I made an App that dynamically load firmware from SD Card
Picocalc_SD_Boot is a custom bootloader for the Raspberry Pi Pico.
This bootloader provides the functionality and GUI to load and execute applications from an SD card, designed to enable PicoCalc to load different firmware to the Pico using an SD card easily.
Current challenge is that:
Applications intended for SD card boot “must be recompiled” using a custom linker script to accommodate the program’s offset address. I will need to figure out a new memory mapping and doesn’t effect the existing standard firmware builds. Not sure if anyone have any good ideas?
Memory Mapping
Pico H [Flash 2MB]
  • Before: Flash Start ADDR, —[Application]—
  • After: Flash Start ADDR, --[This Bootloader GUI 256KB]-------[Application]—
Awesome, hope this will compatible with the Pico 2 W soon :slightly_smiling_face:. Good job.
Hi @adwuard,
  • I compiled using the Pico2 option without any errors (haven’t tested it yet). I adapt the main.c and the cmakelist
  • Could you provide the source code for a “hello_world” example?
I’d like to use my old development knowledge to work with your system :slight_smile:
Thanks
On Pico 2 W
great work, pico 2 should technically work. I just haven’t got a chance to test it.
The hello world demo came from original PicoCalc repo. PicoCalc/Code/picocalc_helloworld at master · clockworkpi/PicoCalc · GitHub
Thanks. I adjusted the sizes in memmap_sdcard_app.ld to compile the projects. I’ve successfully compiled the NES emulator, and it’s now working with your bootloader. I think it would be a good idea to modify memmap_sdcard_app.ld to handle memory size dynamically based on the Pico variant.
I attempted to build the PicoMite firmware (for Pico, though I plan to build WebMite for Pico2 as well) for the loader but when I launch it I just get a black screen. The loader works with the pre-built examples though.
Any idea what I’ve done wrong?
@TheKiwil did you post your changes anywhere for the Pico2? That would be helpful for PicoMite/WebMite. And maybe it would help me figure out what is wrong with the Pico build as well.
@adcockm What is the .bin output size of the picomite? This bootloader will use 256KB of initial flash memory, which left about ~1.7MB for the loading applications.
  1. Make sure the app uses within 1.7MB of flash.
  2. Make sure if the picomite has any hard coded memory manipulation. If so then it might be a problem.
I will also try and compile your PicoMite codebase and see if I could figure it out.
@TheKiwil it will be nice if you can shed some insight on building for pico2 and your changes on linker file.:grin:
Here’s a visualized image of the new flash layout.
@adcockm, I’ll probably fork the work of @adwuard (because I’ve seen a display error when the file name is too large, so just set a limit of display length). In the meantime, the two files main.c and memmap_sdcard_app.ld that I modified yet below:
main.c (only changed made at line 166)
 * PicoCalc SD Firmware Loader
 * Author: Hsuan Han Lai
 * Email: hsuan.han.lai@gmail.com
 * Website: https://hsuanhanlai.com
 * Year: 2025
 * This project is a bootloader for the PicoCalc device, designed to load and execute
 * firmware applications from an SD card.
#include <stdio.h>
#include <string.h>
#include "pico/stdlib.h"
#include "hardware/gpio.h"
#include "hardware/clocks.h"
#include "debug.h"
#include "i2ckbd.h"
#include "lcdspi.h"
#include <hardware/flash.h>
#include <errno.h>
#include <hardware/watchdog.h>
#include "config.h"
#include "blockdevice/sd.h"
#include "filesystem/fat.h"
#include "filesystem/vfs.h"
#include "text_directory_ui.h"
#include "key_event.h"
const uint LEDPIN = 25;
bool sd_card_inserted(void)
    // Active low detection - returns true when pin is low
    return !gpio_get(SD_DET_PIN);
bool fs_init(void)
    DEBUG_PRINT("fs init SD\n");
    blockdevice_t *sd = blockdevice_sd_create(spi0,
                                              SD_MOSI_PIN,
                                              SD_MISO_PIN,
                                              SD_SCLK_PIN,
                                              SD_CS_PIN,
                                              125000000 / 2 / 4, // 15.6MHz
                                              true);
    filesystem_t *fat = filesystem_fat_create();
    int err = fs_mount("/sd", fat, sd);
    if (err == -1)
        DEBUG_PRINT("format /sd\n");
        err = fs_format(fat, sd);
        if (err == -1)
            DEBUG_PRINT("format err: %s\n", strerror(errno));
