/ Apple 2 in your pocket.And Maybe PicoCalc 2 would be something Bring the Golden age of 90s back in the pocket
Hardware
  • 7inch 4:3 VGA Screen;VGA/HDMI Interface 32bit color
  • A multitouch switchable touchpad&touchkeyboard provide “labor-saving” input experience like modern smartphones;
  • Also the touchpad can emulate 2 Analog Joystic when in Games;
  • 3 x 18650 Battery module,can change to Lithium polymer battery;
  • A power saving x86 compute module,around Petium4 128M~256M RAM;(For those who want native ancient software)
  • Changable compute module,with 4GB + RAM;(For those who want modern software experience)
  • CF Card Storage;
Software:
  • Customized Linux with Retro OS Skin;(For those who desire a retro visual appearance, but are looking for accessible modern software)
  • Capacity to run OSs around 1990~2000;
  • Of course all DOS applications and Games,development environments etc;
  • Capacity to run those 4:3 aspect ratio console games with full speed and pixel perfect;
This is essentially were it stated.
And were I’m hoping we’re going again.
@DigitalDreams That’s you? https://youtu.be/RTIaGyquMR0
(because of the FRAM idea x))
