Reading the SD card via usb?
Probably a non-starter but is it possible to read and write to the SD card via usb while in the PicoCalc ?. PC (Windows) just beeps if connected to usb-c or micro usb :expressionless_face:
I don’t see a reason why that wouldn’t be possible… but it would be quite slow. The Pico can emulate a removable storage (perfect example is the UF2 flashing method)… and the Pico can also read/write to the SD card. I imagine it’d be matter of mapping the two libraries together, which may already exist out in the world.
Another option, if using the Pico2 with wifi connected, would be to transfer the files wirelessly to the SD.
I haven’t had time to dig further into this, what with the apparent need for PicoMite updates to sync with changes to the latest RCs and my time spent doing that, but @TheKiwil has done some interesting work here. They’ve also apparently got the SD bootloader working with the Pico2 (it was originally only for the Pico), so that combined with their FTP app could mean we could load the FTP firmware dynamically from the SD, transfer files around, and then load the PicoMite firmware dynamically from the SD. Everything (Picomite, the FTP application, and other firmware like MicroPython, Lisp, etc.) has to be compiled specifically for the SD bootloader, and differently depending on the module being used, but it means you could only ever have to flash the Bootloader firmware once (and for any Bootloader specific updates) and then everything else can be loaded dynamically from the SD card. You lose a bit of flash space because the Bootloader has to be there, but you gain a lot of flexibility, and I think the tradeoff would be worth it.
https://github.com/TheKiwil/PicoCalc_FTP/issues/1#issuecomment-2842587066
More background info here:
@DigitalDreams: I just wrote a program that does this. check out the PicoCalc posts
I should remind people that @pelrun’s uf2loader does all this (loads UF2 files, supports accessing the SD card over USB).
yes, but it’s soooo much fun discovering this myself! LOL. I’ve learned so much about USB protocols this past week!
