I just assembled 2 gameshells, the first working perfectly, the D-Pad is great.
The second one I assembled, the D-Pad feels like it has a bit less pressure against it and I have to press quite a bit harder in any direction for it to actuate. Is there any mod I can do to make the D-Pad more sensitive so I don’t have to press it so violently compared to the other?
Any input is appreciated.
yeah i think it has something to do with the rubber but it looks perfectly fine. now only the down direction is difficult to trigger compared to the others
I originally had the same problem. I used 99% rubbing alcohol to clean the metal contacts as well as the rubber contacts and it ended up being a lot more responsive.
