It seems like that the thermal printer has a temp sensor (a thermistor), and it’s connected to an ADC, which is connected through an I2C bus to the core. On the other hand, it seems to be ignored for now?
By checking the schematics, the thermal printer datasheet, and the ADC datasheet, I think I figured out how to read the temp value from it. Basically, on A04,
value = subprocess.check_output("i2cget -y 1 0x54 0 w", shell=True)
value = int(value.strip(), 16)
# Swap byte order
value = ((value & 0xFF) << 8) | ((value & 0xFF00) >> 8)
# Bits 11:2 are the conversion result
value = (value >> 2) & ((1 << 10) - 1)
# Resistance of the thermistor, R11 = 30
res = 30 / (1024.0 / value - 1)
# Temperature, R25 = 30, B = 3950, R = R25 * e ^ (B * (1 / T - 1 / T25))
temp = 1/(math.log(res / 30) / 3950 + 1/ (25 + 273.15)) - 273.15
print(value, res, temp)
It seems to be reporting a temperature slightly higher than my room temperature, through (~33C, while the room is ~27C), Not sure if I made any mistake. It increases to ~57C during printing, which seems reasonable.
Is there any plan to use this sensor? It seems like that maybe we can use this to measure the environment temperature.
