Any guidance on how to program the four arrow keys and the A, B, X, and Y buttons as hot keys for a key sequence? Specifically, I would like to program the left and right arrows to be the Ctrl-Alt-Left Arrow and Ctrl-Al-Right Arrow key combos used to switch between workspaces.
Thank you for your help in advance!
Definitely possible but it will need some modifications on the code, from a quick look I think possibly it will be over here DevTerm/keys.ino at 24f09a1781658b5804b166a8d9c5b6c2fc393790 · clockworkpi/DevTerm · GitHub
Adding some ifs to check for the keypresses and programatically sending the key sequence.
Is there a build guide for this custom code for the DevTerm and guidance on how to deploy it as part of a distribution install package?
On the fork by Godzil there is some pointers:
DevTerm Keyboard firmware
## Changes from official firmware:
- Fn + Trackball no longer trigger the "slow movement mote" but allow to use the mouse scroll wheel
(only up/down for now, need to find how to set for left/right)
- Now to set the trackball speed you use Fn + Left button for normal speed
- Fn + Middle button for "slow" speed
- Fn + Right button is currently an unused third mode that do the same as the normal one.
- Cmd now send LEFT META by default (left command or left windows key)
- Fn + Cmd send the RIGHT META Key.
- Fn + "-" (the key just on the right of the trackball) do send a volume mute key.
### Undocumented from the official firmware (and not displayed on the keyboard):
- Fn + < to send the brightness decrease key
- Fn + > to send the brightness increase key
For the brightness setting, as far as I can say, on the CM3 model at least, there is nothing to honour these key,
a deamon must probably need to be added for it to work.
This file has been truncated. show original
You can also program that in the keyboard firm