            return false;
        if (err == -1)
            DEBUG_PRINT("mount err: %s\n", strerror(errno));
            return false;
    return true;
static bool __not_in_flash_func(is_same_existing_program)(FILE *fp)
    uint8_t buffer[FLASH_SECTOR_SIZE] = {0};
    size_t program_size = 0;
    size_t len = 0;
    while ((len = fread(buffer, 1, sizeof(buffer), fp)) > 0)
        uint8_t *flash = (uint8_t *)(XIP_BASE + SD_BOOT_FLASH_OFFSET + program_size);
        if (memcmp(buffer, flash, len) != 0)
            return false;
        program_size += len;
    return true;
// This function must run from RAM since it erases and programs flash memory
static bool __not_in_flash_func(load_program)(const char *filename)
    FILE *fp = fopen(filename, "r");
    if (fp == NULL)
        DEBUG_PRINT("open %s fail: %s\n", filename, strerror(errno));
        return false;
    if (is_same_existing_program(fp))
        // Program is up to date
    // Check file size to ensure it doesn't exceed the available flash space
    if (fseek(fp, 0, SEEK_END) == -1)
        DEBUG_PRINT("seek err: %s\n", strerror(errno));
        fclose(fp);
        return false;
    long file_size = ftell(fp);
    if (file_size <= 0)
        DEBUG_PRINT("invalid size: %ld\n", file_size);
        fclose(fp);
        return false;
    if (file_size > MAX_APP_SIZE)
        DEBUG_PRINT("file too large: %ld > %d\n", file_size, MAX_APP_SIZE);
        fclose(fp);
        return false;
    DEBUG_PRINT("updating: %ld bytes\n", file_size);
    if (fseek(fp, 0, SEEK_SET) == -1)
        fclose(fp);
        return false;
    size_t len = 0;
    // Erase and program flash in FLASH_SECTOR_SIZE chunks
        // Ensure we don't write beyond the application area
        if ((program_size + len) > MAX_APP_SIZE)
            DEBUG_PRINT("err: write beyond app area\n");
            fclose(fp);
            return false;
        uint32_t ints = save_and_disable_interrupts();
        flash_range_erase(SD_BOOT_FLASH_OFFSET + program_size, FLASH_SECTOR_SIZE);
        flash_range_program(SD_BOOT_FLASH_OFFSET + program_size, buffer, len);
        restore_interrupts(ints);
    DEBUG_PRINT("program loaded\n");
    fclose(fp);
    return true;
// This function jumps to the application entry point
// It must update the vector table and stack pointer before jumping
void __not_in_flash_func(launch_application_from)(uint32_t *app_location)
    // https://vanhunteradams.com/Pico/Bootloader/Bootloader.html
    uint32_t *new_vector_table = app_location;
    volatile uint32_t *vtor = (uint32_t *)(PPB_BASE + M33_VTOR_OFFSET);
    *vtor = (uint32_t)new_vector_table;
    asm volatile(
        "msr msp, %0\n"
        "bx %1\n"
        : "r"(new_vector_table[0]), "r"(new_vector_table[1])
// Check if a valid application exists in flash by examining the vector table
static bool is_valid_application(uint32_t *app_location)
    // Check that the initial stack pointer is within a plausible RAM region (assumed range for Pico: 0x20000000 to 0x20040000)
    uint32_t stack_pointer = app_location[0];
    if (stack_pointer < 0x20000000 || stack_pointer > 0x20040000)
        return false;
    // Check that the reset vector is within the valid flash application area
    uint32_t reset_vector = app_location[1];
    if (reset_vector < (0x10000000 + SD_BOOT_FLASH_OFFSET) || reset_vector > (0x10000000 + PICO_FLASH_SIZE_BYTES))
        return false;
    return true;
int load_firmware_by_path(const char *path)
    text_directory_ui_set_status("STAT: loading app...");
    // Attempt to load the application from the SD card
    // bool load_success = load_program(FIRMWARE_PATH);
    bool load_success = load_program(path);
    // Get the pointer to the application flash area
    uint32_t *app_location = (uint32_t *)(XIP_BASE + SD_BOOT_FLASH_OFFSET);
    // Check if there is an already valid application in flash
    bool has_valid_app = is_valid_application(app_location);
    if (load_success || has_valid_app)
        text_directory_ui_set_status("STAT: launching app...");
        DEBUG_PRINT("launching app\n");
        // Small delay to allow printf to complete
        sleep_ms(100);
        launch_application_from(app_location);
    else
        text_directory_ui_set_status("ERR: No valid app");
        DEBUG_PRINT("no valid app, halting\n");
        sleep_ms(2000);
        // Trigger a watchdog reboot
        watchdog_reboot(0, 0, 0);
    // We should never reach here
    while (1)
        tight_loop_contents();
