Simple d-pad mod
The d-pad felt a bit mushy. Like… you could press all 4 directions at once.
I cut a thin ring ( about 1mm ) off a q-tip and placed it underneath the d-pad. Works like a charm so far.
Hope the ring does not move away. If it does it can be easily glued down.
Something else will do, too.
gameshell
I originally posted this on Twitter:
https://mobile.twitter.com/MonkeyPanicMode/status/1098654495351943168
That is an awesome idea, I’ll try that too, thanks!
Any update if you needed to glue it down after all?
Thanks! :slight_smile:
No, it stayed in place. But it’s not like it has been under heavy use to be honest. Didn’t have much time to play with it.
It’s a subtle, non invasive modification.Just give it a try :slight_smile:
Thanks for sharing, and for the update!
amazing how this actually works! :smiley:
