uConsole Antenna Bracket (3D Model)
I designed an antenna bracket for uConsole.
The profile of the model is basically based on the Bamboo Lab P1S.
To assemble this, you need two M4 bolts of more than 8mm and a super glue.
The reason why superglue is needed is that the parts of the model are separated into two parts for improved printing quality for complex shapes.
Model download
https://makerworld.com/en/models/1103666#profileId-1122681
This is really nice looking! can you include a single part version by any chance? I have support martial so can print as one piece fine I think?
Also is the M4 the size of the antennas? or the replacement back screws to attach this over the back plate?
Thanks for the work! it is awesome looking!
Check the URL he gave in makerworld, a single part profile has been added. The M4 relates the the size of the screws. The flat head screws that come with the Uconsole are M4. The antennas should be of a SWR that is compatible with 2.5 and 5 gHZ.
I uploaded new 3 variants.
They looks nice ! However there’s only a blank bracket on your link.
I’m more a prusa guy and not familiar with makerworld, I may have missed something.
Oh, I wasn’t considerate. I’ll check it right away :sweat_smile:
I uploaded STL :slight_smile:
Rodger that!
Gonna download his 3 antenna version however, that straight one and other angles is really nice!
I got some generic amazon pigtail and antennas and they fit the hex slot perfectly! I see what you mean now that it is printed and assembled. I just need to find a GPS antenna now. I thought a generic antenna would work, but seems like it may be a bad idea to test it with anything but an offical gps antenna since they seem to have some more to them then just an antenna.
edit: I am slow, thanks for adding the single part version! I see now what you ment. I was able to kinda sort make it work in the slicer using the cutting tool and merge tool before I noticed your fix.
Great looking! thanks for the all the options and updates!
do it! Hacker Gadget went full retard on my order when I purchased the AIO v.2 with both antenna pack and mounting bracket.