void final_selection_callback(const char *path)
    // Trigger firmware loading with the selected path
    DEBUG_PRINT("selected: %s\n", path);
    char status_message[128];
    const char *extension = ".bin";
    size_t path_len = strlen(path);
    size_t ext_len = strlen(extension);
    if (path_len < ext_len || strcmp(path + path_len - ext_len, extension) != 0)
        DEBUG_PRINT("not a bin: %s\n", path);
        snprintf(status_message, sizeof(status_message), "Err: FILE is not a .bin file");
        text_directory_ui_set_status(status_message);
        return;
    snprintf(status_message, sizeof(status_message), "SEL: %s", path);
    sleep_ms(200);
    load_firmware_by_path(path);
int main()
    char buf[64];
    stdio_init_all();
    uart_init(uart0, 115200);
    uart_set_format(uart0, 8, 1, UART_PARITY_NONE); // 8-N-1
    uart_set_fifo_enabled(uart0, false);
    // Initialize SD card detection pin
    gpio_init(SD_DET_PIN);
    gpio_set_dir(SD_DET_PIN, GPIO_IN);
    gpio_pull_up(SD_DET_PIN); // Enable pull-up resistor
    keypad_init();
    lcd_init();
    lcd_clear();
    text_directory_ui_init();
    // Check for SD card presence
    DEBUG_PRINT("Checking for SD card...\n");
    if (!sd_card_inserted())
        DEBUG_PRINT("SD card not detected\n");
        text_directory_ui_set_status("SD card not detected. \nPlease insert SD card.");
        // Poll until SD card is inserted
        while (!sd_card_inserted())
            sleep_ms(100);
        // Card detected, wait for it to stabilize
        DEBUG_PRINT("SD card detected\n");
        text_directory_ui_set_status("SD card detected. Mounting...");
        sleep_ms(1500); // Wait for card to stabilize
    else
        // If SD card is detected at boot, wait for stabilization
        DEBUG_PRINT("SD card stabilization delay on boot\n");
        text_directory_ui_set_status("Stabilizing SD card...");
        sleep_ms(1500); // Delay to allow the SD card to fully power up and stabilize
    // Initialize filesystem
    if (!fs_init())
        text_directory_ui_set_status("Failed to mount SD card!");
        DEBUG_PRINT("Failed to mount SD card\n");
        sleep_ms(2000);
    sleep_ms(500);
    lcd_clear();
    text_directory_ui_set_final_callback(final_selection_callback);
    text_directory_ui_run();
memmap_sdcard_app.ld:
MEMORY
    FLASH(rx) : ORIGIN = 0x10000000 + 512k, LENGTH = 4096k - 512k
    RAM(rwx) : ORIGIN =  0x20000000, LENGTH = 512k
    SCRATCH_X(rwx) : ORIGIN = 0x20040000, LENGTH = 4k
    SCRATCH_Y(rwx) : ORIGIN = 0x20041000, LENGTH = 4k
ENTRY(_entry_point)
SECTIONS
    /* Second stage bootloader is prepended to the image. It must be 256 bytes big
       and checksummed. It is usually built by the boot_stage2 target
       in the Raspberry Pi Pico SDK
    .flash_begin : {
        __flash_binary_start = .;
    } > FLASH
    /* The second stage will always enter the image at the start of .text.
       The debugger will use the ELF entry point, which is the _entry_point
       symbol if present, otherwise defaults to start of .text.
       This can be used to transfer control back to the bootrom on debugger
       launches only, to perform proper flash setup.
    .text : {
        __logical_binary_start = .;
        KEEP (*(.vectors))
        KEEP (*(.binary_info_header))
        __binary_info_header_end = .;
        KEEP (*(.reset))
        /* TODO revisit this now memset/memcpy/float in ROM */
        /* bit of a hack right now to exclude all floating point and time critical (e.g. memset, memcpy) code from
         * FLASH ... we will include any thing excluded here in .data below by default */
        *(.init)
        *(EXCLUDE_FILE(*libgcc.a: *libc.a:*lib_a-mem*.o *libm.a:) .text*)
        *(.fini)
        /* Pull all c'tors into .text */
        *crtbegin.o(.ctors)
        *crtbegin?.o(.ctors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
        *(SORT(.ctors.*))
        *(.ctors)
        /* Followed by destructors */
        *crtbegin.o(.dtors)
        *crtbegin?.o(.dtors)
        *(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
        *(SORT(.dtors.*))
        *(.dtors)
        *(.eh_frame*)
        . = ALIGN(4);
    } > FLASH
    .rodata : {
        *(EXCLUDE_FILE(*libgcc.a: *libc.a:*lib_a-mem*.o *libm.a:) .rodata*)
        . = ALIGN(4);
        *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.flashdata*)))
        . = ALIGN(4);
    } > FLASH
    .ARM.extab :
        *(.ARM.extab* .gnu.linkonce.armextab.*)
    } > FLASH
    __exidx_start = .;
