Sharing Internet using USB-C cable
The weak performance of the bundled antenna is an issue, but I’m also looking for a way to connect the uConsole to a network in an environment that doesn’t provide WiFi.
One of the ways is to share the internet on macOS via a USB-C cable, which I did as shown below, but in the end I was unable to make any connections on macOS.
If someone could point out where I went wrong, I would greatly appreciate it.
  1. modified /boot/config.txt from dtoverlay=dwc2,dr_mode=host to dtoverlay=dwc2
  2. append modules-load=dwc2,g_ether to /boot/cmdline
  3. add libcomposite to /etc/modules
  4. Add denyinterfaces usb0 to /etc/dhcpcd.conf
  5. sudo apt-get install dnsmasq
  6. create /etc/dnsmasq.d/usb file.
    interface=usb0
    dhcp-range=10.55.0.2,10.55.0.6,255.255.255.248,1h
    dhcp-option=3
    leasefile-ro
  7. Create /etc/network/interfaces.d/usb0 file
    auto usb0
    allow-hotplug usb0
    iface usb0 inet static
    address 10.55.0.1
    netmask 255.255.255.248
Then reboot, and usb0 interface is up and configured.
uConsole is connected with macOS via USB-C, but no interface appears nor system alert that shows like ‘new usb device found’.
PS1) if /boot/config.txt changed to dtoverlay=dwc2,dr_mode=peripheral, keyboard/mouse of uConsole does not work at all.
Maybe you need the Mac drivers? HoRNDIS: USB tethering driver for Mac OS X | Joshua Wise's domain
This is the driver used on the gameshell for USB ETH.
This guy just works. Dell usb3 gigabit Ethernet adapter.
@Petrakis Thank you for your reply.
The latest version of driver is outdated and does not work on macOS 13.
And I built kext my own without signining & turned off system guard using csrutil in Safe Mode of macOS. BUT eventually I had to delete the kext because the whole macOS system stopped in networking. After delete the kext and reboot, everything work again.
@barry99705 Thank you for your suggestion. But I have only one Ethernet line for my macbook and I am trying to share its internet connection with uConsole. I’ll keep trying to make connection using USB-C.
I thought the USB C port on the uConsole was power only. Does it even have data lines connected to it?
The USB C port has data lines connected to it, which go directly to the SODIMM port for the core.
From what I can tell, it’s listed as “power only” because not all cores connect that line. From what I can tell, data should connect on the R01 core, but not the CM4 core, but I don’t know if there’s any official statement or anybody’s who’s tested them across the board. It could also not be USB 3 speeds.
If you want to check for yourself, you can follow the USB0_DP and USB0_DM wires from the USB section of the Mainboard schematic through to the specific core you’re using.
for the CM4
I saw somewhere in the forum, the usb-c does have some data lines with the pi4 but are missing some others… something about a CC1/CC2 pin to switch modes between host or device… and the default PiOS doesn’t do auto switching just in device mode…
here is some info on the pi forum
https://forums.raspberrypi.com/viewtopic.php?t=347459
more of an argument about someone trying to make it work…
On the CM4 adapter, for the J1 (DDR2 SODIMM), there are:
  • Pin 160: USB0_DP
  • Pin 162: USB0_DM
  • Pin 165: USB_DP
  • Pin 167: USB_DM
  • Pin 168: USB_OTGID
On the actual Compute Module, there are:
  • Pin 101: USB_OTGID
  • Pin 103: USB_DM
  • Pin 105: USB_DP
  • No matches for USB0_DP or USB0_DM
On the Mainboard for J1 (the other side of the DDR2 SODIMM):
  • Pin 168: USB_OTGID is wired to ground through a 1K resistor.
On the Mainboard for US01 (the internal USB hub), there are:
  • USB_DP and USB_DM enter the USB hub labeled as DP0 and DM0, respectively.
  • Output as DP1/DM1 through DP4/DM4.
On the Mainboard for JS01 (the Type-c port), there are:
  • Pin B6: USB0_DP
  • Pin B7: USB0_DM
From what I can tell, this means it’s physically impossible to change the USB_OTGID value (which seems to be associated with the internal hub, anyways), or for the USB-C port data connection to reach the CM4.
@Daniel_Segel @sedwca
My mistake. I meant USB-A port not C port.
Thank you guys for letting me know infos.
I did a few more tests and Android USB tethering worked fine with g_ether.
But uConsole could not connect with iPad Pro (refered here)
PS2: When I deleted horndis kext, the USB 10/100/1000 LAN adapter that I had long ago deleted from macOS Network Preferences reappeared in the list.
