Uconsole with ac1200 and HaLow wifi
I am trying to make a wifi tester with the uconsole, but before i tinker myself, i like to know if anybody has tips for installing 2 wifi dongles. The aiov2 with ac1200 is already in. Also the battery board with pcie/nvme but that route does not seem easy.
inboard would be the preferred route, 3d printer backplate is possible to make.
also a lorawan TTN is on the wishlist​:innocent:
Do you want 2 boards inside such to use the two USBC that are in side the case? I have the 7 antenna card, and all may cables are clean under the ribbon cables. For an extra card you need a thin 90 right or left to snake to the card where you have room for it. Not alot of room in there so if I am running extra wifi I do it from USB outside or USBC hub (heap) to external card. Atlease then I can get some distance from the antennas.