    .ARM.exidx :
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
    } > FLASH
    __exidx_end = .;
    /* Machine inspectable binary information */
    . = ALIGN(4);
    __binary_info_start = .;
    .binary_info :
        KEEP(*(.binary_info.keep.*))
        *(.binary_info.*)
    } > FLASH
    __binary_info_end = .;
    . = ALIGN(4);
   .ram_vector_table (NOLOAD): {
        *(.ram_vector_table)
    } > RAM
    .data : {
        __data_start__ = .;
        *(vtable)
        *(.time_critical*)
        /* remaining .text and .rodata; i.e. stuff we exclude above because we want it in RAM */
        *(.text*)
        . = ALIGN(4);
        *(.rodata*)
        . = ALIGN(4);
        *(.data*)
        . = ALIGN(4);
        *(.after_data.*)
        . = ALIGN(4);
        /* preinit data */
        PROVIDE_HIDDEN (__mutex_array_start = .);
        KEEP(*(SORT(.mutex_array.*)))
        KEEP(*(.mutex_array))
        PROVIDE_HIDDEN (__mutex_array_end = .);
        . = ALIGN(4);
        /* preinit data */
        PROVIDE_HIDDEN (__preinit_array_start = .);
        KEEP(*(SORT(.preinit_array.*)))
        KEEP(*(.preinit_array))
        PROVIDE_HIDDEN (__preinit_array_end = .);
        . = ALIGN(4);
        /* init data */
        PROVIDE_HIDDEN (__init_array_start = .);
        KEEP(*(SORT(.init_array.*)))
        KEEP(*(.init_array))
        PROVIDE_HIDDEN (__init_array_end = .);
        . = ALIGN(4);
        /* finit data */
        PROVIDE_HIDDEN (__fini_array_start = .);
        *(SORT(.fini_array.*))
        *(.fini_array)
        PROVIDE_HIDDEN (__fini_array_end = .);
        *(.jcr)
        . = ALIGN(4);
        /* All data end */
        __data_end__ = .;
    } > RAM AT> FLASH
    /* __etext is (for backwards compatibility) the name of the .data init source pointer (...) */
    __etext = LOADADDR(.data);
    .uninitialized_data (NOLOAD): {
        . = ALIGN(4);
        *(.uninitialized_data*)
    } > RAM
    /* Start and end symbols must be word-aligned */
    .scratch_x : {
        __scratch_x_start__ = .;
        *(.scratch_x.*)
        . = ALIGN(4);
        __scratch_x_end__ = .;
    } > SCRATCH_X AT > FLASH
    __scratch_x_source__ = LOADADDR(.scratch_x);
    .scratch_y : {
        __scratch_y_start__ = .;
        *(.scratch_y.*)
        . = ALIGN(4);
        __scratch_y_end__ = .;
    } > SCRATCH_Y AT > FLASH
    __scratch_y_source__ = LOADADDR(.scratch_y);
    .bss  : {
        . = ALIGN(4);
        __bss_start__ = .;
        *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.bss*)))
        *(COMMON)
        . = ALIGN(4);
        __bss_end__ = .;
    } > RAM
    .heap (NOLOAD):
        __end__ = .;
        end = __end__;
        KEEP(*(.heap*))
        __HeapLimit = .;
    } > RAM
    /* .stack*_dummy section doesn't contains any symbols. It is only
     * used for linker to calculate size of stack sections, and assign
     * values to stack symbols later
     * stack1 section may be empty/missing if platform_launch_core1 is not used */
    /* by default we put core 0 stack at the end of scratch Y, so that if core 1
     * stack is not used then all of SCRATCH_X is free.
    .stack1_dummy (NOLOAD):
        *(.stack1*)
    } > SCRATCH_X
    .stack_dummy (NOLOAD):
        KEEP(*(.stack*))
    } > SCRATCH_Y
    .flash_end : {
        PROVIDE(__flash_binary_end = .);
    } > FLASH
    /* stack limit is poorly named, but historically is maximum heap ptr */
    __StackLimit = ORIGIN(RAM) + LENGTH(RAM);
    __StackOneTop = ORIGIN(SCRATCH_X) + LENGTH(SCRATCH_X);
    __StackTop = ORIGIN(SCRATCH_Y) + LENGTH(SCRATCH_Y);
    __StackOneBottom = __StackOneTop - SIZEOF(.stack1_dummy);
    __StackBottom = __StackTop - SIZEOF(.stack_dummy);
    PROVIDE(__stack = __StackTop);
    /* Check if data + heap + stack exceeds RAM limit */
    ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed")
    ASSERT( __binary_info_header_end - __logical_binary_start <= 512, "Binary info must be in first 512 bytes of the binary")
    /* todo assert on extra code */
My CMakeLists.txt (for Pico 2 w)
cmake_minimum_required(VERSION 3.13...3.27)
set(PICO_PLATFORM rp2350)
set(PICO_BOARD pico2_w)
include(pico_sdk_import.cmake)
project(picocalc_sd_boot C CXX ASM)
set(CMAKE_INSTALL_PREFIX ${CMAKE_SOURCE_DIR} CACHE PATH "Install prefix set to project root" FORCE)
set(CMAKE_C_STANDARD 11)
set(CMAKE_CXX_STANDARD 17)
pico_sdk_init()
include_directories(
  ${CMAKE_CURRENT_LIST_DIR}
add_subdirectory(i2ckbd)
add_subdirectory(lcdspi)
add_subdirectory(pico-vfs)
