Thermal printer datasheet
I would like to procure datasheet of thermal printer module.
I would like to write proper kernel mode driver and utilies around it.
here is the datasheet
Thanks,
I see problem with current driver - it omitts max 96 dots in one “burn”
you mean the speed of printing is too slow ?
No.
On page 10 parameter Ndot max.
Do you mean that if there are more than 96 pixel on a single line to “burn” you need to do the line in more than one pass before moving the paper?
It’s not really clear what you mean.
Yes I mean that. I says it cannot guarantee print quality otherwise.
I’ve checked the code, due to reduce the current when printing , we set 2 points max can be printed simultaneously
