Screen issue (nothing appares)
Just assembled the uConsole. Fancy little machine.
But when I turn on the console (saw the green light so that the battery has juice). The screen wont appear anything (only a bit dim light like any other screen when you turn it on).
Is that something wrong? The first power on wont take 3 mins right?
Got the CM4 mode. Hope the screen wiring cable is fine.
BTW, when I press Fn + Print/H/J, I can hear a tweet sound. I think the mother board is ok?
Does the SD card contains any firmware?
But just fixed this uConsole issue after re-assembling it + reflashing the SD card. I think the old firmware in the SD card was corrupted!
What did you flash it with?
Hi, late response:
I use the official software (Raspberry Pi Imager) for Raspberry Pi, using the option (if I rember correctly) “Other OS” with the official OS of the uConsole.
…Did you pay attention to the installation instructions? Specifically, not using custom settings when flashing the image?