function(build_for_board board_name)
  add_executable(picocalc_sd_boot_${board_name}
    main.c
    key_event.c
    text_directory_ui.c
  target_link_libraries(picocalc_sd_boot_${board_name}
    pico_stdlib
    hardware_sync
    hardware_flash
    hardware_irq
    hardware_adc
    hardware_pwm
    hardware_i2c
    hardware_spi
    hardware_dma
    hardware_exception
    hardware_pio
    pico_multicore
    i2ckbd
    lcdspi
    blockdevice_sd
    filesystem_fat
    filesystem_vfs
  pico_enable_stdio_usb(picocalc_sd_boot_${board_name} 0)
  pico_enable_stdio_uart(picocalc_sd_boot_${board_name} 1)
  pico_add_extra_outputs(picocalc_sd_boot_${board_name})
  target_link_options(picocalc_sd_boot_${board_name} PRIVATE -Wl,--print-memory-usage)
  # Define the output directory relative to the project root directory
  set(output_dir prebuild_output/${board_name})
  install(FILES ${CMAKE_CURRENT_BINARY_DIR}/picocalc_sd_boot_${board_name}.elf
    DESTINATION ${output_dir}
  install(FILES ${CMAKE_CURRENT_BINARY_DIR}/picocalc_sd_boot_${board_name}.uf2
  install(FILES ${CMAKE_CURRENT_BINARY_DIR}/picocalc_sd_boot_${board_name}.bin
endfunction()
# Build for Pico
#build_for_board(pico)
# Build for Pico 2
build_for_board(pico2_w)
# This function sets the custom linker script for SD card applications
# The memmap_sdcard_app.ld script configures the application to start at
# FLASH origin = 0x10000000 + 256k, which aligns with the SD_BOOT_FLASH_OFFSET
# defined in main.c (256 * 1024). This ensures the bootloader (first 256KB)
# is preserved when flashing the application.
function(enable_sdcard_app target)
  pico_set_linker_script(${target} ${CMAKE_SOURCE_DIR}/memmap_sdcard_app.ld)
endfunction()
I hope to have some time tommorrow to try to compile @adcockm Webmite version.
And the pico 2 have 4Mb of flash so ~3.7Mb left space :slightly_smiling_face:.
The .bin file is about 780k. (The same as a .uf2 is over 1.5MB, but I guess that shouldn’t matter. I was surprised at how much smaller it was as just the .bin though.)
Ah, that’s a very good point. I haven’t started to dig into it yet, but this may be the problem.
Thanks!
I confirm, I’ve the same issue on my side (black screen). I’m think the response is here (some flash address and size was configured): PicoMiteAllVersions/configuration.h at main · madcock/PicoMiteAllVersions · GitHub
I managed to compile and launch PicoMite from the bootloader :tada:, but there was a memory error when a program .bas was loaded (probably another variable to modify at address level). You actually have to modify the PicoMite.c file to add the boot address (from line 234, in my case I’m on Pico 2 W so I set 512K):
const uint8_t *flash_option_contents = (const uint8_t *) (XIP_BASE + (512*1024) + FLASH_TARGET_OFFSET);
const uint8_t *SavedVarsFlash = (const uint8_t *) (XIP_BASE + (512*1024) + FLASH_TARGET_OFFSET +  FLASH_ERASE_SIZE);
const uint8_t *flash_target_contents = (const uint8_t *) (XIP_BASE + (512*1024) + FLASH_TARGET_OFFSET + FLASH_ERASE_SIZE + SAVEDVARS_FLASH_SIZE);
const uint8_t *flash_progmemory = (const uint8_t *) (XIP_BASE + (512*1024) + PROGSTART);
const uint8_t *flash_libmemory = (const uint8_t *) (XIP_BASE + (512*1024) + PROGSTART - MAX_PROG_SIZE);
@adwuard, I have found a bootloader rest that we could use as inspiration to manage the two varian (rp2040 and rp2350). Here: GitHub - IndoorCorgi/picoboot3: Custom bootloader that allows firmware updates to Raspberry Pi Pico via UART/I2C/SPI.
Nice ! I’m very novice at compiling, but i managed to compile PicoMite to the .bin file last night but when i tried to launch it from the PicoCalc it went to black screen, then faded away, and came back to boot loader menu. Would you be able to post a step by step guide on how to successfully compile it? :sweat_smile:
I haven’t gotten this far on mine. I get:
fatal error: hardware/pwm.h: No such file or directory
46 | #include “hardware/pwm.h”
compilation terminated.
make[2]: *** [CMakeFiles/PicoMite.dir/build.make:76: CMakeFiles/PicoMite.dir/PicoMite.c.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:1874: CMakeFiles/PicoMite.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
I seem to get this kind of issues on a lot of pico projects and it’s driving me up the wall.
I’ll give it a try. Since my last post, I’ve made further progress and can now run my programs without any issues—especially the MP3 player.
However, please note that I’m using a Pico 2 W on my end, and more thorough testing is still needed.
I’ve also modified several files.
CMakeLists.txt:
cmake_minimum_required(VERSION 3.13)
# Valid builds are PICO, PICOUSB, VGA, VGAUSB, HDMI(rp2350 only), HDMIUSB(rp2350 only), WEB
set(PICOCALC true)
set(SDBOOT true)
set(PICO_NO_FLASH true)
# Compile for PICO 1 Board
#set(COMPILE PICO)
# Compile for PICO 2 Board
#set(COMPILE PICORP2350)
set(COMPILE WEBRP2350)
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "HDMIUSB"  OR COMPILE STREQUAL "VGARP2350"  OR COMPILE STREQUAL "VGAUSBRP2350"  OR COMPILE STREQUAL "PICORP2350"  OR COMPILE STREQUAL "PICOUSBRP2350" )
	if (COMPILE STREQUAL "WEBRP2350")
	else()
		set(PICO_BOARD pimoroni_pga2350)
	endif()
else()
	set(PICO_PLATFORM rp2040)
	if (COMPILE STREQUAL "WEB")
		set(PICO_BOARD pico_w)
	else()
		set(PICO_BOARD pico)
	endif()
endif()
project(PicoMite C CXX ASM)
#set(PICO_NO_COPRO_DIS 1)
pico_sdk_init()
add_executable(PicoMite
	PicoMite.c
	Memory.c
	regex.c
	MMBasic.c
	Operators.c
	Custom.c
	Functions.c
	Commands.c
	FileIO.c
	ff.c
	ffsystem.c
	ffunicode.c
	mmc_stm32.c
	Draw.c
	Editor.c
	XModem.c
	MM_Misc.c
	External.c
	MATHS.c
	Onewire.c
	I2C.c
	SPI.c
	Serial.c
	SPI-LCD.c
	BmpDecoder.c
	GPS.c
	Audio.c
	CFunction.c
    picojpeg.c
    lfs.c
    lfs_util.c
	hxcmod.c
    VS1053.c
	aes.c
if (COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350" )
    target_sources(PicoMite PRIVATE
	SSD1963.c
	Touch.c
	GUI.c
	cJSON.c
    mqtt.c
    MMMqtt.c
    MMTCPclient.c
    MMtelnet.c
    MMntp.c
    MMtcpserver.c
    tftp.c
    MMtftp.c
    MMudp.c
	set_source_files_properties(cJSON.c PROPERTIES COMPILE_FLAGS -Os)
	target_include_directories(PicoMite PRIVATE
	${CMAKE_CURRENT_LIST_DIR}/.. # for our common lwipopts
	Pico_enable_stdio_usb(PicoMite 1)
endif()
if ((COMPILE STREQUAL "PICO") OR (COMPILE STREQUAL "PICOUSB") OR (COMPILE STREQUAL "PICORP2350") OR (COMPILE STREQUAL "PICOUSBRP2350") OR (COMPILE STREQUAL "WEBRP2350"))
	SSD1963.c
	Touch.c
	GUI.c)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB")
	USBKeyboard.c
else()
	Keyboard.c
	mouse.c
endif()
if(COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "PICOUSBRP2350")
	upng.c
	# assember.S
endif()
set_source_files_properties(mmc_stm32.c PROPERTIES COMPILE_FLAGS -O2)
set_source_files_properties(ff.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GUI.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(BmpDecoder.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GPS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(I2C.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(lfs.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(picojpeg.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(regex.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(hxcmod.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(MATHS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(Editor.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(aes.c PROPERTIES COMPILE_FLAGS -Os)
pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteI2S.pio)
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "WEB")
	pico_define_boot_stage2(slower_boot2 ${PICO_DEFAULT_BOOT_STAGE2_FILE})
	target_compile_definitions(slower_boot2 PRIVATE PICO_FLASH_SPI_CLKDIV=4)
	pico_set_boot_stage2(PicoMite slower_boot2)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "VGARP2350")
	pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteVGA.pio)
#	pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteI2S.pio)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
	Pico_enable_stdio_usb(PicoMite 0)
	target_include_directories(PicoMite PRIVATE ${CMAKE_CURRENT_SOURCE_DIR}
	${CMAKE_CURRENT_SOURCE_DIR}/usb_host_files
else()
endif()
pico_enable_stdio_uart(PicoMite 0)
pico_add_extra_outputs(PicoMite)
pico_set_printf_implementation(PicoMite compiler)
target_compile_options(PicoMite PRIVATE -DNDEBUG
										-DPICO_STDIO_USB_ENABLE_RESET_VIA_VENDOR_INTERFACE=0
										-DPICO_ADC_CLKDIV_ROUND_NEAREST
										-DPICO_XOSC_STARTUP_DELAY_MULTIPLIER=64
										-DPICO_CLOCK_AJDUST_PERI_CLOCK_WITH_SYS_CLOCK
										#-DPICO_FLASH_SIZE_BYTES=16777216
										-DPICO_FLASH_SIZE_BYTES=16777728
										-DPICO_CORE1_STACK_SIZE=0x00
										-DPICO_MALLOC_PANIC
										-O2
										-Wall)
# all RP2350 variants
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
target_compile_options(PicoMite PRIVATE -Drp2350
										-DPICO_FLASH_SPI_CLKDIV=4
										-DPICO_PIO_USE_GPIO_BASE
endif()
# all PicoMite variants - enable the gui
if (COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "PICOUSBRP2350")
target_compile_options(PicoMite PRIVATE -DPICOMITE
										-DPICO_HEAP_SIZE=0x1000
										-DGUICONTROLS
										-DPICO_CORE0_STACK_SIZE=0x1000
endif()
# all VGA variants
if (COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
target_compile_options(PicoMite PRIVATE -DPICOMITEVGA
										-DPICO_HEAP_SIZE=0x2000
										-DPICO_CORE0_STACK_SIZE=0x2000
endif()
# HDMI variants
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "HDMIUSB")
										-DHDMI
endif()
#Web variants need more heap
if(COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350")
	target_compile_options(PicoMite PRIVATE -DPICOMITEWEB
											-DPICO_HEAP_SIZE=0x4000
											-DGUICONTROLS
											-DCYW43_HOST_NAME="WebMite"
											-DPICO_CYW43_ARCH_POLL
											-DPICO_CORE0_STACK_SIZE=0x4000
endif()
#USB variants
if (COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "HDMIUSB")
target_compile_options(PicoMite PRIVATE -DUSBKEYBOARD
endif()
#special case WEB RP2350 gets the GUI controls
if(COMPILE STREQUAL "WEBRP2350")
	target_compile_options(PicoMite PRIVATE -DGUICONTROLS
endif()
#set the PICOCALC flag
if(PICOCALC STREQUAL "true")
	target_compile_options(PicoMite PRIVATE -DPICOCALC
endif()
target_link_libraries(PicoMite
	pico_stdlib
	hardware_flash
	hardware_irq
	hardware_adc
	hardware_pwm
	hardware_i2c
	hardware_spi
	hardware_dma
	hardware_exception
	hardware_pio
if(COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
	tinyusb_host
	tinyusb_board
	pico_multicore
endif()
if(COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "PICORP2350")
	pico_multicore
endif()
	pico_rand
endif()
if(COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350" )
	pico_cyw43_arch_lwip_poll
endif()
if(SDBOOT STREQUAL "true")
	pico_set_linker_script(PicoMite ${CMAKE_SOURCE_DIR}/memmap_sdcard_app.ld)
endif()
Configuration.h, just the line 154 with:
    #define FLASH_TARGET_OFFSET ((1080 * 1024) + (512 * 1024))
/* Based on GCC ARM embedded samples.
   Defines the following symbols for use by code:
    __exidx_start
    __exidx_end
    __etext
    __data_start__
    __preinit_array_end
    __init_array_start
    __init_array_end
    __fini_array_start
    __fini_array_end
    __data_end__
    __bss_start__
    __bss_end__
    __end__
    end
    __HeapLimit
    __StackLimit
    __StackTop
    __stack (== StackTop)
MEMORY
    SCRATCH_X(rwx) : ORIGIN = 0x20080000, LENGTH = 4k
    SCRATCH_Y(rwx) : ORIGIN = 0x20081000, LENGTH = 4k
ENTRY(_entry_point)
SECTIONS
    .flash_begin : {
    } > FLASH
    /* The bootrom will enter the image at the point indicated in your
       IMAGE_DEF, which is usually the reset handler of your vector table.
       symbol, and in our case is *different from the bootrom's entry point.*
       This is used to go back through the bootrom on debugger launches only,
       to perform the same initial flash setup that would be performed on a
       cold boot.
    .text : {
        KEEP (*(.vectors))
        KEEP (*(.embedded_block))
        __embedded_block_end = .;
        KEEP (*(.reset))
        *(.init)
        *libgcc.a:cmse_nonsecure_call.o
        *(.fini)
        *crtbegin.o(.ctors)
        *(SORT(.ctors.*))
        *(.ctors)
        *crtbegin.o(.dtors)
        *(SORT(.dtors.*))
        *(.dtors)
        . = ALIGN(4);
        /* preinit data */
        . = ALIGN(4);
        /* init data */
        . = ALIGN(4);
        /* finit data */
        *(.fini_array)
        *(.eh_frame*)
        . = ALIGN(4);
    } > FLASH
    /* Note the boot2 section is optional, and should be discarded if there is
       no reference to it *inside* the binary, as it is not called by the
       bootrom. (The bootrom performs a simple best-effort XIP setup and
       leaves it to the binary to do anything more sophisticated.) However
       there is still a size limit of 256 bytes, to ensure the boot2 can be
       stored in boot RAM.
       Really this is a "XIP setup function" -- the name boot2 is historic and
       refers to its dual-purpose on RP2040, where it also handled vectoring
       from the bootrom into the user image.
    .boot2 : {
        __boot2_start__ = .;
        *(.boot2)
        __boot2_end__ = .;
    } > FLASH
    ASSERT(__boot2_end__ - __boot2_start__ <= 256,
        "ERROR: Pico second stage bootloader must be no more than 256 bytes in size")
    .rodata : {
        *(.srodata*)
        . = ALIGN(4);
        . = ALIGN(4);
    } > FLASH
    .ARM.extab :
    } > FLASH
    __exidx_start = .;
    .ARM.exidx :
    } > FLASH
    __exidx_end = .;
    . = ALIGN(4);
    .binary_info :
        *(.binary_info.*)
    } > FLASH
    . = ALIGN(4);
    } > RAM
        . = ALIGN(4);
    } > RAM
    .data : {
        __data_start__ = .;
        *(vtable)
        *(.time_critical*)
        *(.text*)
        . = ALIGN(4);
        *(.rodata*)
        . = ALIGN(4);
        *(.data*)
        *(.sdata*)
        . = ALIGN(4);
        *(.after_data.*)
        . = ALIGN(4);
        /* preinit data */
        *(.jcr)
        . = ALIGN(4);
    } > RAM AT> FLASH
    .tdata : {
        . = ALIGN(4);
		*(.tdata .tdata.* .gnu.linkonce.td.*)
        /* All data end */
        __tdata_end = .;
    } > RAM AT> FLASH
    PROVIDE(__data_end__ = .);
    .tbss (NOLOAD) : {
        . = ALIGN(4);
        __bss_start__ = .;
        __tls_base = .;
        *(.tbss .tbss.* .gnu.linkonce.tb.*)
        *(.tcommon)
        __tls_end = .;
    } > RAM
    .bss (NOLOAD) : {
        . = ALIGN(4);
        __tbss_end = .;
        *(COMMON)
        PROVIDE(__global_pointer$ = . + 2K);
        *(.sbss*)
        . = ALIGN(4);
        __bss_end__ = .;
    } > RAM
    .heap (NOLOAD):
        __end__ = .;
        end = __end__;
        KEEP(*(.heap*))
        /* historically on GCC sbrk was growing past __HeapLimit to __StackLimit, however
           to be more compatible, we now set __HeapLimit explicitly to where the end of the heap is */
        . = ORIGIN(RAM) + LENGTH(RAM);
        __HeapLimit = .;
    } > RAM
    .scratch_x : {
        *(.scratch_x.*)
        . = ALIGN(4);
    .scratch_y : {
        *(.scratch_y.*)
        . = ALIGN(4);
        *(.stack1*)
    } > SCRATCH_X
        KEEP(*(.stack*))
    } > SCRATCH_Y
    .flash_end : {
        KEEP(*(.embedded_end_block*))
    } > FLASH =0xaa
    /* picolibc and LLVM */
    PROVIDE (__heap_start = __end__);
    PROVIDE (__heap_end = __HeapLimit);
    PROVIDE( __tls_align = MAX(ALIGNOF(.tdata), ALIGNOF(.tbss)) );
    PROVIDE( __tls_size_align = (__tls_size + __tls_align - 1) & ~(__tls_align - 1));
    PROVIDE( __arm32_tls_tcb_offset = MAX(8, __tls_align) );
    /* llvm-libc */
    PROVIDE (_end = __end__);
    PROVIDE (__llvm_libc_heap_limit = __HeapLimit);
    ASSERT( __binary_info_header_end - __logical_binary_start <= 1024, "Binary info must be in first 1024 bytes of the binary")
    ASSERT( __embedded_block_end - __logical_binary_start <= 4096, "Embedded block must be in first 4096 bytes of the binary")
Thank you! I think i actually have a Pico 2w lying around somehwere :sweat_smile: I’m gonna find it, and swap it out. That way I can be on the same page so to speak :smiley:
@adwuard, Thanks for the display tweaks :slightly_smiling_face:
I’ve created two forks: one for @adwuard’s bootloader, including support for the Pico 2 W variant, and another with a “bootloader” branch for the PicoMite, based on @adcockm’s sources.
Bootloader fork: GitHub - TheKiwil/Picocalc_SD_Boot: Bootloader that loads firmware from PicoCalc's SD card Slot.
PicoMite fork: GitHub - TheKiwil/PicoMiteAllVersions-1 at bootloader
Will
@TheKiwil Awesome work! Thanks for the support for the project and amazing work on supporting PicoMite. :clap:
Like you said I took your advise on improving file length displaying with scrolling effect. And added file size UI for better file selection experience.:grin:
I’m currently working on defined based conditional size or the .ld link file. But haven’t got it to work. Got some syntax error, and c code or CMakeLists file doesn’t trigger .ld conditional flag.
I do have one other question is that why does it have to be 512KB? I’ve tried 256KB like the pico1 and it doesn’t work. Is the pico2’s memory map different?
Cheers,
Ed
